Upgrade to Premium
Reply
  #1
Old 02-25-2018, 12:24 PM
Nickhagen1 Nickhagen1 is offline
Currently: Not set.
Basic Member
Nickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud of
Default Clutch weights for evo 210 tune
Finally went with the evo 210 tune.
Just curious if I will need to clutch my primary now that more useable power is available. Thinking about mds or cutler TM weights. Also, what springs are people running and will I benefit from a tpi 911 cover and or abc kit? How about the spider, should I change that while I am in there?
Sled is a 2014, M9000. I ride normally around 1000ft of elevation but I will be in the mountains someday.
Thanks for any help!
Nick
Rate this post: Yes | No
  #2
Old 02-25-2018, 01:04 PM
0neoldfart 0neoldfart is offline
Currently: rigging instad of riding
0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute
Default
Nick
I like MDS weights - thinking you will end up around 91-92g, loaded at the tip. Running at 6-8000' I'm using a Polaris black (100/300) spring, you may want to ask Steve at MDS what would be good for your weight and elevation.
Thunder Products 911 cover is on every sled I own, way stronger then the stock covers, I also use their spider on my boosted M1100, but maybe not essential with a 210 flash. If you PM Racin Station on here, he can likely provide a very good setup, as he also deals with MDS weights...
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #3
Old 02-25-2018, 05:30 PM
Currently: Not set.
Basic Member
Default
I really appreciate the help!
I’m pm’ing racing station as I speak!
  #4
Old 02-26-2018, 09:22 AM
8secolds 8secolds is offline
Currently: Not set.
Basic Member
8secolds has a reputation beyond repute8secolds has a reputation beyond repute8secolds has a reputation beyond repute8secolds has a reputation beyond repute8secolds has a reputation beyond repute8secolds has a reputation beyond repute8secolds has a reputation beyond repute8secolds has a reputation beyond repute8secolds has a reputation beyond repute8secolds has a reputation beyond repute8secolds has a reputation beyond repute
Default
MDS Fat Cat weights work great on these sleds.
  #5
Old 03-01-2018, 05:09 PM
Currently: Not set.
Basic Member
Default FIRST START UP???🤨
Started sled up and everything was great. After warmup, sled stuttered and then rpm picked up rpm but not overly impressed on first fire up. Throttle response is quick and idle is much smoother but it still stutters here and there.
Plugs? Fuel filter is fairly new and fuel is not full.
Any ideas???
  #6
Old 03-01-2018, 06:53 PM
Default
Any ideas???
Change your plugs. Also, don't blip the throttle when cold - you have a bit more timing advance with the reflash, it'll stutter a bit when cold. Nothing to worry about. Think of it as a car that you've added a hotter cam to. I'd run a set of NGK CR9E plugs gapped to .020".
  #7
Old 03-01-2018, 07:51 PM
Currently: Not set.
Basic Member
Default Worried at first!!
Quote:
Much appreciated! I guess I never took into account the timing advance. I bought the plugs you mentioned and Iíll be installing them tonight. Would a splash of race gas hurt? I guess itís a dumb question but I can get 110 other wise itís 91/eth free mixing with the oldish fuel. Where Iím at snow is deminishing fast due to Al Gores theory so its kinda frustrating. Iíll be heading north soon. They still got a couple feet.
Whatís the next mod? I spoke with a rep from evo, he said stock weights are good for a 210 flash. Exhaust is straight pipe, intake is in the mail, just turbo mouthpiece for now, adjustable fuel regulator. I think Iím going to crank it up a little, maybe 45 to 50 psi. Driveline upgrades next?? Narrow a arms? Skis? All these things matter but Iím not sure where to go. I actually got this thing in some good snow this year and I fell in love all over again, I want to keep
  #8
Old 03-02-2018, 09:54 AM
Default My thoughts...
Leave the fuel pressure stock, that's what the flash was intended for. Straight 91 is good, race fuel won't help, will actually make it harder to start. Polaris gripper skis work really well, the 2016 front end changes the sled completely. With the new found power, plan on replacing the engine mounts at some point - I use OSP's urethane units, way stiffer. If you can live without reverse, a hyvo chain conversion is a good way to lose weight and strengthen a weak point, and a bit less money then a belt drive (which also works great).
The Following User Says Thank You to 0neoldfart For This Useful Post:
Nickhagen1 (03-02-2018)
  #9
Old 03-10-2018, 12:50 PM
BD-Xtreme's Avatar
BD-Xtreme BD-Xtreme is offline
Currently: Not set.
BD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond reputeBD-Xtreme has a reputation beyond repute
Default clutching
We have a really good clutch setup for that tune for the 2014. We have our adjustable weights for them for only $129.95 per set. Or our whole clutch kit, which includes or torsion spring conversion helix. Converting to the torsion spring allows the clutch to shift out further for more track speed. It also makes the driven clutch run about 40 degrees cooler, and really extends belt life big time!
http://www.bd-xtreme.com/index.php?i...roller=product
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — evo tune switch w/ launch control Thread Starter — f7firecatkid Forum — Turbos/Superchargers (Swapmeet) Replies — 1 Last Post — 01-29-2016 11:17 PM
Thread — evo tune switch w/ launch control Thread Starter — f7firecatkid Forum — Gauges/Instrumentation (Swapmeet) Replies — 0 Last Post — 01-02-2016 02:24 PM
Thread — evo tune switch w/ launch control Thread Starter — f7firecatkid Forum — Engine/Engine Parts (Swapmeet) Replies — 0 Last Post — 01-02-2016 02:21 PM
Thread — Team clutch review 275 evo kit. MDS weights. Thread Starter — HCM Forum — Arctic Cat: 1100 ProClimb Replies — 5 Last Post — 02-03-2013 09:30 AM
Thread — Tied Team clutch w/ 215 Evo, and MDS weights Thread Starter — cattracks Forum — Arctic Cat: 1100 ProClimb Replies — 4 Last Post — 12-15-2012 06:35 PM
no new posts
