Upgrade to Premium
Polaris: TURBO Turbo discussion for Polaris aftermarket turbo sleds
Reply
  #1
Old 02-15-2018, 08:41 PM
Rudy149 Rudy149 is offline
Currently: Not set.
Rudy149 has a reputation beyond reputeRudy149 has a reputation beyond reputeRudy149 has a reputation beyond reputeRudy149 has a reputation beyond reputeRudy149 has a reputation beyond reputeRudy149 has a reputation beyond reputeRudy149 has a reputation beyond reputeRudy149 has a reputation beyond reputeRudy149 has a reputation beyond reputeRudy149 has a reputation beyond reputeRudy149 has a reputation beyond repute
Default Must have parts once turbo added??
Not sure if this subject had been beat too death sorry if it has.
So I just added a sidekick turbo to my axys and have adjustable weights and ordered some venting for it and I know there has to be some more must have parts once running a turbo any input would be appreciated. Thanks
Rate this post: Yes | No
  #2
Old 02-15-2018, 10:06 PM
Dazzler's Avatar
Dazzler Dazzler is online now
Currently: Hobbling on crutches
Dazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond reputeDazzler has a reputation beyond repute
Default
Other than balls, the only issue I've had with the sidekick on my Axy is the exhaust is close to the pull rope and melted the rope about 4-6" from the handle..
  #3
Old 02-15-2018, 11:02 PM
goridedoo's Avatar
goridedoo goridedoo is online now
Currently: Not set.
goridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond reputegoridedoo has a reputation beyond repute
Default
Tool kit
The Following 2 Users Say Thank You to goridedoo For This Useful Post:
I8URCAT (02-16-2018), tmberro (02-21-2018)
  #4
Old 02-16-2018, 11:45 AM
2005 1m 2005 1m is offline
Currently: Not set.
Basic Member
2005 1m has a reputation beyond repute2005 1m has a reputation beyond repute2005 1m has a reputation beyond repute2005 1m has a reputation beyond repute2005 1m has a reputation beyond repute2005 1m has a reputation beyond repute2005 1m has a reputation beyond repute2005 1m has a reputation beyond repute2005 1m has a reputation beyond repute2005 1m has a reputation beyond repute2005 1m has a reputation beyond repute
Default
I'm running Silber but same conversation anyway... I haven't even added any venting and I'm beyond impressed with how pull & go it's been. I heat taped the coolant bottle to be safe along with the oil & coolant lines that run to the turbo. Otherwise that's it. I carry and extra belt (obviously) and drive belt with the tools but haven't had to add either yet. Knock on wood but I think all (or most) of the turbo MFRs really have these kits perfected.
It's worth checking your track to make sure it's fairly tight too to prevent any ratcheting.
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to 2005 1m For This Useful Post:
AKFULLTHROTTLE (02-16-2018)
  #5
Old 02-16-2018, 12:50 PM
Ron Burgandy's Avatar
Ron Burgandy Ron Burgandy is online now
Currently: Not set.
Ron Burgandy has a reputation beyond reputeRon Burgandy has a reputation beyond reputeRon Burgandy has a reputation beyond reputeRon Burgandy has a reputation beyond reputeRon Burgandy has a reputation beyond reputeRon Burgandy has a reputation beyond reputeRon Burgandy has a reputation beyond reputeRon Burgandy has a reputation beyond reputeRon Burgandy has a reputation beyond reputeRon Burgandy has a reputation beyond reputeRon Burgandy has a reputation beyond repute
Default
I don't have a turbo but have talked to quite a few owners, sounds like adding a blowhole substantially prolongs belt life.
The Following User Says Thank You to Ron Burgandy For This Useful Post:
Rudy149 (02-16-2018)
  #6
Old 02-16-2018, 01:22 PM
Teth-Air's Avatar
Teth-Air Teth-Air is offline
Currently: sourceinnovations.ca
Teth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond reputeTeth-Air has a reputation beyond repute
Default
You need a few parts from our online store, start with this one:
http://www.sourceinnovations.ca/prod...nsion-coupler/
__________________
Home of the "Cordless Teth-Air" and NEW "Laser Phantom Teth-Air"
We also have TKI Belt Drives, Arm Candy A-Arm Braces, Oil Tank Inserts, Reversible Scratchers, Polaris Suspension Couplers, Track Clips, Clutching and more.
The Following User Says Thank You to Teth-Air For This Useful Post:
  #7
Old 02-16-2018, 05:59 PM
HECKS's Avatar
HECKS HECKS is online now
Currently: Not set.
HECKS has a reputation beyond reputeHECKS has a reputation beyond reputeHECKS has a reputation beyond reputeHECKS has a reputation beyond reputeHECKS has a reputation beyond reputeHECKS has a reputation beyond reputeHECKS has a reputation beyond reputeHECKS has a reputation beyond reputeHECKS has a reputation beyond reputeHECKS has a reputation beyond reputeHECKS has a reputation beyond repute
Default
Y-pipe exhaust donuts ! I use to go through 3-4 a season. Carry a spare.
