Upgrade to Premium
Polaris: TURBO Turbo discussion for Polaris aftermarket turbo sleds
Reply
  #1
Old 02-17-2018, 12:04 PM
Spiderman Spiderman is offline
Currently: Not set.
Spiderman has a reputation beyond reputeSpiderman has a reputation beyond reputeSpiderman has a reputation beyond reputeSpiderman has a reputation beyond reputeSpiderman has a reputation beyond reputeSpiderman has a reputation beyond reputeSpiderman has a reputation beyond reputeSpiderman has a reputation beyond reputeSpiderman has a reputation beyond reputeSpiderman has a reputation beyond reputeSpiderman has a reputation beyond repute
Default 2014 external silber turbo bog after warm start up
So the sled bogs after you are riding, take a break and then start back up...like heat soak. Only then, and not when cold. Blip the throttle quite a few times or some times roll into the throttle slowly and then it's fine. Has anybody cut that map sensor knipple back some so it's more in the air flow stream. Acting like its too lean or fat at that moment I'm thinking
Sent from my SM-G920V using Tapatalk
Rate this post: Yes | No
  #2
Old 02-19-2018, 04:18 PM
AKFULLTHROTTLE's Avatar
AKFULLTHROTTLE AKFULLTHROTTLE is offline
Currently: Waiting for my Polaris 850!
AKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond repute
Default
If you have a buddy to swap EGT sensors with try that. We have seen them cut back but I have seen no difference made. How many miles on reeds?
__________________
Full Throttle Customs
Alaska Silber Turbos Dealer
http://www.silberturbos.com/
  #3
Old 02-19-2018, 04:21 PM
aksledjunkie's Avatar
aksledjunkie aksledjunkie is offline
Currently: Payin' the dough to play in the snow
aksledjunkie has disabled reputation
Default
I cut mine back to test that theory, there was zero change in the sled. Myth busted.
__________________
Jeff Dennis Owner/Guide
Sled Alaska, LLC @aksledjunkie
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #4
Old 02-20-2018, 12:53 PM
roni87 roni87 is offline
Currently: Not set.
roni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond reputeroni87 has a reputation beyond repute
Default
I think that's just what they do. Mine and 3 other pro Re flash kits do that...just have to wait a couple seconds after restart.
I've heard that silber didn't change the warm restart function in the ecu which I guess adds fuel, that combined with larger injectors makes a rich start.
  #5
Old 02-22-2018, 09:58 AM
Currently: Not set.
Default
It's done it since I put the turbo on...it does seem fat, with no popping. Not changing the warm restart makes sense. Not a big deal and she runs great otherwise. Thanks for all the input!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2013 Polaris 800 - External Silber Turbo Thread Starter — dejoli Forum — Polaris (Swapmeet) Replies — 1 Last Post — 03-09-2017 05:29 PM
Thread — Powder Buggies Review | External Wastegate Silber Turbo – Polaris Thread Starter — AKFULLTHROTTLE Forum — Polaris: TURBO Replies — 18 Last Post — 10-21-2016 11:48 AM
Thread — 2015 silber turbo external for a pro Thread Starter — jerrydecoy Forum — Turbos/Superchargers (Swapmeet) Replies — 3 Last Post — 09-19-2016 07:34 AM
Thread — Demo SILBER turbo Axys kit (external waste gate) Thread Starter — Silber Forum — Turbos/Superchargers (Swapmeet) Replies — 0 Last Post — 05-20-2016 03:18 PM
Thread — 2014 Silber Turbo External Wastegate kit Pic. Thread Starter — Boston Racing Forum — Ski-Doo: TURBO Replies — 4 Last Post — 08-23-2014 01:09 PM
no new posts
