Upgrade to Premium
Reply
  #1
Old 02-20-2018, 10:07 PM
summit800 summit800 is offline
Currently: premium member
summit800 has a reputation beyond reputesummit800 has a reputation beyond reputesummit800 has a reputation beyond reputesummit800 has a reputation beyond reputesummit800 has a reputation beyond reputesummit800 has a reputation beyond reputesummit800 has a reputation beyond reputesummit800 has a reputation beyond reputesummit800 has a reputation beyond reputesummit800 has a reputation beyond reputesummit800 has a reputation beyond repute
Default 2015 800 Summit X
What is it suppose to idle at, and how do you adjust it ? Mine seems to idle low 1200 rpm likes to die when switching to reverse
Rate this post: Yes | No
  #2
Old 02-21-2018, 03:44 PM
Lake Powell Lake Powell is offline
Currently: Not set.
Basic Member
Lake Powell has a reputation beyond reputeLake Powell has a reputation beyond reputeLake Powell has a reputation beyond reputeLake Powell has a reputation beyond reputeLake Powell has a reputation beyond reputeLake Powell has a reputation beyond reputeLake Powell has a reputation beyond reputeLake Powell has a reputation beyond reputeLake Powell has a reputation beyond reputeLake Powell has a reputation beyond reputeLake Powell has a reputation beyond repute
Default
Idle is 1200. Not sure there is a way to change it. Check your plugs to see if they need replacing.
  #3
Old 02-21-2018, 07:43 PM
Default
What do you check? What's the gap?, Heard a rumour about rotation or clocking?
  #4
Old 02-22-2018, 12:34 PM
Currently: Not set.
Basic Member
Default
You should be replacing the plugs every year if you summerized the sled using the computer. That fouls the plugs and they don't really clean up even riding hard. Do not remember the gap but typically the NGK's come with the correct gap but you should always double check. Owner's manual will have that info. I have a 2015 154x with 5800 miles so far and always put in new plugs every year along with cleaning the rav valves at least every year but sometimes twice a year depending on miles ridden. Fuel filter every second year depending on fuel and I only run 91 non ethanol and use BG Super Charge every time which keeps the carbon down, fuel system clean, and moisture out of the fuel. Sled runs flawlessly until either plugs are bad or valves get sticky. Always blow clutches out every ride and disassemble every 500 miles to clean and inspect. Only had to replace the arms and ramps once so far but always the spring every year. My bet is the plugs will cure your problem.
The Following User Says Thank You to Lake Powell For This Useful Post:
roadtech (10-23-2018)
  #5
winter brew's Avatar
winter brew winter brew is offline
Currently: Not set.
winter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond repute
Default
Loosen belt deflection to see if that is causing it to die going to reverse.
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #6
Old 02-22-2018, 12:36 PM
Currently: Not set.
Basic Member
Default
that is also a good place to check.
  #7
Old 02-22-2018, 04:07 PM
cubby's Avatar
cubby cubby is offline
Currently: Riding Atv's till the snow comes back
cubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond repute
Default
Never heard of fouled plugs after the summer storage before. I know I've never had a problem with any of mine before. If you buy the NGK plugs don't mess with the gap they come perfect
__________________
2016 T3 154"
2007 XRS 800 151" engine built by SHR
2013 Polaris 850xp
2015 Polaris 1000xp
2016 Polaris 170 RZR
Hold it pinned till you feel bad
  #8
Old 02-22-2018, 04:14 PM
Default
Thanks I'll check all, I bought it as a total sled with a bent tunnel , only 2 rides on it , And 1200 miles
  #9
Old 02-26-2018, 05:47 PM
Carp's Avatar
Carp Carp is online now
Currently: Paneling Out on my XM
Carp has a reputation beyond reputeCarp has a reputation beyond reputeCarp has a reputation beyond reputeCarp has a reputation beyond reputeCarp has a reputation beyond reputeCarp has a reputation beyond reputeCarp has a reputation beyond reputeCarp has a reputation beyond reputeCarp has a reputation beyond reputeCarp has a reputation beyond reputeCarp has a reputation beyond repute
Default
There was a software update for the sleds running rich more when cold if I remember. Might want to have that checked. Might cause it to stall when cold when hitting reverse. Also, put the 16 spark plugs in it.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2015 Summit SP 800 154--CO Thread Starter — Jreng87 Forum — Ski-Doo (Swapmeet) Replies — 0 Last Post — 01-26-2016 11:57 PM
Thread — 2015 Ski-Doo Summit X 800 174 T3 Thread Starter — copp96 Forum — Ski-Doo (Swapmeet) Replies — 0 Last Post — 12-18-2015 08:18 AM
Thread — 2015 Summit 800 X T3 163 Thread Starter — Decks4Sale Forum — Ski-Doo (Swapmeet) Replies — 2 Last Post — 09-15-2015 08:32 AM
Thread — 2015 Summit X 800 T3 174 Thread Starter — jgd Forum — Ski-Doo (Swapmeet) Replies — 6 Last Post — 09-05-2015 05:46 PM
Thread — 2015 SUMMIT X 800 T3 BLACK 163 Thread Starter — shreddingsugar Forum — Ski-Doo (Swapmeet) Replies — 3 Last Post — 03-30-2015 09:41 AM
no new posts
