Upgrade to Premium
Polaris: TURBO Turbo discussion for Polaris aftermarket turbo sleds
Reply
  #1
Old 02-19-2018, 04:51 PM
2005 1m 2005 1m is offline
Currently: Not set.
Basic Member
2005 1m has a reputation beyond repute2005 1m has a reputation beyond repute2005 1m has a reputation beyond repute2005 1m has a reputation beyond repute2005 1m has a reputation beyond repute2005 1m has a reputation beyond repute2005 1m has a reputation beyond repute2005 1m has a reputation beyond repute2005 1m has a reputation beyond repute2005 1m has a reputation beyond repute2005 1m has a reputation beyond repute
Default Silber bog coming off full boost
2016 Axys, Silber kit with quiet can, 7lb spring, mixing in 2-3 gals 110 race gas with 91 non eth per tank, roughly 9k-10k ft. roughly 700 miles on sled, 200 miles at most on the turbo.
The first few rides the sled ran flawlessly. Recently in the last ride and a half when I'm making full boost with the flapper clamped to the bars, then let off of the throttle all or most of the way, then go to get back on it the sled completely bogs for a good second and then comes back to life. It's sent me over the hood a couple times. Any guesses on what might be causing this or where to start looking? If I only ease off the throttle say half way (like a trail ride) it will dump the boost and not bog. It's only when it's an aggressive all to none (or very little) type of throttle action that causes this. Also, the intake vents were clear too. No other issues with the sled/turbo other than this all-to-no throttle bog.
Any help is appreciated.
Rate this post: Yes | No
  #2
Old 02-19-2018, 05:31 PM
aksledjunkie's Avatar
aksledjunkie aksledjunkie is offline
Currently: Payin' the dough to play in the snow
aksledjunkie has disabled reputation
Default
Are you in ETH mode?
__________________
Jeff Dennis Owner/Guide
Sled Alaska, LLC @aksledjunkie
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to aksledjunkie For This Useful Post:
2005 1m (02-20-2018)
  #3
Old 02-19-2018, 06:27 PM
rockin rmk's Avatar
rockin rmk rockin rmk is offline
Currently: working
rockin rmk has a reputation beyond reputerockin rmk has a reputation beyond reputerockin rmk has a reputation beyond reputerockin rmk has a reputation beyond reputerockin rmk has a reputation beyond reputerockin rmk has a reputation beyond reputerockin rmk has a reputation beyond reputerockin rmk has a reputation beyond reputerockin rmk has a reputation beyond reputerockin rmk has a reputation beyond reputerockin rmk has a reputation beyond repute
Default
Quote:
Should it be in ETH mode? Taking mine out for the first time this weekend.
__________________
16 Turbo Pro Axys 163
08 700 Dragon 163
07 600 RMK 155
87 Indy 400 136
  #4
Old 02-19-2018, 07:51 PM
562xp 562xp is online now
Currently: Montana
562xp has a reputation beyond repute562xp has a reputation beyond repute562xp has a reputation beyond repute562xp has a reputation beyond repute562xp has a reputation beyond repute562xp has a reputation beyond repute562xp has a reputation beyond repute562xp has a reputation beyond repute562xp has a reputation beyond repute562xp has a reputation beyond repute562xp has a reputation beyond repute
Default
Yes.
The Following 2 Users Say Thank You to 562xp For This Useful Post:
2005 1m (02-20-2018), rockin rmk (02-24-2018)
  #5
Old 02-19-2018, 07:53 PM
Sage Crusher's Avatar
Sage Crusher Sage Crusher is offline
Currently: Power Clawing the Axys....
Sage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond reputeSage Crusher has a reputation beyond repute
Default
How long ago did you purchase the turbo?
There is an ECU update that help situations when you are 'WOT' "Like after a good pull" back off the throttle and get back into it.. the update help with the slight bog issues that you had to feather the throttle to get the R's back up.
__________________
Dealers for:
Silber Turbos.
GGB Exhaust.
TKI.
F-N-I.
K-Mod.
2016 Axys 3" 162 P/C Track W/Silber Turbo/K-Mod Gen III/TKI
The Following User Says Thank You to Sage Crusher For This Useful Post:
  #6
Old 02-19-2018, 07:55 PM
Default
Quote:
Yes always run in the E 10 Eth mode- supposedly it gives 10% more fuel
__________________
Dealers for:
Silber Turbos.
GGB Exhaust.
TKI.
F-N-I.
K-Mod.
The Following 2 Users Say Thank You to Sage Crusher For This Useful Post:
  #7
Old 02-19-2018, 10:12 PM
sumtinwong sumtinwong is offline
Currently: Not set.
Basic Member
sumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond repute
Default
I have ben running in none ethanol? plugs look good and never hade a hiccup. should I change it?
  #8
Old 02-19-2018, 10:35 PM
Default
Yes, and don't forget about your clutching ...LOL!!
__________________
Dealers for:
Silber Turbos.
GGB Exhaust.
