Upgrade to Premium
Trucks and Trailers Towing and hauling your sleds
Reply
  #1
Old 02-05-2018, 11:16 AM
GlennRMK GlennRMK is offline
Currently: Riding every chance I get
Basic Member
GlennRMK has a reputation beyond reputeGlennRMK has a reputation beyond reputeGlennRMK has a reputation beyond reputeGlennRMK has a reputation beyond reputeGlennRMK has a reputation beyond reputeGlennRMK has a reputation beyond reputeGlennRMK has a reputation beyond reputeGlennRMK has a reputation beyond reputeGlennRMK has a reputation beyond reputeGlennRMK has a reputation beyond reputeGlennRMK has a reputation beyond repute
Default Best trailer for 3 sleds and dirt bikes?
Curious on what everyone's thoughts are on this.
I had a 7x19 (front door and v nose) which only held 2 sleds.
Worked great for snow bikes and dirt bikes though. Towed real easy.
I would like to be able to hold 3 sleds but not drag around a huge heavy trailer which is way overkill for 3-5 dirt bikes. Going up to a steel deck over 8.5x19-21 makes 3 sleds easy but about doubles the trailer weight.
I have pulled an 8.5x16 deck over v nose sled trailer and it pulls a lot harder and blows around a bit more then my inline did, so I was thinking about an aluminum 7.5x19-21 or 7x21-23?
Can you fit 3 long tracks in a 7x21 or 7.5x19?
The aluminum inline trailers cost about the same as steel 8.5 deck overs and weigh almost half and pull a lot nicer.
I camp quite a bit in the summer and my concern with a 7x23 is the low ground clearance for forest service roads.
Maybe I'm dreaming and the best thing is a 8.5x21 for sleds and 7x12 for dirt bikes?
Pulling the trailer with 14 Ram 2500 Cummins, so weight/size isn't a huge concern to the truck but it sure is nice to get better fuel economy on long trips.
Rate this post: Yes | No
  #2
Old 02-05-2018, 11:22 AM
kiliki kiliki is online now
Currently: Not set.
kiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond repute
Garage
Default
I have a 8.5x16' on the square with a 7' V and you can fit 3 x 162" easy. the 7' V makes the trailer pull a lot better than the 4 or 5'V and you get better turning and unloading with the longer v. overall trailer is 23'
The Following User Says Thank You to kiliki For This Useful Post:
GlennRMK (02-05-2018)
  #3
Old 02-05-2018, 12:04 PM
Basic Member
Default
Quote:
Can you squeeze 4 sleds in it?
  #4
Old 02-05-2018, 12:07 PM
Currently: Not set.
Garage
Default
Only if 2 are 153 and 2 are 162. Very tight
  #5
Old 02-05-2018, 01:21 PM
Basic Member
Default
Thanks for the feedback!
I put 3 sleds in a deck over Charmac 18'x8.5'(12' box and 6' V) all the time. Just drove all three in the front door.
There was no comparison in how nice the 7x19 pulls compared to the 8.5x18 deckover. Hence I would like the low/mid deck.
The Mirage sport mid deck is real nice, but at $9000-10,000 I could buy a 6x12 cargo trailer and 8.5x19 deck over.
  #6
Old 02-05-2018, 07:40 PM
Griff Griff is offline
Currently: Not set.
Griff has a reputation beyond reputeGriff has a reputation beyond reputeGriff has a reputation beyond reputeGriff has a reputation beyond reputeGriff has a reputation beyond reputeGriff has a reputation beyond reputeGriff has a reputation beyond reputeGriff has a reputation beyond reputeGriff has a reputation beyond reputeGriff has a reputation beyond reputeGriff has a reputation beyond repute
Default
Good info here...I'll ask for more. I am looking at an 8' wide x 20' box with a 4' V. Is there any chance of getting 4 - 162 inch sleds in there? What about 2 - 162" and 2 - 155"? Want to go no longer than necessary for towing characteristics. Thanks.
__________________
Black Pearl Axys.
