Upgrade to Premium
Polaris: EDGE 2002-2005, all models in the Edge chassis
Reply
  #1
Old 02-12-2018, 09:50 PM
SpencerA SpencerA is offline
Currently: Not set.
SpencerA has a reputation beyond reputeSpencerA has a reputation beyond reputeSpencerA has a reputation beyond reputeSpencerA has a reputation beyond reputeSpencerA has a reputation beyond reputeSpencerA has a reputation beyond reputeSpencerA has a reputation beyond reputeSpencerA has a reputation beyond reputeSpencerA has a reputation beyond reputeSpencerA has a reputation beyond reputeSpencerA has a reputation beyond repute
Default 340 clutch issues
Just had my primary and secondary cleaned and rebuilt. Put on different spring because oem engaged to high rpm (blue and white) put gold and silver on. Now sled is real boggy. It will do ok on flats but hills it struggles. Obviously I need to try another spring. Any ideas?
Rate this post: Yes | No
  #2
Old 02-14-2018, 01:39 AM
BeartoothBaron BeartoothBaron is offline
Currently: Not set.
BeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond reputeBeartoothBaron has a reputation beyond repute
Default
Looks like the Silver/Gold spring is a much lighter spring (77-240) than the Dark Blue/White (120-310). That big a change is going to make it under-rev a lot and would explain the bogging. Engagement should be just before 4000 on that, but I don't have any references handy. I'd say the Gold spring (100-275) might do what you're looking for, but it could be other issues too. Is the belt in good shape and correct? With the belt and clutch spring removed, does the moving sheave slide in and out freely by hand? Finally, are the weights correct and in good shape?
  #3
Old 02-14-2018, 07:53 AM
Currently: Not set.
Default
Quote:
Clutch was inspected and rebuilt when I put new spring in. New belt and deflection in spec. Went back to oem spring and will probably just have him get used to it. My understanding is the 340s are supposed to rev high because they are under powered.
  #4
Old 02-14-2018, 02:23 PM
Currently: Not set.
Default
Just checked a couple of the manuals I've got, it looks like the old 340 (mid-90s) had the silver/gold spring you had in, but the microfiche for an EDGE 340 says 110-290 – doesn't give a color and doesn't match up with the springs listed in the manual I use. Looks closest to either the blue (120-300) or gold (100-275), but the dark blue/white is pretty close too.
If you can check peak RPM, that'll tell you what you need to know (I know a lot of these don't come with a tach). If peak RPM is off, then you'd definitely help yourself out getting it where it's supposed to be, especially with a 340. If you're going by ear, it's pretty hard to tell. I've heard of people who thought their engagement was sky-high, only to put a tach on and find it was in spec. I think that's partly an air-cooled thing, they make more noise idling and part throttle.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Help with Polaris TX 340 and TXL 340 Thread Starter — plumnuts Forum — Vintage Replies — 0 Last Post — 01-14-2018 09:23 PM
Thread — 340 clutch issues Thread Starter — SpencerA Forum — Youth Sleds Replies — 3 Last Post — 10-10-2017 05:28 PM
Thread — 2000 indy 340 motor issues Thread Starter — dizheafta Forum — Polaris: GEN 2 Replies — 2 Last Post — 01-03-2016 10:24 AM
Thread — 09 Clutch issues? New to XP clutch setup!! Thread Starter — Summit8 Forum — Ski-Doo: XP Sleds Replies — 19 Last Post — 03-15-2011 05:35 PM
Thread — Need help with clutch issues Thread Starter — hollywood2 Forum — Ski-Doo Replies — 1 Last Post — 04-14-2009 11:37 PM
no new posts
