Upgrade to Premium
Trucks and Trailers Towing and hauling your sleds
Reply
  #1
Old 02-04-2018, 09:24 PM
DangerousDave's Avatar
DangerousDave DangerousDave is offline
Currently: Building a new sled deck...
DangerousDave has a reputation beyond reputeDangerousDave has a reputation beyond reputeDangerousDave has a reputation beyond reputeDangerousDave has a reputation beyond reputeDangerousDave has a reputation beyond reputeDangerousDave has a reputation beyond reputeDangerousDave has a reputation beyond reputeDangerousDave has a reputation beyond reputeDangerousDave has a reputation beyond reputeDangerousDave has a reputation beyond reputeDangerousDave has a reputation beyond repute
Default Sled deck build project...
There are lots of great sled decks out there, but I just like to build my own stuff. Here's my latest project, a custom year round deck to be used for work and recreation.
Here's a list of wants and needs.
1) Must look nice on the truck, like it's suppose to be there.
2) Must be robust, mounted to bed floor no damage to the truck.
3) Must allow bed rails to flex, but be sealed for dry storage
4) Concealed side extensions.
5) Needs to be able to haul 2 sleds or a side by side and still allow to pull a travel trailer.
6) Needs to be able to easily convert from sled deck use to accept a ladder / pipe rack (that doubles as a boat rack)
7) Slide out under deck storage for tools, gear, tailgating, large enough to carry 4x8 sheets
8) Telescoping ramp storage that slides ramp back far enough to hook right on the deck without having to wrestle with the ramp.
9) All aluminum, no wood on deck or under feet in bed.
Here are some pics of the progress so far.
I'd welcome any suggestions or critiques.
Click image for larger version
ID:	292589   Click image for larger version
ID:	292590   Click image for larger version
ID:	292592   Click image for larger version
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following 4 Users Say Thank You to DangerousDave For This Useful Post:
Cerialsledder (10-28-2018), H1Pilot (02-05-2018), ryanjeri (02-09-2018), warreng417 (02-05-2018)
  #2
Old 02-09-2018, 09:03 AM
warreng417 warreng417 is offline
Currently: Not set.
Basic Member
warreng417 has a reputation beyond reputewarreng417 has a reputation beyond reputewarreng417 has a reputation beyond reputewarreng417 has a reputation beyond reputewarreng417 has a reputation beyond reputewarreng417 has a reputation beyond reputewarreng417 has a reputation beyond reputewarreng417 has a reputation beyond reputewarreng417 has a reputation beyond reputewarreng417 has a reputation beyond reputewarreng417 has a reputation beyond repute
Default
Lookin good, Any more progress? What is the alum decking from? Looks like the stuff seen on marine docks.
  #3
Old 02-10-2018, 11:39 PM
Default
The aluminum decking was salvaged out of a delivery truck that flipped on its side last year in the snow.
I made a little progress today, welded the headache rack on. (The headache rack was a craigslist find)
Put the deck on the truck so I could layout the front of the side rails to match up with the bed and blend into the cab.
Made gaskets to seal it to the bed rails.
Bolted the super tracks to the outside of the extensions.
It's not ready to haul sleds yet but it's going to make a trip to Halfway Oregon later this week (I'm trailering the sleds)
In the pictures you can see the 4 reciever tubes, one in each corner to accept ladder racks, boat rack, and there will be an extension that drops in the back 2 to support the Sleds, SXS and the ramp.
I tried to maximize the under bed storage, you can see the channels that the bearings will ride in for a 4x8 slide out tray.
I'm thinking about covering the entire deck with Superglides.
Once it's done all the exposed aluminum will be polished.
ID:	292878   Click image for larger version
ID:	292879   Click image for larger version
3 out of 3 members found this post helpful. Rate this post: Yes | No
Clark42 (03-17-2018), fudge313 (02-11-2018), Long Gone (02-11-2018), warreng417 (02-12-2018)
  #4
Old 03-10-2018, 11:34 PM
Default
I’ve made a little more progress...
I built a piece that drops in to the rear receiver tubes when hauling sleds or the polaris ranger. It has a 2” tube on the back that the ramp will hook to. It also has a square tube farther forward that is spaced so the snowmobile track will straddle both tubes AND it’s laid out so the rear tires of the ranger drop between the 2 tubes.
