Upgrade to Premium
Ski-Doo: XP Sleds 2007.5-current, all models in the XP, XT and XR chassis
Reply
  #1
Old 02-14-2018, 04:29 PM
chwkrx7 chwkrx7 is offline
Currently: Not set.
Basic Member
chwkrx7 is an unknown quantity at this point
Default 800R PTek Engine Failure
Hey guys, just had a meltdown on my 2007 Summit 800R engine (same as 08+ carb models) at 2600 miles. Was up in the mountains and it started popping and farting on me so I immediately turned back and made it back to my pickup. By the time I got there it was running very poorly and smoking like a freight train. Pulled the top end off and found this:
Funny thing was I couldn't find an evidence of what exactly was pounding around in the top end. Spark plugs were intact, all of the ring is still there, rave valves look good. Maybe it just leaned out? Could it be an oiling problem? Once I had the pistons off I poked around in the bottom end with a magnet and was picking up fine pieces of metal. So it looks like the engine is coming out of the sled.
I'm an automotive technician by trade but have never torn down/rebuilt a sled motor. I'm guessing I should be looking at a new crank/seals/pistons/head/cylinder replate? Also considering parting out the sled and calling it a season. Just curious what some of you more experienced guys would be doing in this situation.
Rate this post: Yes | No
  #2
Old 02-15-2018, 08:53 AM
cubby's Avatar
cubby cubby is offline
Currently: Riding Atv's till the snow comes back
cubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond repute
Default
Looks like the locating pin came out of the ring and hammered the head and piston. Might want to think about parting it out. I have an 07 xrs and I sent my motor off to Sledhead racing had him fix the case because 07's were famous for bad cranks, put in new crank and complete rebuild and it cost me about $1800. You on the other hand are going to need a head, cylinder, and then a complete rebuild, your looking at well over 2g for all that if you do the work. Post it here in the skidoo section sleds for sale and part it out is my thinking. You'll make some money on it and go buy a newer sled and enjoy. Let me know what kind of skis you have I'm looking for some for my 07
__________________
2016 T3 154"
2007 XRS 800 151" engine built by SHR
2013 Polaris 850xp
2015 Polaris 1000xp
2016 Polaris 170 RZR
Hold it pinned till you feel bad
  #3
Old 02-15-2018, 02:18 PM
Bendy Bendy is offline
Currently: Dooin the Snowdance
Bendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond reputeBendy has a reputation beyond repute
Default PTO side...
so I'm gonna call crank seal. Have you ever blown a belt so bad you had to pull the cords out from behind the clutch? Maybe cracked carb boot. I don't think the retaining pin can come out. Not unless it runs into an open port... but I don't think it does.
  #4
Old 02-15-2018, 08:49 PM
sledsrock sledsrock is offline
Currently: SUMMER SUCKS!
sledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond reputesledsrock has a reputation beyond repute
Default Beat down
That’s not a meltdown more of a beat down. Ferrous metal in the lower end, I’d be checking for a bearing coming apart.
  #5
Old 02-16-2018, 01:18 PM
winter brew's Avatar
winter brew winter brew is offline
Currently: Not set.
winter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond repute
Default
Check PTO runout
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — Skidoo XP 800R Ptek Check Engine Light with 3Beeps Thread Starter — newbb Forum — Ski-Doo: XP Sleds Replies — 5 Last Post — 12-02-2016 06:04 PM
Thread — 800r ptek head Thread Starter — idareyou Forum — Engine/Engine Parts (Swapmeet) Replies — 4 Last Post — 04-19-2016 09:00 AM
Thread — 800r PTek parts Thread Starter — jreed Forum — Carb/Airbox/Reeds (Swapmeet) Replies — 1 Last Post — 01-11-2013 09:45 PM
Thread — Xp Ptek 800r SLP can Thread Starter — Visi Forum — Pipes/Cans (Swapmeet) Replies — 1 Last Post — 08-26-2012 01:47 AM
Thread — 07 800r engine failure Thread Starter — skidoojames151 Forum — Ski-Doo Replies — 0 Last Post — 12-26-2007 10:42 PM
no new posts
