Upgrade to Premium
Polaris: EDGE 2002-2005, all models in the Edge chassis
Reply
  #1
Old 02-17-2018, 10:37 AM
Wantarmk Wantarmk is offline
Currently: Not set.
Basic Member
Wantarmk is an unknown quantity at this point
Default 600 swapped 440 pro out west clutching?
Main question i have a 02 prox 440 chasis swapped 600 wondering on the driven clutch helix will i be ok going to cook wyo. Current helix is 66-44-46, 70-46-36. Will it cause me problems or will it be good enough.? I believe this is the stock 440 helix. Drive clutch is all set with correct weights and spring for 6-9k feet. Gears are also per polaris spec for 6-9k .thanks
Rate this post: Yes | No
  #2
Old 02-17-2018, 07:57 PM
whoisthatguy's Avatar
whoisthatguy whoisthatguy is offline
Currently: Not set.
whoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond repute
Default
I would think that fine tuning springs only applies if you are intending on winding it out to maximum RPM, and getting top speed out of it.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — WE Needle on 08 dragon swapped to 11 Pro pita? Thread Starter — RexFlex23 Forum — Polaris: Pro-Ride Replies — 2 Last Post — 10-22-2014 10:37 AM
Thread — 04 sno pro 440 clutching Thread Starter — Bmoney Forum — Clutching Replies — 0 Last Post — 09-15-2010 11:56 AM
Thread — 2001 ZR 440 Sno-Pro jetting & clutching? Thread Starter — posrider Forum — Arctic Cat: 1M Replies — 2 Last Post — 01-05-2010 03:07 PM
Thread — Anybody swapped motors in an '01 sno pro? Thread Starter — smv sledhead Forum — Arctic Cat Replies — 3 Last Post — 04-01-2009 09:48 AM
Thread — 02 440 fan pro x clutching/jetting needed Thread Starter — rmkboxer Forum — Polaris Replies — 0 Last Post — 01-09-2008 10:34 PM
no new posts