__________________
16' Axys 163 x 3 Powder Claw / Jaws Pipe/Can
The Following User Says Thank You to HECKS For This Useful Post:
  #8
Old 02-16-2018, 10:54 PM
A@ron A@ron is offline
Currently: still in da patch
A@ron has a brilliant futureA@ron has a brilliant futureA@ron has a brilliant futureA@ron has a brilliant futureA@ron has a brilliant futureA@ron has a brilliant futureA@ron has a brilliant futureA@ron has a brilliant futureA@ron has a brilliant futureA@ron has a brilliant futureA@ron has a brilliant future
Default
Quote:
along with good clutching
  #9
Old 02-17-2018, 01:32 PM
sumtinwong sumtinwong is offline
Currently: Not set.
Basic Member
sumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond repute
Default
when I put mine on I figured at a minim I needed clutching /venting/SLP torque arm and tether but I also added ice adage rail stiffeners {I walk on the tail a lot and didn't want the rails bending} avaid drivers and anti stab kit as I fought retching when it was NA. you will find lots of nay-sayers that will tell you things like get a "TOOL KIT" but most of them haven't tried a tuneless turbo! I have hade zero problems sense the silber turbo and it was installed right after break-in always starts and idles never stalls when I hit reverse to my amazement still haven't replaced a plug still on the original belt and no clutch rebuilds but I am do for some springs and the best part is that I make all the NA sleds look like a kids toy! if you don't like to wheelie you better consider a ARK system, aftermarket skid or some lock outs for the rear skid I have found it hard to keep the front down!
  #10
Old 02-17-2018, 02:31 PM
Dazzler's Avatar
  #11
Old 02-20-2018, 08:29 PM
Currently: Not set.
Click Here to Register
  #12
Old 02-21-2018, 09:38 AM
JJ_0909 JJ_0909 is offline
Currently: Not set.
JJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond repute
The Following 2 Users Say Thank You to JJ_0909 For This Useful Post:
cdebodt44 (02-23-2018), grizzslayer (03-19-2018)
  #13
Old 02-22-2018, 05:56 PM
jim jim is online now
Currently: Keyboard highmarking at its best.
jim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond repute
The Following User Says Thank You to jim For This Useful Post:
Rudy149 (02-22-2018)
  #14
Old 02-23-2018, 12:50 AM
colbypetersen colbypetersen is offline
Currently: Not set.
Basic Member
colbypetersen has a reputation beyond reputecolbypetersen has a reputation beyond reputecolbypetersen has a reputation beyond reputecolbypetersen has a reputation beyond reputecolbypetersen has a reputation beyond reputecolbypetersen has a reputation beyond reputecolbypetersen has a reputation beyond reputecolbypetersen has a reputation beyond reputecolbypetersen has a reputation beyond reputecolbypetersen has a reputation beyond reputecolbypetersen has a reputation beyond repute
  #15
Old 02-25-2018, 04:04 PM
Currently: Not set.
  #16
Old 02-25-2018, 08:15 PM
Seabass152 Seabass152 is online now
Currently: Not set.
Seabass152 has a reputation beyond reputeSeabass152 has a reputation beyond reputeSeabass152 has a reputation beyond reputeSeabass152 has a reputation beyond reputeSeabass152 has a reputation beyond reputeSeabass152 has a reputation beyond reputeSeabass152 has a reputation beyond reputeSeabass152 has a reputation beyond reputeSeabass152 has a reputation beyond reputeSeabass152 has a reputation beyond reputeSeabass152 has a reputation beyond repute
  #17
Old 03-09-2018, 07:09 PM
kelras kelras is online now
Currently: Not set.
Basic Member
kelras has a reputation beyond reputekelras has a reputation beyond reputekelras has a reputation beyond reputekelras has a reputation beyond reputekelras has a reputation beyond reputekelras has a reputation beyond reputekelras has a reputation beyond reputekelras has a reputation beyond reputekelras has a reputation beyond reputekelras has a reputation beyond reputekelras has a reputation beyond repute
The Following User Says Thank You to kelras For This Useful Post:
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Polaris parts for sale (more added) Thread Starter — Hardass Forum — Misc. Sled Parts Replies — 15 Last Post — 10-09-2011 06:16 PM
Thread — 2010 TURBO DRAGON - Pics added! $10,500 Thread Starter — SLDHVN Forum — Polaris (Swapmeet) Replies — 16 Last Post — 03-22-2011 10:58 AM
Thread — 09 rmk800 with BD turbo 95 miles (new pics added) Thread Starter — schmitt Forum — Polaris (Swapmeet) Replies — 21 Last Post — 08-17-2010 07:17 AM
Thread — Its garage sale time! more parts added 6-3-09 Thread Starter — FTXMOTORSPORTS Forum — Suspension/Shocks (Swapmeet) Replies — 0 Last Post — 06-03-2009 09:54 AM
no new posts
