Upgrade to Premium
Reply
  #1
Old 02-19-2018, 09:11 PM
turbokitty11 turbokitty11 is offline
Currently: Not set.
Basic Member
turbokitty11 has a reputation beyond reputeturbokitty11 has a reputation beyond reputeturbokitty11 has a reputation beyond reputeturbokitty11 has a reputation beyond reputeturbokitty11 has a reputation beyond reputeturbokitty11 has a reputation beyond reputeturbokitty11 has a reputation beyond reputeturbokitty11 has a reputation beyond reputeturbokitty11 has a reputation beyond reputeturbokitty11 has a reputation beyond reputeturbokitty11 has a reputation beyond repute
Default 2012 m11000 Pop and started smoking
So I went for a ride the other day. Was running alright then went to pull a hill and it would sputter/pop also only pull 7400rpm. After a few time on the hill the last pull the sled made a pop(like a innercooler boot blew) but started oil smoking really bad. Also oil coming out of the exhaust. Any one have any ideas what could have happened?
Rate this post: Yes | No
  #2
Old 02-20-2018, 09:57 AM
izzni's Avatar
izzni izzni is online now
Currently: Improving the NS1 Gauge System
izzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond reputeizzni has a reputation beyond repute
Default
Sounds like the turbo **** the bed.
The pulling 7400 RPM is typical for a massive boost leak or no boost, and oil out the exhaust sounds like a seal in the turbo.
__________________
Deluxe Gauge Software Reflash
www.NextStageGauges.com
The Deluxe Gauge Software Reflash enhances the stock Arctic Cat gauge to correct odometer inaccuracies, allow engine coolant temp to be displayed, add data logging, and many other improvements.
  #3
Old 02-20-2018, 02:39 PM
Currently: Not set.
Basic Member
Default
Who offers turbos other then evopower sports?
  #4
Old 02-20-2018, 02:46 PM
izzni's Avatar
Default
Quote:
I would look around on HardcoreSledder.com. The 1100T has a strong contingent there, and you'd likely have a better chance of finding a used one. I personally would throw a used one at it.
__________________
  #5
Old 02-20-2018, 09:04 PM
Nickhagen1 Nickhagen1 is offline
Currently: Not set.
Basic Member
Nickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud of
Default
Most likely the turbo. I’ve personally been in a pickup when a turbo blows. Yes, two different applications but it’s that loud pop sound and oil out of the exhaust.
D&D racing sells a bigger turbo then stock but not sure on your application.
Hope this helps
  #6
Old 02-27-2018, 08:04 PM
Currently: Not set.
Basic Member
Default
Finally got to tear into it. The compressor wheel nut fell off.
  #7
Old 02-28-2018, 01:46 PM
spoon's Avatar
spoon spoon is offline
Currently: Might grow up one day, just not today
spoon has a reputation beyond reputespoon has a reputation beyond reputespoon has a reputation beyond reputespoon has a reputation beyond reputespoon has a reputation beyond reputespoon has a reputation beyond reputespoon has a reputation beyond reputespoon has a reputation beyond reputespoon has a reputation beyond reputespoon has a reputation beyond reputespoon has a reputation beyond repute
Default
Finally got to test into it. The compressor whe nut fell off.
Hope you found the nut. Dont just put it back on, turbo is now out of balance. Either replace turbo or send it for repair.
__________________
2013 PC800 153 LE, New Project!
TM1000 with 174x3" CE, Timbersled, PCV with Autotune and 3076 WTA Custom Turbo
12 RMK 600 (wifes sled but I like it too)
  #8
Old 03-01-2018, 02:44 PM
Currently: Not set.
Basic Member
Default
Quote:
Pretty sure the shaft snapped when the nut lodged itself into the wheel. So it’s done for.
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #9
Old 03-02-2018, 09:58 AM
8secolds 8secolds is offline
Currently: Not set.
Basic Member
8secolds has a reputation beyond repute8secolds has a reputation beyond repute8secolds has a reputation beyond repute8secolds has a reputation beyond repute8secolds has a reputation beyond repute8secolds has a reputation beyond repute8secolds has a reputation beyond repute8secolds has a reputation beyond repute8secolds has a reputation beyond repute8secolds has a reputation beyond repute8secolds has a reputation beyond repute
Default
Did you find the nut? It could have gone into the engine if not.......
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2012 proclimb pop, under 1000 miles Thread Starter — astofooroff Forum — Arctic Cat: Proclimb M Replies — 5 Last Post — 02-07-2014 11:05 AM
Thread — 2012 Pro Rmk 155. Lot's of extras. 2yr warranty started april! Thread Starter — Destroyer Forum — Polaris (Swapmeet) Replies — 0 Last Post — 05-20-2012 08:59 AM
Thread — pop pop Thread Starter — CSCHERER Forum — Ski-Doo: TURBO Replies — 7 Last Post — 01-07-2012 05:05 PM
Thread — Does it just pop out? Thread Starter — POLZIN Forum — Polaris: Pro-Ride Replies — 5 Last Post — 10-19-2011 09:45 AM
Thread — Pop THIS!!!!!!!! Thread Starter — Scott Forum — Fouled Plug Replies — 34 Last Post — 09-05-2009 01:16 PM
no new posts
