Upgrade to Premium
Polaris: EDGE 2002-2005, all models in the Edge chassis
Reply
  #1
Old 02-19-2018, 01:15 AM
whoisthatguy's Avatar
whoisthatguy whoisthatguy is offline
Currently: Not set.
whoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond repute
Default ADDING REVERSE TO AN 02 RMK EDGE
Can you add reverse to an 02 RMK by changing the CDI box, CDI box wire harness, left handlebar controls and cylinder head to an 03,04 or 05 issue parts? I imagine that the speedometer that has the reverse light, could also be changed out. I noticed that the stator is exactly the same between an 02, 03, and 04. The only difference in engines between 02 and the 03 and 04, is the DET sensor in the cylinder head.
Rate this post: Yes | No
  #2
Old 02-19-2018, 09:18 AM
Skylane1978 Skylane1978 is online now
Currently: Not set.
Skylane1978 has a reputation beyond reputeSkylane1978 has a reputation beyond reputeSkylane1978 has a reputation beyond reputeSkylane1978 has a reputation beyond reputeSkylane1978 has a reputation beyond reputeSkylane1978 has a reputation beyond reputeSkylane1978 has a reputation beyond reputeSkylane1978 has a reputation beyond reputeSkylane1978 has a reputation beyond reputeSkylane1978 has a reputation beyond reputeSkylane1978 has a reputation beyond repute
Default
As I recall that would work. No head change needed, but oil pump would need to be from 03 or newer, the 02 doesn't pump oil in reverse as I recall.
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #3
Old 02-19-2018, 09:27 AM
Woodsrider Woodsrider is offline
Currently: if it's not broke your not done
Woodsrider has a reputation beyond reputeWoodsrider has a reputation beyond reputeWoodsrider has a reputation beyond reputeWoodsrider has a reputation beyond reputeWoodsrider has a reputation beyond reputeWoodsrider has a reputation beyond reputeWoodsrider has a reputation beyond reputeWoodsrider has a reputation beyond reputeWoodsrider has a reputation beyond reputeWoodsrider has a reputation beyond reputeWoodsrider has a reputation beyond repute
Default
Does your driven clutch have reverse helix?
  #4
Old 02-19-2018, 09:28 AM
WyoUltra's Avatar
WyoUltra WyoUltra is online now
Currently: Doing a snow dance.
WyoUltra has a reputation beyond reputeWyoUltra has a reputation beyond reputeWyoUltra has a reputation beyond reputeWyoUltra has a reputation beyond reputeWyoUltra has a reputation beyond reputeWyoUltra has a reputation beyond reputeWyoUltra has a reputation beyond reputeWyoUltra has a reputation beyond reputeWyoUltra has a reputation beyond reputeWyoUltra has a reputation beyond reputeWyoUltra has a reputation beyond repute
Garage
Default
If I remember correctly, you have to switch out the oil pump, a flywheel and a reverse style helix. I haven't done the PERC conversion, but looked it up a while back.
See this thread here.
  #5
Old 02-28-2018, 01:50 AM
this1ultraflyz's Avatar
this1ultraflyz this1ultraflyz is offline
Currently: Thinking about Revy Pow
this1ultraflyz has a reputation beyond reputethis1ultraflyz has a reputation beyond reputethis1ultraflyz has a reputation beyond reputethis1ultraflyz has a reputation beyond reputethis1ultraflyz has a reputation beyond reputethis1ultraflyz has a reputation beyond reputethis1ultraflyz has a reputation beyond reputethis1ultraflyz has a reputation beyond reputethis1ultraflyz has a reputation beyond reputethis1ultraflyz has a reputation beyond reputethis1ultraflyz has a reputation beyond repute
Default
Polaris used to have a kit. i installed on my 02 Edge 800 about 7 years ago. works perfectly never touched oil pump
Secondary Clutch, ECU, Complete Wiring harness, New Controls on left side handle bar with reverse button, Tach i think (Don't think it was speedo) .
  #6
Old 02-28-2018, 05:22 AM
Mark's RMK's Avatar
Mark's RMK Mark's RMK is online now
Currently: Not set.
Mark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond reputeMark's RMK has a reputation beyond repute
Default PERC
I've done several.
Team secondary with ER helix.
Change flywheel.
Change CDI
Need small CDI harness for PERC with connections to the handlebar PERC control.
Need the different handlebar control.
You can add a light in the tach to blink and this wiring comes from the different harness on the CDI.
__________________
2013 800 Pro RMK 155 ES, Burandt boards, Timbersled A-arms, NXT Level WS Bag, skid plate, VE belt guard, Team Tied Clutch, MTX wts, SLP Hot Air Eliminators, Mike Taylor Footwell Vents, Powder Keg tank/pack, Rox Flex Tec II Handguards.
Wife's Sled - 2012 Yamaha Apex XTX 144" EPS, Earth X battery, Yamaha Handguards, cable scratchers
2015 600 RMK 155, ES, skid plate, MTX wts
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — HOW TO: Adding Electronic Reverse - PICTURES* Thread Starter — AaronBND Forum — Arctic Cat: M Series Replies — 20 Last Post — 03-14-2013 06:19 PM
Thread — Adding reverse Thread Starter — rotax3006 Forum — Ski-Doo: REV Sleds Replies — 0 Last Post — 02-10-2010 11:39 AM
Thread — adding reverse Thread Starter — kvfrider Forum — Ski-Doo Replies — 17 Last Post — 11-17-2009 05:35 PM
Thread — adding mechanical reverse? Thread Starter — Beakjones Forum — Polaris: GEN 2 Replies — 5 Last Post — 11-02-2009 09:18 AM
Thread — Adding reverse? Thread Starter — rdr99 Forum — Arctic Cat: M Series Replies — 3 Last Post — 06-09-2009 04:34 PM
no new posts
