Upgrade to Premium
Polaris: Pro-Ride 2010 and up, all models in the Pro-Ride chassis
Reply
  #1
Old 02-20-2018, 05:22 PM
429dhm 429dhm is online now
Currently: Not set.
429dhm has a reputation beyond repute429dhm has a reputation beyond repute429dhm has a reputation beyond repute429dhm has a reputation beyond repute429dhm has a reputation beyond repute429dhm has a reputation beyond repute429dhm has a reputation beyond repute429dhm has a reputation beyond repute429dhm has a reputation beyond repute429dhm has a reputation beyond repute429dhm has a reputation beyond repute
Default Max 8000 RPM with sled on the stand
I'm having a problem with my sled not revving past 8000 RPM (2012 PRO RMK 163).
I have the correct weights (Carls Clutch Kit) in for elevation, good compression (13.1 head), cleaned exhaust valves, injectors last season and changed the fuel filter.
Even if I put the sled on the stand it will not rev past 8000 rpm. I had the shop install a 280 track last season and never had a chance to ride it is the only thing that changed.
I would have thought it would over rev on the stand.
Thanks
__________________
2012 Retro Pro RMK 163
2015 PRO-X Switchback
2008-Dragon 700-155 SOLD
2010 Polaris RZR
2002 CRF450R
2012 KTM 300XC
Rate this post: Yes | No
  #2
Old 09-06-2018, 02:26 PM
Currently: Not set.
Default
Any info? Can it be a TPS issue?
__________________
2010 Polaris RZR
2002 CRF450R
2012 KTM 300XC
  #3
Old 09-07-2018, 09:28 PM
Murph's Avatar
Murph Murph is online now
Currently: Back in the mountains
Murph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond reputeMurph has a reputation beyond repute
Default
Miles on primary clutch? last time rebuilt? Weight bushings in good shape?
Because of the nature of torque sensing secondary clutch, sometimes you will not see full rpm because of lack of load.
Are you snapping throttle open or easing into the higher rpm load? Sometimes if you creep up on max rpm you will pull more when running on stand versus pinning the sled wide open.
With the current clutching setup that is installed, did you ever see 8200 rpm?
__________________
Missing Digit Motors-- Servicing your 2011-current ProRMKs in Truckee, CA
Truckee's source for BMFab,Camso Tracks, Indy Specialties, Lectron Carbs, Mountain Side Products, Mystik Oil, RAZE Motorsports, Speedcell and other fine snowmobile products
Speedcell Technologies-- Founding Member
Tahoe Nordic Search and Rescue-snowmobile team
Auburn Extreme Powersports--(530) 885-7105 My local Polaris Dealer
  #4
Old 09-12-2018, 09:32 AM
Currently: Not set.
Default
It has not been reaching past 8000 RPM since at rebuild around 1000 miles and that's about how many miles on the clutch as well.
I dived into the TPS and found the base voltage was very at 0.731V.
I adjusted it to 0.700V so will try again.
__________________
2010 Polaris RZR
2002 CRF450R
2012 KTM 300XC
  #5
Old 09-12-2018, 03:00 PM
Scott's Avatar
Scott Scott is offline
Currently: ACTIVELY defend your right to ride.
Polaris & Montana Moderator
Scott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond reputeScott has a reputation beyond repute
Garage
Default
What was it running last time on the snow?
Areas to check:
old clutch springs
primary clutch bushings
track tension
tps
fuel quality deteriorates over the summer
plugged exhaust or air intake (mice love nooks and crannies in the sleds)
__________________
OEM parts from Free Agent
Ambassador for:
FB & IG: Scott Stiegler
Honestly, Honey!!! The shop paid for these mods. They sponsor me now. Really!
Check out these cool products:
  #6
Old 09-12-2018, 04:44 PM
Currently: Not set.
Default
It didn’t run very well last season as well when it was on the snow. Clutches are off to Indy Speacialties for a rebuild, the last item I had to check was the TPS.
__________________
2010 Polaris RZR
2002 CRF450R
2012 KTM 300XC
  #7
Old 09-12-2018, 07:56 PM
mtncat1's Avatar
mtncat1 mtncat1 is online now
Currently: waiting for snow
mtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond repute
Default
don't run your sled on a track stand at full throttle it is not safe !!!
you probably won't see max rpm on a stand because the clutches are up shifting to fast due to no load on the track , do you tuning on the snow ,you will get better results
__________________
2013 163 X3 silber turbo,
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #8
Old 09-12-2018, 08:02 PM
89sandman's Avatar
89sandman 89sandman is online now
Currently: Meadow Muffin
89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute89sandman has a reputation beyond repute
Default
x3 you have to load the track...
2 out of 2 members found this post helpful. Rate this post: Yes | No
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — hour to get 8000 rpm? Thread Starter — thejo Forum — Arctic Cat: M Series Replies — 17 Last Post — 12-06-2012 06:55 PM
Thread — 2002 rmk stalls at 8000 rpm Thread Starter — 454racing Forum — Polaris: EDGE Replies — 2 Last Post — 02-04-2012 02:03 PM
Thread — XP 860 Surging at 7-8000 rpm Thread Starter — allrevsrule Forum — Ski-Doo Replies — 4 Last Post — 12-21-2009 11:48 PM
Thread — XP 860 Surging 7-8000 RPM Thread Starter — allrevsrule Forum — Ski-Doo: XP Sleds Replies — 22 Last Post — 12-06-2009 09:53 PM
Thread — XP 860 Surging 7-8000 RPM Thread Starter — allrevsrule Forum — Performance/Modified Replies — 0 Last Post — 12-05-2009 04:42 PM
no new posts
