Upgrade to Premium
Ski-Doo: REV Gen 4 For the 2017 and newer REV Gen 4 Sleds
Reply
  #1
Old 02-01-2018, 05:33 PM
fredw fredw is offline
Currently: 850 blown up before Breakin over
Basic Member
fredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond repute
Default Cheap rear skid sag fix for G4
Been fighting the rear sag issue on the G4 but after talking with Rene st Onge he stated that this fix has felt similar to adding three more adjustments to coil spring adjustments, and no more sag with you off the machine..
Doo has always been famous for there rear sag, but this cheap fix really shines quick.. And prevents rear shock from pounding out on the trail..
Before I started this quick1/2 hr job, I measured the sag on shop floor on setting 5 with rear bag and fuel caddy installed.. There was 3.5 inches
After installing the coil spring inserts there was no sag at all.. Fully extended and when I sit on the rear bumper it now drops 3.5 inches, jump off and it quickly rebounds to full length..
This has to be the best rear skid fix I have done to date, time to see how it's on the snow..
Click image for larger version
Rate this post: Yes | No
The Following 2 Users Say Thank You to fredw For This Useful Post:
MountainTrashCat (07-04-2018), rulonjj (05-02-2018)
  #2
Old 02-01-2018, 05:35 PM
Basic Member
Default
One last picture.. Rene has sold 20 sets and all happy costumers..
The Following User Says Thank You to fredw For This Useful Post:
  #3
Old 02-01-2018, 07:15 PM
jackbombay jackbombay is offline
Currently: Not set.
Basic Member
jackbombay has a reputation beyond reputejackbombay has a reputation beyond reputejackbombay has a reputation beyond reputejackbombay has a reputation beyond reputejackbombay has a reputation beyond reputejackbombay has a reputation beyond reputejackbombay has a reputation beyond reputejackbombay has a reputation beyond reputejackbombay has a reputation beyond reputejackbombay has a reputation beyond reputejackbombay has a reputation beyond repute
Default
Quote:
So the skis will stay down better without having to shorten the front limiter strap?
  #4
Old 02-01-2018, 08:48 PM
Skidoo bachelor Skidoo bachelor is offline
Currently: Not set.
Basic Member
Skidoo bachelor is an unknown quantity at this point
Default
Where do you get those?
  #5
Old 02-01-2018, 09:01 PM
ak ak is online now
Currently: Nothing
ak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond reputeak has a reputation beyond repute
Default
There’s a couple of company’s selling these.
http://www.gripnripracing.com/index....roller=product
https://www.hygearsuspension.com/col...spring-spacers
The Following 2 Users Say Thank You to ak For This Useful Post:
Devilmanak (06-27-2018), MountainTrashCat (07-04-2018)
  #6
Old 04-17-2018, 10:24 PM
donbrown's Avatar
donbrown donbrown is offline
Currently: Let it snow !!!
donbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond reputedonbrown has a reputation beyond repute
Default
How do these work? Keeps spring from compressing?
__________________
www.CNSA.NET lifetime member
  #7
Old 04-18-2018, 10:43 AM
snosumitcsr's Avatar
snosumitcsr snosumitcsr is offline
Currently: ripping it up
snosumitcsr has a reputation beyond reputesnosumitcsr has a reputation beyond reputesnosumitcsr has a reputation beyond reputesnosumitcsr has a reputation beyond reputesnosumitcsr has a reputation beyond reputesnosumitcsr has a reputation beyond reputesnosumitcsr has a reputation beyond reputesnosumitcsr has a reputation beyond reputesnosumitcsr has a reputation beyond reputesnosumitcsr has a reputation beyond reputesnosumitcsr has a reputation beyond repute
Default
What I found that works for me is the next heavier spring rate. their is a ton of difference in the weak/Soft stock springs and the next heavier. I had torsion spacers earlier in the season and it worked ok, but raised the rear up a little changing the geometry so the skis were pushed harder into the snow and the rear felt jacked up, felt like the front was plowing.
I installed a front cable limiter adjuster which broke the cable before I even really got to try it out. I find that there is no need to mess with the limiter with the heavy spring Rate. The actual Rate change of the spring is the most important thing in my Opinion. I also had my shocked Revalved by big john at Sled Head Racing Day one.. I have never bottomed my rear skid out yet and im 240 on #1 adjustment..
__________________
18’ Doo 850 165 3” skinz Bumpers, SHR Clutching valved shocks. Heavy springs, grip n rip and Zrp bracing ZRP Z motion CFR bars wheelies under control
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following 4 Users Say Thank You to snosumitcsr For This Useful Post:
BIG JOHN (04-19-2018), donbrown (04-18-2018), Matte Murder (05-04-2018), MountainTrashCat (07-04-2018)
  #8
Old 04-18-2018, 02:19 PM
donbrown's Avatar
Default
Installed a new spring? If so what is the part number?
__________________
  #9
Old 04-18-2018, 06:21 PM
Default
Quote:
Depends on what model you have summit x shocks use a different spring than free ride and summit SP.
Search for this pdf from dootalk, it has the spring part numbers. Lighter and heavier spring rates from the race manual. Look closely for your model. Also shows the rates.
