Upgrade to Premium
Reply
  #1
Old 02-16-2018, 08:15 PM
Nickhagen1 Nickhagen1 is offline
Currently: Not set.
Basic Member
Nickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud ofNickhagen1 has much to be proud of
Default Need help ideas!!!???
Took a good ride today with some buddies and sled ran great till about noon ish when I started noticing a few things.
1- started to spit and sputter. On take off and mid throttle. Not sure on plugs but sled has 2000 miles on it.
2- It seems like my sled eats way way to much fuel. My buddies doo and other buddies m8000 were like half of what I was at. Will the stock ecu adjust for a straight pipe exhaust or do I need to get a time for my elevation? Iím at 900 in Michigan. Do the tunes clean up mileage?
3- towards the end, my sled just felt like it had no power. Sure fuel was low and I am accounting for the low fuel stutter that these are known for but Iím just confused...
Anyone have any issue with the throttle position button in their handle? Mine went last year and it cause my sled to not run and I remember how jumpy and irractic the sled prior to it going and it was kinda of doing that like the last 30 mine.... idk, sure donít want to keep putting a new electronic throttle piece in my controls every year
Please help, thanks
Nick
Rate this post: Yes | No
  #2
Old 02-17-2018, 02:27 AM
Tmann Tmann is online now
Currently: Previously known as "Deadsled1"
Basic Member
Tmann has a reputation beyond reputeTmann has a reputation beyond reputeTmann has a reputation beyond reputeTmann has a reputation beyond reputeTmann has a reputation beyond reputeTmann has a reputation beyond reputeTmann has a reputation beyond reputeTmann has a reputation beyond reputeTmann has a reputation beyond reputeTmann has a reputation beyond reputeTmann has a reputation beyond repute
Default
What are you riding, is this fuel from last year and what else have you done besides TSS
  #3
Old 02-17-2018, 06:20 AM
Currently: Not set.
Basic Member
Default What I ride
Quote:
2014 M9000. Good fuel, 92 ethanol free, and just a straight pipe. Air filter mod, essentially just a straight intake..
  #4
Old 02-18-2018, 04:49 PM
0neoldfart 0neoldfart is online now
Currently: rigging instad of riding
0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute0neoldfart has a reputation beyond repute
Default Nick:
1 - Replace your fuel filter.
2 - Replace and gap your plugs
3 - with intake & exhaust mods, you're running lean. Get the ECU reflashed. I personally like EVO's products
4 - check intercooler piping, the clamps tend to loosen. T-bolt clamps are the way to go.
  #5
Old 02-19-2018, 08:14 AM
Currently: Not set.
Basic Member
Default
I appreciate the help. I’m sending ecu out this week. Hopefully the mileage will come back and I don’t go through so much gas!!
Why is plug gap so important? Just curious, I’d like a definitive answer, guess I never thought it made a difference.
Thanks again, nick
  #6
Old 02-19-2018, 08:32 AM
Default
Quote:
Originally Posted by Nickhagen1 View Post
I appreciate the help. Iím sending ecu out this week. Hopefully the mileage will come back and I donít go through so much gas!!
Why is plug gap so important? Just curious, Iíd like a definitive answer, guess I never thought it made a difference.
Thanks again, nick
Plug gap is essential, as flame out can (and does occur) under boost. I personally run NGK CR9E plugs gapped to .020" to resist flame out - I don't recommend regapping the iridium plugs. I don't know how many miles are on your sled, but a valve adjustment should be done at 5000 km, I did mine at 3500km and found two valves out of adjustment. If you have a boost leak (common with stock hoses and clamps), the sled will be sluggish and hard on fuel. T-bolt clamps hold torque better - 200 in/lbs (NOT ft/lbs) should ensure a good seal. The 1100 Suzuki is a great engine, but it does require periodic maintenance.
The Following User Says Thank You to 0neoldfart For This Useful Post:
Hotchief (02-19-2018)
  #7
Old 02-19-2018, 01:50 PM
Currently: Not set.
Basic Member
Default
I appreciate the help. I just went over 1800 miles on mine. I’ll check my hoses tonight. Just curious but do you run a stock fuel pressure regulator? Also, have you had any issues with the tss in your throttle control? I had an issue with mine last year sled wouldn’t stay running unless I played with that button and then it would only run wot... idk, great engine buts lots of bad engineering and stuff around it makes me feel like I bought the wrong machine
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Any ideas? Thread Starter — FrostBite2010 Forum — Arctic Cat: Proclimb M Replies — 4 Last Post — 06-27-2014 08:47 AM
Thread — any Ideas Thread Starter — Ultralord Forum — Yamaha (Swapmeet) Replies — 3 Last Post — 02-02-2013 09:45 AM
Thread — Looking for ideas? Thread Starter — Spyder73 Forum — Ski-Doo: REV Sleds Replies — 4 Last Post — 01-27-2013 10:26 PM
Thread — Any ideas? Thread Starter — NDFARMER95 Forum — Trucks and Trailers Replies — 1 Last Post — 04-22-2012 08:04 AM
no new posts
