Upgrade to Premium
Arctic Cat: M Series 2005-Current, all models in the M-series chassis
Reply
  #1
Old 02-26-2018, 04:18 AM
lasse lasse is offline
Currently: Not set.
Basic Member
lasse has much to be proud oflasse has much to be proud oflasse has much to be proud oflasse has much to be proud oflasse has much to be proud oflasse has much to be proud oflasse has much to be proud oflasse has much to be proud oflasse has much to be proud oflasse has much to be proud oflasse has much to be proud of
Question Oil Injection delete/elimination... ?
I have done a Oil Injection delete/elimination on wife's Crossfire since the oil pump not working satisfactory.
But something does not seems to be ok when the Engine is running.
I have filled the space where the water pump shaft is with oil and mounted a small oil reservoir instead of the large bulky one.
But as soon as I start the engine, It starts to consume oil from the oil reservoir and the level drops
and the engine smoke like crazy.
Is not the space where the water pump's shaft sits sealed against the crankcases ?
Or do the crank have a bad seal against the waterpump shaft space so the oil just leaks through ?
Rate this post: Yes | No
  #2
Old 02-26-2018, 06:03 AM
kiliki kiliki is online now
Currently: Not set.
kiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond repute
Garage
Default
each side has a ring with a split in it and the oil will pass.
use the BDX oil delete and just put 10 pumps of grease in it every 500 miles or so. I cut a hole in the belly pan and use the rubber plug from the center of the intake plenum mounted under the hood and cover the hole under the hood with heat tape. lay it on the side take the plug out pull the bolt from the center of the case and add grease, put plug and bolt back it. takes 5 min
The Following User Says Thank You to kiliki For This Useful Post:
Reeb (02-26-2018)
  #3
Old 02-26-2018, 01:40 PM
Currently: Not set.
Basic Member
Question
Quote:
Originally Posted by kiliki View Post
Each side has a ring with a split in it and the oil will pass.
I do not understand what you mean, can you develop your answer ?
According to the exploded view, there is a crank seal on each side of the water pump shaft.
This should mean that the space is sealed to the respective crankcase.
# 20 ( Middle Crank Seal , # 3005-597 )
Click image for larger version
Name:	1 vevaxel moddad 2.jpg
  #4
Old 02-26-2018, 01:57 PM
Currently: Not set.
Basic Member
Question
This is what I have done....
I have used a oil injection delete bottle from Rotax ( very small ).
I have connected one hose to the block off plate,
and the other one to the lowest point under the engine.
The pictures below are quite self-explanatory.
FYI: The Pictures are not from wife's sled !!
I just posted them so you all got an idea what I have done.
ID:	293618   Click image for larger version
ID:	293619   Click image for larger version
ID:	293621   Click image for larger version
  #5
Old 02-27-2018, 12:06 AM
Thunder101 Thunder101 is offline
Currently: making room in the garage :)
Thunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond reputeThunder101 has a reputation beyond repute
Default
I have not had any troubles deleting the oil pump on these engines (800cc). I run 32:1 and ride it. Don’t bother with grease or a drip set up. Just ride it. It will be fine, oil gets in there !
  #6
Old 02-27-2018, 07:03 AM
Currently: Not set.
Garage
Default
look at your #20 it is metal and number 18 rides around it. so not a complete seal.
you can do as thunder101 states but i add the grease just for extra lube
  #7
Old 03-01-2018, 07:02 PM
Currently: Not set.
Basic Member
Question
look at your #20 it is metal and #18 rides around it.
So not a complete seal.
Please explain this in detail !
Pictures ?
Name:	Vevaxel detalj.jpg
  #8
Old 03-01-2018, 07:14 PM
Currently: Not set.
Garage
Default
https://www.ebay.com/itm/ARCTIC-CAT-...NYNeAT&vxp=mtr
Look at picture number 5.
the rings come installed with the split one in the 12 o'clock and one at 6.
even tho they are label "seal" the are not a complete seal. the factory pumps oil into this location and if it was a true seal it would fill up in just one run.
  #9
Old 11-18-2018, 11:53 AM
2006sigouin 2006sigouin is offline
Currently: Not set.
Basic Member
2006sigouin has a reputation beyond repute2006sigouin has a reputation beyond repute2006sigouin has a reputation beyond repute2006sigouin has a reputation beyond repute2006sigouin has a reputation beyond repute2006sigouin has a reputation beyond repute2006sigouin has a reputation beyond repute2006sigouin has a reputation beyond repute2006sigouin has a reputation beyond repute2006sigouin has a reputation beyond repute2006sigouin has a reputation beyond repute
Default
I was about To do thé same thing .....did you figure it out ? The rév delete kit was Perfect solution but if it bypass too much in th lay down Suzuki engine all just continué To put grease .....
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Oil injection elimination kits?? Thread Starter — jr_ddix Forum — Arctic Cat: Proclimb M Replies — 8 Last Post — 03-19-2012 03:50 PM
Thread — Anyone ever heard of this BDX Oil Injection Elimination Kit? Thread Starter — FCR112 Forum — Arctic Cat: M Series Replies — 18 Last Post — 10-25-2010 10:26 PM
Thread — injection oil delete/mixing fuel+oil? Thread Starter — venom1000 Forum — Arctic Cat: TURBO Replies — 0 Last Post — 11-14-2009 05:21 PM
Thread — Wanted... 440 mod zx, oil injection delete braket mpem, and bracket for oil canister. Thread Starter — jbsumbc Forum — Misc. Sled Parts Replies — 0 Last Post — 01-11-2009 11:48 PM
Thread — 900RMK Oil Injection Elimination?? Thread Starter — AaronBND Forum — Polaris Replies — 1 Last Post — 11-26-2008 04:59 PM
no new posts
