Upgrade to Premium
Reply
  #1
Old 02-25-2018, 10:58 AM
HANDSOME HANDSOME is offline
Currently: Not set.
HANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond reputeHANDSOME has a reputation beyond repute
Default Removing brake pads on an xm
My son cant seem to get the bolt or pin out that holds the pads in place. It threads out 1/4 inch and acts like it is stripped. Its loose but wont come out. Any ideas ?
Rate this post: Yes | No
  #2
Old 02-26-2018, 01:35 PM
winter brew's Avatar
winter brew winter brew is offline
Currently: Not set.
winter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond repute
Default
There is a small hitch pin on the inside lip of the bolt that must be removed (needlenose pliers) before removing the bolt/pin that retains the pads. Once that is removed the bolt should thread out about 1/2" and can then be removed.
Bolt will need to be threaded back in to remove the small hitch pin...if that makes sense?
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to winter brew For This Useful Post:
HANDSOME (03-05-2018)
  #3
Old 03-05-2018, 05:53 PM
Currently: Not set.
Default
Thanks Winter !
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Mototrax brake pads Thread Starter — Rider1999 Forum — Snow bikes Replies — 3 Last Post — 04-03-2017 05:13 PM
Thread — New Brake Pads Thread Starter — Euc51 Forum — Snow bikes Replies — 2 Last Post — 01-20-2016 11:10 PM
Thread — Brake pads Thread Starter — Qube90 Forum — Polaris: Pro-Ride Replies — 6 Last Post — 10-01-2013 02:10 PM
Thread — Brake pads for Nitro Thread Starter — Artic Cat Forum — WTB (Swapmeet) Replies — 0 Last Post — 02-14-2010 09:13 PM
Thread — F/S AC Wave Brake Rotor with brake pads Thread Starter — Matt Westendorf Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 0 Last Post — 03-02-2008 05:35 PM
no new posts