I also started laying out the ramp. It will be 53” wide 11’ telescoping ramp with superglide “wide slides”. The bars that the track climbs up are 1 1/4” square tube spaced 14 5/16” apart. This spacing will allow a 2.86” pitch track to climb up the ramp without the lugs rolling over some of the bars.
ID:	294291   Click image for larger version
  #5
Old 03-13-2018, 04:43 PM
hughesfoundation hughesfoundation is online now
Currently: Not set.
Basic Member
hughesfoundation has a reputation beyond reputehughesfoundation has a reputation beyond reputehughesfoundation has a reputation beyond reputehughesfoundation has a reputation beyond reputehughesfoundation has a reputation beyond reputehughesfoundation has a reputation beyond reputehughesfoundation has a reputation beyond reputehughesfoundation has a reputation beyond reputehughesfoundation has a reputation beyond reputehughesfoundation has a reputation beyond reputehughesfoundation has a reputation beyond repute
Default
Where did you get the supertracs material for the outside of the bed?
  #6
Old 03-13-2018, 11:45 PM
Default
Quote:
I ordered the “L Track” airline track and a bunch of fitting attachments from USCC (US Cargo control)
I incorporated a 45 deg angle into the sides to keep the pull angle straight when using tie downs.
  #7
Old 03-14-2018, 08:24 AM
Currently: Not set.
Basic Member
Default
Thanks, great source. Can you post closeup of how you did the 45?
  #8
Old 03-14-2018, 03:50 PM
rhino89523 rhino89523 is online now
Currently: Not set.
Basic Member
rhino89523 has a reputation beyond reputerhino89523 has a reputation beyond reputerhino89523 has a reputation beyond reputerhino89523 has a reputation beyond reputerhino89523 has a reputation beyond reputerhino89523 has a reputation beyond reputerhino89523 has a reputation beyond reputerhino89523 has a reputation beyond reputerhino89523 has a reputation beyond reputerhino89523 has a reputation beyond reputerhino89523 has a reputation beyond repute
Default
DAM!!!! I can see with your skills why you like to build your own stuff. I have never seen a sled deck that appeared to be so much a part of the truck or that you would want to leave on year round. Your Ideas are killer. I have zero suggestions, that is a well thought out and executed project. Bravo!!!
2 out of 2 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to rhino89523 For This Useful Post:
DangerousDave (03-17-2018)
  #9
Old 03-17-2018, 10:58 PM
Default
Here’s a couple photos, one of the sketch when I was laying it out and one of how it turned out. I made the angle of the 2 1/2” outside rail match the angle of the truck cab then welded a 1 1/4” bar at an angle to give it some rigidity. I bolted the L Track on with stainless Allen head countersink bolts.
After further review it’s a bit less than 45 deg.
ID:	294539   Click image for larger version
  #10
Old 03-18-2018, 07:36 AM
High Voltage's Avatar
High Voltage High Voltage is online now
Currently: Helena MT who wants to go sledding?
High Voltage has a reputation beyond reputeHigh Voltage has a reputation beyond reputeHigh Voltage has a reputation beyond reputeHigh Voltage has a reputation beyond reputeHigh Voltage has a reputation beyond reputeHigh Voltage has a reputation beyond reputeHigh Voltage has a reputation beyond reputeHigh Voltage has a reputation beyond reputeHigh Voltage has a reputation beyond reputeHigh Voltage has a reputation beyond reputeHigh Voltage has a reputation beyond repute
  #11
Old 11-18-2018, 02:00 PM
Blueside Blueside is offline
Currently: Not set.
Blueside is an unknown quantity at this point
Click Here to Register
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2005 Arctic Cat M7 Project Sled - Build Thread Included Thread Starter — Phizzer Forum — Arctic Cat (Swapmeet) Replies — 16 Last Post — 03-01-2017 05:21 PM
Thread — Simply magical Sled build: PROJECT FUNSTIK Thread Starter — tudizzle Forum — General Snowmobiling Replies — 10 Last Post — 09-22-2014 08:44 AM
Thread — Sled build project questions Thread Starter — srt20 Forum — Polaris: IQ Replies — 6 Last Post — 12-13-2013 01:05 AM
Thread — My XCR 800 Mountain sled build project. Thread Starter — X2Freeride Forum — Polaris: GEN 2 Replies — 31 Last Post — 04-28-2012 09:56 PM
Thread — Summer Project: Lake sled build!!! Thread Starter — MountainTrashCat Forum — Member Sled Builds Replies — 6 Last Post — 05-31-2011 02:54 PM
no new posts
