Upgrade to Premium
Arctic Cat: 1M 2001-2005, all models in the Mountain Cat / 1M chassis
Reply
  #1
Old 02-11-2018, 08:57 AM
Jakelittle_3 Jakelittle_3 is offline
Currently: Not set.
Basic Member
Jakelittle_3 is an unknown quantity at this point
Angry 2004 Mountain Cat 900 EFI Fuel Issues???
Have a 2004 Mountain Cat 900 EFI that will not run more than 20 feet before it bogs out and dies. If I give it anything more then a 1/4 throttle it will die before it even moves. Sometimes it will start right back up and others times I can not get it to start without adding starting fluid to the air box. I have changed out the fuel pump, checked all my grounds, fuel pressure is 41 lbs @ the fuel rail, cleaned out the smart vales in the tank, had my injectors cleaned at the local arctic cat dealer. Have spark on both cylinders, changed out my servo. Have tried everything I can think of to get this sled to run but nothing has worked.. Any tips or ideas for me?
Current Sled Set up
1. SLP Single Pipe & Can
2. Boondocker Control Box with SLP recommended settings
3. RK Tech Torque-Line Head
4. V-Force 3 Reeds
Rate this post: Yes | No
  #2
Old 02-11-2018, 09:09 AM
Idcatman3's Avatar
Idcatman3 Idcatman3 is online now
Currently: Not set.
MODERATOR: Premium Member
Idcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond reputeIdcatman3 has a reputation beyond repute
Garage
Default
I'd pull the boondocker box off and try the sled for a minute or two to eliminate that as a source of error.
Sent from my VS987 using Tapatalk
__________________
Arctic Cat 1M and PS Moderator
'04 1M 1500 162" Challenger Extreme, M8 rear suspension, Custom jetting, clutching and gearing
  #3
Old 02-11-2018, 10:24 AM
kiliki kiliki is online now
Currently: Not set.
kiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond repute
Garage
Default
cut the wire to the throttle safety switch and put on a tether, or use a multi meter to test is.
  #4
Old 02-11-2018, 10:34 AM
Sledbrain2 Sledbrain2 is offline
Currently: Not set.
Basic Member
Sledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond reputeSledbrain2 has a reputation beyond repute
Default
Ground wire, I had issue with m1000, had spark when doing pull test, would start on occasion then die, or produce a large back fire, Turned out to be shorted out wire in the exhaust temp sensor, I know you do not have a exhaust sensor but I would check all connections for rubbed wires.
  #5
Old 02-11-2018, 10:40 AM
Currently: Not set.
Basic Member
Default
Another possibility, I know on my 02 800 efi mt cat I had the wires cracked right at the injector, the crack was real close to neck of connector, might be an area to see if it is large enough to cause a short.
  #6
Old 02-11-2018, 02:26 PM
Currently: Not set.
Basic Member
Default
Pulled the Boondocker box and had the same issue.
Pulled the TSS and that did not fix it either.
I changed the stator as I have read that being an issue on these sleds.
Nothing seems to help correct the issue.. Is there a "limp mode" on this sled? Almost acts like it goes into a limp mode and will not supply fuel any more. So I have to supply it through the air box with starting fluid
The Following User Says Thank You to Jakelittle_3 For This Useful Post:
Idcatman3 (02-11-2018)
  #7
Old 02-11-2018, 02:46 PM
Currently: Not set.
Garage
Default
Replace fuel pump. Also there is a screen on the uptake side on the fuel pump. At idle you might have good fuel pressure but not have enough flow for more rpm. You can use a 9v battery to run the pump in reverse to help flush it
  #8
Old 02-11-2018, 02:56 PM
Currently: Not set.
Basic Member
Default
I have already replaced the fuel pump.. Is there any way to track fuel pressure while I run it?
  #9
Old 02-11-2018, 03:43 PM
Currently: Not set.
Garage
Default
Your local hydraulic shop a t a 0 to 60 gauge and a foot piece of Hose hang the gauge outside the hood
The Following User Says Thank You to kiliki For This Useful Post:
Jakelittle_3 (02-11-2018)
  #10
Old 02-12-2018, 08:35 PM
Currently: Not set.
Basic Member
  #11
Old 02-18-2018, 07:33 AM
Currently: Not set.
Basic Member
Click Here to Register
  #12
Old 02-18-2018, 11:03 AM
Idcatman3's Avatar
Currently: Not set.
Garage
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2004 Arctic Cat 900 Mountain Cat EFI 159" Thread Starter — horn813 Forum — Arctic Cat (Swapmeet) Replies — 1 Last Post — 02-29-2012 12:49 PM
Thread — 2004 mountain cat 900 EFI 159" track Thread Starter — jjacobs Forum — Arctic Cat: 1M Replies — 4 Last Post — 01-15-2011 04:58 PM
Thread — 2004 900 EFI 1M Mountain Cat 159" track ($3,900.00) Thread Starter — Fryguy Forum — Arctic Cat (Swapmeet) Replies — 13 Last Post — 08-31-2009 10:25 PM
Thread — 2004 Mountain Cat 900 151" EFI Thread Starter — IowaSnowCat Forum — Arctic Cat (Swapmeet) Replies — 2 Last Post — 02-13-2009 01:19 PM
Thread — Turbo for 2004 Arctic cat mountain cat 900 efi Thread Starter — boondockerpro16 Forum — Performance/Modified Replies — 2 Last Post — 10-29-2008 01:43 PM
no new posts
