Upgrade to Premium
Polaris: 900 05-06 Polaris RMK 900
Reply
  #1
Old 02-14-2018, 03:40 PM
islandlake islandlake is offline
Currently: Not set.
Basic Member
islandlake is an unknown quantity at this point
Default 2006 RMK 700 - Lost
Hello. I tried reading through the posts for these machines but I am not smart enough to link all of the information together in my brain.My apologies.
2006 RMK 700. Purchase last year with about 2000 miles.Ran well all winter.Would not start in the fall.Pulled PTO plug and it was fouled with coolant/oil.
Figured blown gasket and started to work on repair. Eventually pulled motor.Probably a quart of coolant/oil in crankcase under PTO jug.MAG crankcase side was dry.Cleaned crankcase.Replaced base gaskets, put jugs back on crankcase, set engine back in sled, attached injectors, fuel rail, and then attached engine to sled.
Noticed that tags came off injectors. A little worried that these were not put back in the correct order.
When replacing the cover (I did replace the O rings), the last bolt partially stripped when under full torque. Backed it out, added Loctite and a washer, and reinstalled but stopped when tight (hoping it would not leak once Loctite set – allowed to set for 24 hours).
Engine started and idled fine. Took out for a brief 2-3 minute rip and it would not go over 40 mph.
Brought back inside. No coolant leaks.No obvious issues.One plug (PTO) looked good.The MAG plug was grey.Left for a day.
Then I tested compression (120 both jugs). Also bled the oil pump (opened set screw until oil dripped out).Noticed that a Bosch knock tester was not re-connected.No idea where to install this, so I just zip-tied it to the frame.
Started machine again. Started on second pull.Idled perfect.Ran down road.Same issue.Once 40 mph engine would bog and lose power.Turned around and back in shop.No clue what to do next.
Rate this post: Yes | No
  #2
Old 02-16-2018, 07:29 AM
uSoTiNy uSoTiNy is offline
Currently: Not set.
Basic Member
uSoTiNy has a reputation beyond reputeuSoTiNy has a reputation beyond reputeuSoTiNy has a reputation beyond reputeuSoTiNy has a reputation beyond reputeuSoTiNy has a reputation beyond reputeuSoTiNy has a reputation beyond reputeuSoTiNy has a reputation beyond reputeuSoTiNy has a reputation beyond reputeuSoTiNy has a reputation beyond reputeuSoTiNy has a reputation beyond reputeuSoTiNy has a reputation beyond repute
Default Mods please move post...Please post in proper forum
This is a forum for Polaris 900’s only.
#1 I think someone with more knowledge should be working on your snowmobile. Not trying to be an *** but it may save you money in the long run.
#2 just because there is no leaks outside your motor doesn’t mean there isn’t any inside.
#3 my guess is your head is warped but mainly you have to get that stripped bolt fixed.
Good luck
  #3
Old 02-22-2018, 09:54 AM
Currently: Not set.
Basic Member
Default Response
Sorry for delay. My buddy and I just saw your reply. No offense taken. In fact, we both laughed like hell. Very funny. And I totally agree with you. Still laughing. Will look at another big and pull head and check for warp. Then to a shop. Thanks!
  #4
Old 03-23-2018, 11:26 PM
guidoxpress's Avatar
guidoxpress guidoxpress is offline
Currently: Tearing up Alaskas BOMB POW
guidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond reputeguidoxpress has a reputation beyond repute
Garage
Default
The DET sensor (knock tester) bolts to the rear of the cylinder head, just below the small coolant line that goes to the water pump. It’s a PINA with motor in but doable. You can feel the threaded hole with ur finger. Literally dead center on rear Underneath
__________________
"Too much, is not enough"
3 2016 Polaris AXYS.
06 RMK 900
His and Hers 16 badass AXYS builds
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Parting out 2005 RMK 900 and 2006 RMK 700 Thread Starter — skidooman56 Forum — Misc. Sled Parts Replies — 2 Last Post — 10-23-2014 11:20 PM
Thread — 2005 RMK 900, 2006 RMK 700, and Sled Deck Thread Starter — rmk900sledhead Forum — Snowmobiles Replies — 0 Last Post — 02-24-2009 08:44 PM
Thread — 2008 RMK 700 VS Tree. Nosepan and A arm lost. Help! Thread Starter — snowbie Forum — Polaris Replies — 22 Last Post — 03-18-2008 09:47 AM
no new posts
