Upgrade to Premium
Polaris: EDGE 2002-2005, all models in the Edge chassis
Reply
  #1
Old 02-06-2018, 07:26 PM
11mudder 11mudder is offline
Currently: Not set.
11mudder is an unknown quantity at this point
Default 03 700 no tail light or brake light
Trying to figure out issue with no tail or brake light on a 03 700 rmk. All other lights work, including brake light on dash, bulb tests fine. I am seeing continuity between the brown and yellow at the connector under the seat and if I unplug the stator it goes away. Tested Yellow to Brown on stator and see .4 ohms, so that is out of range according to specs, so thinking possible issue there, but if that was the case wouldn't all lights be effected? Not seeing anything wiring wise yet going back to tail light, but need to dig more under the console. Thoughts on if it would be the stator or not since all lights but the back work? First time I have had a possible stator issue, so trying to make sure I am not replacing something that isn't the problem.
Rate this post: Yes | No
  #2
Old 02-07-2018, 12:43 AM
retiredpop retiredpop is offline
Currently: Not set
retiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond repute
Default
I'm sure it wouldn't be stator related. Do you see continuity at the connector under the seat looking back to the tail light on the brown and yellow? Similarly on the brown to orange (brake light). It sounds like the brown wire may be open under the seat or at the tail light housing itself seeing as how neither brake or tail light work. Brown is the common ground for both lights.
__________________
The older I get the better I was. In fact now that I think about it I'm a legend!
Haven't outgrown my 600 yet!
  #3
Old 02-07-2018, 06:19 PM
Currently: Not set.
Default
Traced the wiring back from the plug under the seat and didn’t see any bare wires, connected bulb to the connector at the back of the seat and worked there. So looked at the pigtail from there to the light and still nothing bare. Ended up being inside of the small connector at the back of the seat. Took it apart and resoldered wires and all is good. Guess I should have worked back instead of forward to begin with! Figured since I saw continuity at the front plug that is was something forward of the tank, guess it was just the resistance in the stator.
  #4
Old 02-08-2018, 12:12 AM
Currently: Not set
Default
Quote:
Yes you were seeing the resistance of the lighting coil in the stator.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Polaris Edge tail/brake light Thread Starter — matt Forum — Chassis/Tunnel (Swapmeet) Replies — 1 Last Post — 10-17-2010 07:17 PM
Thread — slp led tail/brake light Thread Starter — JoBoo Forum — Chassis/Tunnel (Swapmeet) Replies — 1 Last Post — 02-21-2010 05:18 PM
Thread — Tail light/brake light? Thread Starter — Redd Forum — Polaris: 900 Replies — 12 Last Post — 01-08-2010 05:13 PM
Thread — LED tail/ brake light Thread Starter — Vertical-Extreme Forum — General Snowmobiling Replies — 0 Last Post — 12-08-2008 12:01 PM
Thread — Wtb I Need Rmk Brake/tail Light For Edge!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Thread Starter — brnr17 Forum — WTB (Swapmeet) Replies — 4 Last Post — 12-18-2007 07:02 AM
no new posts