  #7
Old 02-05-2018, 08:02 PM
turbolover's Avatar
turbolover turbolover is offline
Currently: Working on the new/Old School Tow Rig.
turbolover has a reputation beyond reputeturbolover has a reputation beyond reputeturbolover has a reputation beyond reputeturbolover has a reputation beyond reputeturbolover has a reputation beyond reputeturbolover has a reputation beyond reputeturbolover has a reputation beyond reputeturbolover has a reputation beyond reputeturbolover has a reputation beyond reputeturbolover has a reputation beyond reputeturbolover has a reputation beyond repute
Garage
Default
Quote:
Tape it out on the garage floor and stack them in there. Pretty easy way to play tetris and see if they will fit.
__________________
14 800 Pro RMK 163
09 600 RMK 156
The Following User Says Thank You to turbolover For This Useful Post:
Griff (02-05-2018)
  #8
Old 02-05-2018, 08:09 PM
Currently: Not set.
Garage
Default
For sure 2 x162 and 2x155 and the 20+4 Is 1 foot longer i bet you could get 4x162. All have to be loaded from the front facing to the rear with the tails of the 2 in the v pushed together
Griff (02-05-2018)
  #9
Old 02-05-2018, 09:28 PM
gonehuntnpowder gonehuntnpowder is online now
Currently: Not set.
gonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond reputegonehuntnpowder has a reputation beyond repute
Default
Mine is a 7x20 on the box with a 5 ft v nose. 3 is easy. I have had a 174 and 3 163's in it several times. It's close, but they fit.
  #10
Old 02-08-2018, 12:05 PM
bradburck bradburck is offline
Currently: ready...
bradburck has a reputation beyond reputebradburck has a reputation beyond reputebradburck has a reputation beyond reputebradburck has a reputation beyond reputebradburck has a reputation beyond reputebradburck has a reputation beyond reputebradburck has a reputation beyond reputebradburck has a reputation beyond reputebradburck has a reputation beyond reputebradburck has a reputation beyond reputebradburck has a reputation beyond repute
The Following User Says Thank You to bradburck For This Useful Post:
GlennRMK (02-26-2018)
  #11
Old 02-15-2018, 11:09 AM
Basic Member
Click Here to Register
  #12
Old 02-17-2018, 11:59 PM
RMK-King's Avatar
RMK-King RMK-King is offline
Currently: Polaris Moderator
RMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond reputeRMK-King has a reputation beyond repute
The Following User Says Thank You to RMK-King For This Useful Post:
GlennRMK (02-18-2018)
  #13
Old 02-26-2018, 10:36 AM
Basic Member
  #14
Old 02-27-2018, 10:11 PM
AZ800 AZ800 is online now
Currently: Not set.
Basic Member
AZ800 has a reputation beyond reputeAZ800 has a reputation beyond reputeAZ800 has a reputation beyond reputeAZ800 has a reputation beyond reputeAZ800 has a reputation beyond reputeAZ800 has a reputation beyond reputeAZ800 has a reputation beyond reputeAZ800 has a reputation beyond reputeAZ800 has a reputation beyond reputeAZ800 has a reputation beyond reputeAZ800 has a reputation beyond repute
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Dirt bikes!!! Thread Starter — Dunatic Forum — Utah Replies — 23 Last Post — 04-25-2014 10:09 AM
Thread — anyone ride dirt bikes? Thread Starter — k_newman66 Forum — Utah Replies — 13 Last Post — 08-22-2011 04:44 PM
Thread — lets see your dirt bikes. Thread Starter — rmk 700 Forum — Fouled Plug Replies — 46 Last Post — 01-29-2010 11:29 PM
Thread — Dirt Bikes Thread Starter — The Boondock Saint Forum — Utah Replies — 36 Last Post — 08-25-2009 05:10 PM
Thread — Anybody using there deck for dirt bikes? Thread Starter — FriscoProx Forum — Trucks and Trailers Replies — 3 Last Post — 04-27-2009 11:46 PM
no new posts