TKI.
F-N-I.
K-Mod.
  #9
Old 02-19-2018, 11:37 PM
Currently: Not set.
Basic Member
Default
I am not in Eth mode, I didn’t recall seeing that I was supposed to do this anywhere in the install instructions but I may have missed it. I’ll give it a shot. Thanks.
  #10
Old 02-19-2018, 11:38 PM
Currently: Not set.
Basic Member
  #11
Old 02-19-2018, 11:49 PM
snoballssnoglory's Avatar
snoballssnoglory snoballssnoglory is offline
Currently: Not set.
snoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond reputesnoballssnoglory has a reputation beyond repute
Click Here to Register
The Following User Says Thank You to snoballssnoglory For This Useful Post:
  #12
Old 02-20-2018, 09:57 AM
AKFULLTHROTTLE's Avatar
AKFULLTHROTTLE AKFULLTHROTTLE is online now
Currently: Waiting for my Polaris 850!
AKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond repute
The Following User Says Thank You to AKFULLTHROTTLE For This Useful Post:
  #13
Old 02-20-2018, 11:41 AM
LongHorn XC LongHorn XC is offline
Currently: Play Time is over, back to work
LongHorn XC has a reputation beyond reputeLongHorn XC has a reputation beyond reputeLongHorn XC has a reputation beyond reputeLongHorn XC has a reputation beyond reputeLongHorn XC has a reputation beyond reputeLongHorn XC has a reputation beyond reputeLongHorn XC has a reputation beyond reputeLongHorn XC has a reputation beyond reputeLongHorn XC has a reputation beyond reputeLongHorn XC has a reputation beyond reputeLongHorn XC has a reputation beyond repute
The Following User Says Thank You to LongHorn XC For This Useful Post:
  #14
Old 02-20-2018, 10:57 PM
rrjames's Avatar
rrjames rrjames is offline
Currently: Getting the Hind Lick Maneuver
rrjames has a reputation beyond reputerrjames has a reputation beyond reputerrjames has a reputation beyond reputerrjames has a reputation beyond reputerrjames has a reputation beyond reputerrjames has a reputation beyond reputerrjames has a reputation beyond reputerrjames has a reputation beyond reputerrjames has a reputation beyond reputerrjames has a reputation beyond reputerrjames has a reputation beyond repute
The Following User Says Thank You to rrjames For This Useful Post:
2005 1m (02-23-2018)
  #15
Old 02-21-2018, 09:52 AM
JJ_0909 JJ_0909 is online now
Currently: Not set.
JJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond repute
The Following User Says Thank You to JJ_0909 For This Useful Post:
  #16
Old 02-21-2018, 10:04 AM
assaulted-one assaulted-one is offline
Currently: waiting for snow
assaulted-one has a reputation beyond reputeassaulted-one has a reputation beyond reputeassaulted-one has a reputation beyond reputeassaulted-one has a reputation beyond reputeassaulted-one has a reputation beyond reputeassaulted-one has a reputation beyond reputeassaulted-one has a reputation beyond reputeassaulted-one has a reputation beyond reputeassaulted-one has a reputation beyond reputeassaulted-one has a reputation beyond reputeassaulted-one has a reputation beyond repute
The Following 2 Users Say Thank You to assaulted-one For This Useful Post:
2005 1m (02-23-2018), JJ_0909 (02-21-2018)
  #17
Old 02-21-2018, 08:09 PM
Angermangement890's Avatar
Angermangement890 Angermangement890 is offline
Currently: 146" RMK in progress
Angermangement890 has a reputation beyond reputeAngermangement890 has a reputation beyond reputeAngermangement890 has a reputation beyond reputeAngermangement890 has a reputation beyond reputeAngermangement890 has a reputation beyond reputeAngermangement890 has a reputation beyond reputeAngermangement890 has a reputation beyond reputeAngermangement890 has a reputation beyond reputeAngermangement890 has a reputation beyond reputeAngermangement890 has a reputation beyond reputeAngermangement890 has a reputation beyond repute
The Following User Says Thank You to Angermangement890 For This Useful Post:
  #18
Old 02-21-2018, 09:20 PM
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — When is the Quiet Can for the silber turbo coming out? Thread Starter — CO 2.0 Forum — Polaris: TURBO Replies — 19 Last Post — 09-21-2017 11:03 PM
Thread — silber wot bog Thread Starter — dcracer92 Forum — Polaris: TURBO Replies — 7 Last Post — 02-12-2013 07:26 PM
Thread — silber turbo bog help Thread Starter — R-rock Forum — Polaris: TURBO Replies — 28 Last Post — 02-05-2013 10:50 PM
Thread — full throttle bog Thread Starter — PaulAnd Forum — Polaris: IQ Replies — 7 Last Post — 03-16-2011 09:01 PM
Thread — FST Over-Boost or full boost update? Thread Starter — Gainster Forum — Polaris Replies — 8 Last Post — 04-10-2009 07:30 AM
no new posts
