Upgrade to Premium
Ski-Doo: XP Sleds 2007.5-current, all models in the XP, XT and XR chassis
Reply
  #1
Old 02-06-2018, 11:20 AM
sportfun sportfun is offline
Currently: Not set.
Basic Member
sportfun is an unknown quantity at this point
Default summit sport 800 not hitting hi rpm
i have a 2012 summit sport power tek 154 when i took my sled out for the first ride it ran like junk even with fuel stabilizer, finally got it running good but now when i rip across the field wide open it hits 8200-8300 rpm as it should but only for a couple minutes of riding then it doesnt go past 7000-7500 if i stop for a minute go again it hits the right rpm but only for a minute then drops back down i have tried changing my clutch weights lots but still only hits for a minute any idea what else this could be?
Rate this post: Yes | No
  #2
Old 02-06-2018, 10:04 PM
summit800 summit800 is offline
Currently: premium member
summit800 has a reputation beyond reputesummit800 has a reputation beyond reputesummit800 has a reputation beyond reputesummit800 has a reputation beyond reputesummit800 has a reputation beyond reputesummit800 has a reputation beyond reputesummit800 has a reputation beyond reputesummit800 has a reputation beyond reputesummit800 has a reputation beyond reputesummit800 has a reputation beyond reputesummit800 has a reputation beyond repute
Default
So it sounds like your over reving, is your belt adjusted right, what is your adjustable primary set at
  #3
Old 02-06-2018, 11:12 PM
Currently: Not set.
Basic Member
Default
my primary weights are set at 4 usually i ride on two around here but its not over reving on my 12 ptek peak power is 8200 little more then the etecs and once driving it only hits 7000-7500 so its under reving i was thinking possibly a fuel filter being plugged but not sure how to get to the fuel filter on that machine
  #4
Old 02-07-2018, 06:30 AM
Default
8200- 8300 is over should be 7900 , what does it do with clickers on 1 or 2
  #5
Old 02-07-2018, 09:41 AM
winter brew's Avatar
winter brew winter brew is offline
Currently: Not set.
winter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond repute
Default
Any chance it is getting hot? As coolant temps rise it will go into a fail-safe mode and cut power.
  #6
Old 02-07-2018, 08:38 PM
treeboy treeboy is offline
Currently: Not set.
Basic Member
treeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond repute
Default
Worn out primary spring, end force is too weak now.time for a new one.
  #7
Old 02-07-2018, 09:05 PM
Currently: Not set.
Basic Member
Default
I USUALLY run clickrers at 2 around home i have it on 4 right now and they all rev out around the 8200 and on my sled the sticker on the clutch cover says 8200 rpm its a ptek i know the etecs are 7900 i have a few friends with the etecs, and i dnt think it is over heating as it should be cooling when im driving in the powder. if the primary main spring was warn out would it work for a few minutes then back off? the other day when it dropped to 7400rp and would go any more i stopped with it idling for about 30 seconds then pinned it and it took off normally but same as usual it only lasted for about a minute then dropped again could this possibly be a lack of fuel not flowing fast enough
  #8
Old 02-08-2018, 05:50 AM
Default
How many miles on the sled, and you have burned a few tanks of fuel through it this season?
  #9
Old 02-09-2018, 12:39 AM
Currently: Not set.
Basic Member
Default
i have only burnt a tank throught it this year not even could it be bad fuel? i put fuel stabilizer in at the end of last year
  #10
Old 02-09-2018, 06:02 AM
  #11
Old 02-09-2018, 06:11 AM
Click Here to Register
  #12
Old 02-10-2018, 11:31 PM
Currently: Not set.
Basic Member
  #13
Old 02-11-2018, 07:26 PM
  #14
Old 02-12-2018, 12:16 PM
BBP BBP is offline
Currently: Not set.
Basic Member
BBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond reputeBBP has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread — summit sport 800 not hitting hi rpm Thread Starter — sportfun Forum — New Member Introductions Replies — 4 Last Post — 02-06-2018 11:30 AM
Thread — Only hitting 7860 RPM????? Thread Starter — Snowmaker10 Forum — Arctic Cat: M Series Replies — 28 Last Post — 01-09-2017 02:56 PM
Thread — 2010 M8 only hitting 6500 RPM Thread Starter — fj40 Forum — Arctic Cat: M Series Replies — 7 Last Post — 12-27-2013 04:56 PM
Thread — 2006 Summit X not hitting 8000 RPM's?? Thread Starter — MNT_SLED69 Forum — Ski-Doo: REV Sleds Replies — 4 Last Post — 02-19-2012 07:22 PM
Thread — m7 only hitting 72-7500 rpm ??? Thread Starter — Vern Forum — Arctic Cat Replies — 7 Last Post — 01-20-2008 11:02 PM
no new posts
