Upgrade to Premium
Ski-Doo: XP Sleds 2007.5-current, all models in the XP, XT and XR chassis
Reply
  #1
Old 02-04-2018, 06:44 AM
cubby's Avatar
cubby cubby is offline
Currently: Riding Atv's till the snow comes back
cubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond repute
Default Looking for some help
Friends sled is a 08 xp 800 and has roughly 2800 miles on it. Took the carbs off 2 weeks ago and cleaned them all was good started and ran fine. Put it on the trailer and drove 450 miles to go sledding, got there and all was good, and rode all day. The next morning go to start it and it wouldn't start, pulled plugs and it was flooded bad, so with plugs out pulled over the motor, put plugs back in and it started and ran good all day. Next morning same thing, but this time with full choke and held throttle wide open a few pulls and it started and ran good all day. Now that were back home the check engine light is on and it is starting to run like crap, backfiring out the exhaust at idle. We take carbs back off to see if a float was hung up or something else and see nothing wrong in he carbs. Did a compression test and both cylinders are dead on at 124psi, not bad I thought. But still dumping fuel in the cylinders so badly that when it starts fuel comes out the pipe. Any ideas o what might have happened?
__________________
2016 T3 154"
2007 XRS 800 151" engine built by SHR
2013 Polaris 850xp
2015 Polaris 1000xp
2016 Polaris 170 RZR
Hold it pinned till you feel bad
Rate this post: Yes | No
  #2
Old 02-04-2018, 07:24 AM
stmike stmike is offline
Currently: Not set.
stmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond reputestmike has a reputation beyond repute
Default
Time for new needle and seats.
2 out of 2 members found this post helpful. Rate this post: Yes | No
  #3
Old 02-04-2018, 10:21 AM
cubby's Avatar
Default
Sounds like a good place to start. Also is there anyway of pulling codes on an 08?
__________________
2016 T3 154"
2013 Polaris 850xp
2015 Polaris 1000xp
  #4
Old 02-04-2018, 11:23 AM
dansvan dansvan is offline
Currently: Not set.
dansvan has a reputation beyond reputedansvan has a reputation beyond reputedansvan has a reputation beyond reputedansvan has a reputation beyond reputedansvan has a reputation beyond reputedansvan has a reputation beyond reputedansvan has a reputation beyond reputedansvan has a reputation beyond reputedansvan has a reputation beyond reputedansvan has a reputation beyond reputedansvan has a reputation beyond repute
Default
Check the vac line from block to fuel pump. See if it's got fuel inside.
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to dansvan For This Useful Post:
cubby (02-04-2018)
  #5
Old 02-04-2018, 11:57 AM
cubby's Avatar
Default
And if it does? Then what?
__________________
2016 T3 154"
2013 Polaris 850xp
2015 Polaris 1000xp
  #6
Old 02-04-2018, 12:23 PM
kiliki kiliki is online now
Currently: Not set.
kiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond repute
Garage
Default
then you rebuild the fuel pump. it has a diaphragm in it when they crack it will let fuel into the cases.
  #7
Old 02-04-2018, 01:29 PM
cubby's Avatar
Default
Alright thanks guys.
__________________
2016 T3 154"
2013 Polaris 850xp
2015 Polaris 1000xp
  #8
Old 03-13-2018, 04:23 PM
FEZ FEZ is offline
Currently: Mechanic for and Advisor to SHR
Basic Member
FEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond reputeFEZ has a reputation beyond repute
Default
Rarely do you need to replace the needle/seats. What fails is the O-ring for the seat assembly. When you remove the float assembly you will see the o-ring. It seals the seat to the carb. When this fails fuel sneaks by.
The o-ring cannot be bought separately from Doo, but can be from Cat. Call BJ @ SHR for the part #.
612.718.3861.
if you have already bought new, then you get the O-rings.
  #9
Old 03-14-2018, 06:58 AM
cubby's Avatar
Default
Replaced the O-rings and that fixed the problem, thanks everyone.
__________________
2016 T3 154"
2013 Polaris 850xp
2015 Polaris 1000xp
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
no new posts