__________________
0 out of 1 members found this post helpful. Rate this post: Yes | No
The Following 2 Users Say Thank You to snosumitcsr For This Useful Post:
donbrown (04-18-2018), MountainTrashCat (05-06-2018)
  #10
Old 04-18-2018, 11:40 PM
hoov165x hoov165x is offline
Currently: Riding
hoov165x has a reputation beyond reputehoov165x has a reputation beyond reputehoov165x has a reputation beyond reputehoov165x has a reputation beyond reputehoov165x has a reputation beyond reputehoov165x has a reputation beyond reputehoov165x has a reputation beyond reputehoov165x has a reputation beyond reputehoov165x has a reputation beyond reputehoov165x has a reputation beyond reputehoov165x has a reputation beyond repute
Default
You need free sag. With your setup you have none.
  #11
Old 05-02-2018, 11:42 AM
donbrown's Avatar
Click Here to Register
  #12
Old 05-02-2018, 11:10 PM
treeboy treeboy is offline
Currently: Not set.
Basic Member
treeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond reputetreeboy has a reputation beyond repute
The Following 2 Users Say Thank You to treeboy For This Useful Post:
donbrown (05-03-2018), MountainTrashCat (07-04-2018)
  #13
Old 05-02-2018, 11:15 PM
Currently: Not set.
Basic Member
  #14
Old 05-03-2018, 09:58 AM
rulonjj's Avatar
rulonjj rulonjj is offline
Currently: Current in the current current.
rulonjj has a reputation beyond reputerulonjj has a reputation beyond reputerulonjj has a reputation beyond reputerulonjj has a reputation beyond reputerulonjj has a reputation beyond reputerulonjj has a reputation beyond reputerulonjj has a reputation beyond reputerulonjj has a reputation beyond reputerulonjj has a reputation beyond reputerulonjj has a reputation beyond reputerulonjj has a reputation beyond repute
  #15
Old 05-03-2018, 11:46 AM
donbrown's Avatar
  #16
Old 05-04-2018, 12:11 AM
simnil simnil is online now
Currently: Not set.
Basic Member
simnil has a reputation beyond reputesimnil has a reputation beyond reputesimnil has a reputation beyond reputesimnil has a reputation beyond reputesimnil has a reputation beyond reputesimnil has a reputation beyond reputesimnil has a reputation beyond reputesimnil has a reputation beyond reputesimnil has a reputation beyond reputesimnil has a reputation beyond reputesimnil has a reputation beyond repute
The Following 2 Users Say Thank You to simnil For This Useful Post:
donbrown (05-05-2018), MountainTrashCat (05-06-2018)
  #17
Old 05-11-2018, 05:23 AM
IcutMetl IcutMetl is offline
Currently: Not set.
Basic Member
IcutMetl has a reputation beyond reputeIcutMetl has a reputation beyond reputeIcutMetl has a reputation beyond reputeIcutMetl has a reputation beyond reputeIcutMetl has a reputation beyond reputeIcutMetl has a reputation beyond reputeIcutMetl has a reputation beyond reputeIcutMetl has a reputation beyond reputeIcutMetl has a reputation beyond reputeIcutMetl has a reputation beyond reputeIcutMetl has a reputation beyond repute
  #18
Old 06-25-2018, 01:59 PM
donbrown's Avatar
  #19
Old 06-25-2018, 02:20 PM
donbrown's Avatar
  #20
Old 06-26-2018, 03:29 AM
Currently: Not set.
Basic Member
donbrown (06-27-2018), MountainTrashCat (07-04-2018)
  #21
Old 06-27-2018, 09:34 PM
Devilmanak Devilmanak is offline
Currently: 500 miles and myrecoilstill works!!!
Devilmanak has a reputation beyond reputeDevilmanak has a reputation beyond reputeDevilmanak has a reputation beyond reputeDevilmanak has a reputation beyond reputeDevilmanak has a reputation beyond reputeDevilmanak has a reputation beyond reputeDevilmanak has a reputation beyond reputeDevilmanak has a reputation beyond reputeDevilmanak has a reputation beyond reputeDevilmanak has a reputation beyond reputeDevilmanak has a reputation beyond repute
The Following 2 Users Say Thank You to Devilmanak For This Useful Post:
donbrown (07-09-2018), MountainTrashCat (07-04-2018)
  #22
Old 06-28-2018, 06:22 AM
Currently: Not set.
Basic Member
  #23
Old 07-04-2018, 10:37 AM
1Mike900 1Mike900 is offline
Currently: Not set.
1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute1Mike900 has a reputation beyond repute
The Following 2 Users Say Thank You to 1Mike900 For This Useful Post:
  #24
Old 07-07-2018, 02:24 PM
mountainhorse's Avatar
mountainhorse mountainhorse is offline
Currently: CONTEMPLATING: "Laughter is gods hand on a troubled world.".
mountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond repute
The Following 2 Users Say Thank You to mountainhorse For This Useful Post:
Daag44 (07-07-2018), donbrown (07-09-2018)
  #25
Old 07-09-2018, 01:07 AM
donbrown's Avatar
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Missing Rear bolt in skid fix :) Thread Starter — Yamadoo04 Forum — Utah Replies — 3 Last Post — 02-26-2013 10:58 AM
Thread — Rear suspension....to sag, or not to sag, that is the question? Thread Starter — snowmanx Forum — Performance/Modified Replies — 8 Last Post — 03-22-2010 02:36 AM
Thread — M7 rear skid sag Thread Starter — High Life Forum — Arctic Cat: M Series Replies — 15 Last Post — 12-07-2009 08:39 PM
Thread — Cheap fix for Nytro skid??? Thread Starter — Blue Light Forum — Yamaha Replies — 4 Last Post — 08-29-2008 11:12 AM
no new posts
