Upgrade to Premium
Youth Sleds Includes all Polaris Dragon/XC 120, Arctic Cat Z120, Ski-Doo Mini-Z, 340cc Polaris Indy Lights, Arctic Cat 340s, Yamaha Bravos, Yamaha Scoots / Sports
Reply
  #1
Old 02-12-2018, 10:01 PM
SpencerA SpencerA is offline
Currently: Not set.
SpencerA has a reputation beyond reputeSpencerA has a reputation beyond reputeSpencerA has a reputation beyond reputeSpencerA has a reputation beyond reputeSpencerA has a reputation beyond reputeSpencerA has a reputation beyond reputeSpencerA has a reputation beyond reputeSpencerA has a reputation beyond reputeSpencerA has a reputation beyond reputeSpencerA has a reputation beyond reputeSpencerA has a reputation beyond repute
Default 03 340 primary spring?
Oem blue and white engaged to high for my 8 year old. Tried gold and silver and super boggy now and can’t even get it up on trailer. Any ideas which spring to try?
Rate this post: Yes | No
  #2
Old 02-13-2018, 10:06 PM
RMK-King's Avatar
RMK-King RMK-King is offline
Currently: Not set.
RMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond repute
Default
You could try the Polaris black #7043120 60/340, just watch the peak RPM as that spring will add approx 300RPM. 2gram heavier weights will bring the RPM back down if needed. I can't imagine your 8yr old is going to be running wide open much anyways so peak rpm probably doesn't matter for now.
__________________
"Days get shorter,Snow gets deeper,Life gets better"
'19 Pro RMK 850- On order
'17 SB Assault 800
'16 SKS 800 2.6
  #3
Old 02-14-2018, 07:56 AM
Currently: Not set.
Default
Quote:
went back to oem set up. Have my 8 year old get used to high engagement.
  #4
Old 02-21-2018, 10:59 AM
Currently: Not set.
Default
Huge difference in performance with the lighter weights and stiffer spring. I did notice though the manual calls for a 8 and not 9 plug. PO had 9's, I read a previous post that said changing the plug made a big difference in their sled. What do you guys think? I'm going to put 8's in regardless but I didn't have a chance to test it.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — New SLP Primary Spring Blue/pink 140/340 Thread Starter — Sledhead800 Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 0 Last Post — 01-01-2014 10:55 AM
Thread — Need Spring Rate for Primary Spring Thread Starter — Reeb Forum — Ski-Doo: S-2000 and older Replies — 2 Last Post — 03-13-2010 12:39 AM
Thread — Help Need spring pressures on Cat Tit Primary Spring Thread Starter — plumnuts Forum — Arctic Cat: M Series Replies — 0 Last Post — 11-18-2009 08:04 PM
Thread — Polaris Black Spring 100-340 Thread Starter — Ski-Laxn Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 5 Last Post — 10-12-2008 02:56 PM
Thread — Wht is the spring rate for a cat yellow green primary spring? Thread Starter — cletus Forum — Arctic Cat Replies — 5 Last Post — 12-02-2007 09:33 PM
