Upgrade to Premium
Polaris: 900 05-06 Polaris RMK 900
Reply
  #1
Old 02-20-2018, 02:53 PM
mann1921 mann1921 is offline
Currently: Not set.
Basic Member
mann1921 has a reputation beyond reputemann1921 has a reputation beyond reputemann1921 has a reputation beyond reputemann1921 has a reputation beyond reputemann1921 has a reputation beyond reputemann1921 has a reputation beyond reputemann1921 has a reputation beyond reputemann1921 has a reputation beyond reputemann1921 has a reputation beyond reputemann1921 has a reputation beyond reputemann1921 has a reputation beyond repute
Default why is my rmk 900 bogging at 2600 rpm
2005 polaris rmk 900 I have pretty much replaced everything on it it seems like. It has new intake boots, reeds, cleaned throttle bodies, new stator, voltage regulator, new engine rebuild, new tps sensor, new exhaust sensor, new DET sensor. I have gone through the entire wiring harness checking wires and I have found nothing. Ive tried several different little knacks like TSS issues or clutch issues and it has gotten me no where and it still bogs super hard and won't rev over 2500 or 2600 rpms, it idles beautifully though. any help would be great
0 out of 1 members found this post helpful. Rate this post: Yes | No
  #2
Old 03-04-2018, 06:26 PM
uSoTiNy uSoTiNy is offline
Currently: Not set.
Basic Member
uSoTiNy has a reputation beyond reputeuSoTiNy has a reputation beyond reputeuSoTiNy has a reputation beyond reputeuSoTiNy has a reputation beyond reputeuSoTiNy has a reputation beyond reputeuSoTiNy has a reputation beyond reputeuSoTiNy has a reputation beyond reputeuSoTiNy has a reputation beyond reputeuSoTiNy has a reputation beyond reputeuSoTiNy has a reputation beyond reputeuSoTiNy has a reputation beyond repute
Default
Have you replaced the fuel filter or checked the fuel pressure? Did the sled sit for a long time without running? Has the TPS sensor been calibrated?
  #3
Old 03-04-2018, 07:12 PM
Currently: Not set.
Basic Member
Default
entire fuel system is new and the tps has been reset. I also tried refreshing the ecu and trying a different ecu and no change. My only idea is that the fuel pump isn't putting out enough pressure at full throttle or half throttle. It will idle fine but as soon as you rev up it drops out.
  #4
Old 03-04-2018, 07:35 PM
05900's Avatar
05900 05900 is offline
Currently: nā mauna o ka hau
05900 has a reputation beyond repute05900 has a reputation beyond repute05900 has a reputation beyond repute05900 has a reputation beyond repute05900 has a reputation beyond repute05900 has a reputation beyond repute05900 has a reputation beyond repute05900 has a reputation beyond repute05900 has a reputation beyond repute05900 has a reputation beyond repute05900 has a reputation beyond repute
Garage
Default
Check the fuel pressure...
06 was different,using same year ecu?
__________________
You might not see him in person, But he'll see you just the same..
  #5
Old 03-05-2018, 12:37 PM
Currently: Not set.
Basic Member
Default
yes the ecu is the same year i made sure of that. I will be checking fuel pressure but the first dealership said it was fine. The one it is at now says the tss is shorting out when you mess with the throttle and making the sled bog so thats getting replaced then they will retest fuel pressure throughout the range of throttle.
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to mann1921 For This Useful Post:
TecCrash (03-09-2018)
  #6
Old 03-13-2018, 08:53 AM
SixtySevenGT's Avatar
SixtySevenGT SixtySevenGT is offline
Currently: Building Sleds
SixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond repute
Default It actualy will go down the trail at 2500 RPM ?
Most Sleds the Clutch is barely engaged at 2500.
Do you have a broken Primary spring or other clutch issue ?
__________________
"Always Drink Upstream from the Herd"
  #7
Old 03-17-2018, 01:20 PM
Currently: Not set.
Basic Member
Default
clutches are fine. They arnt set to engage anyway until 3200-3500 which is what they do in reverse.
  #8
Old 03-19-2018, 09:29 AM
Currently: Not set.
Basic Member
Default
quick update. I have gotten it to rev perfectly in reverse but in forward its trying to get above 2600 but it isn't doing it yet. It will touch every now and then up at 3500 but it just bogs back down to an idle and then back to 2600.
  #9
Old 03-20-2018, 11:15 AM
Super Dave3's Avatar
Super Dave3 Super Dave3 is offline
Currently: Not set.
Super Dave3 has a reputation beyond reputeSuper Dave3 has a reputation beyond reputeSuper Dave3 has a reputation beyond reputeSuper Dave3 has a reputation beyond reputeSuper Dave3 has a reputation beyond reputeSuper Dave3 has a reputation beyond reputeSuper Dave3 has a reputation beyond reputeSuper Dave3 has a reputation beyond reputeSuper Dave3 has a reputation beyond reputeSuper Dave3 has a reputation beyond reputeSuper Dave3 has a reputation beyond repute
Default
Broken wire in the TPS harness.
__________________
HOLD MY BEER AND WATCH THIS $HIT
  #10
Old 03-20-2018, 07:53 PM
Currently: Not set.
Basic Member
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 900 RMK 159 bogging issues Thread Starter — burny_30 Forum — Polaris: 900 Replies — 6 Last Post — 03-07-2013 07:11 AM
Thread — bogging trying to engage clutch rmk 900 Thread Starter — leighto Forum — Polaris: 900 Replies — 1 Last Post — 01-17-2013 05:09 PM
Thread — 2010 800 RMK bogging above 7000 RPM? Thread Starter — WStilson Forum — Polaris: IQ Replies — 3 Last Post — 04-22-2011 10:12 AM
Thread — bogging and gauge turns offs 900 rmk Thread Starter — yukonwheeler1 Forum — Polaris: 900 Replies — 4 Last Post — 02-20-2011 11:27 AM
Thread — 05 900 RMK bogging Thread Starter — cr2nuts Forum — Performance/Modified Replies — 13 Last Post — 01-10-2010 01:34 AM
no new posts
