Upgrade to Premium
Arctic Cat: M Series 2005-Current, all models in the M-series chassis
Reply
  #1
Old 01-31-2018, 08:20 PM
Powder Poacher Powder Poacher is offline
Currently: Not set.
Basic Member
Powder Poacher has a brilliant futurePowder Poacher has a brilliant futurePowder Poacher has a brilliant futurePowder Poacher has a brilliant futurePowder Poacher has a brilliant futurePowder Poacher has a brilliant futurePowder Poacher has a brilliant futurePowder Poacher has a brilliant futurePowder Poacher has a brilliant futurePowder Poacher has a brilliant futurePowder Poacher has a brilliant future
Default no power to the fuel pump
Any help with the following issue is appreciated!
Sled-2010 M-8
Issue-no power to the fuel pump
I have spark
I am suspect of a bare wire shorting out or poor ground. Here's what I know so far.
When I add alternate power to the fuel pump the fuel pump runs and so does the sled. This is achieved by unplugging the fuel pump harness and supplying power from a 12v battery. The sled will fire right up and run perfect.
When the fuel pump wiring harness is unplugged and the sled is running off of the alternate source, the gauge does not light up nor does the tail light. If I quickly unplug the alternate battery running the fuel pump and reconnect the fuel pump wire harness the gauge and tail light illuminate (flicker) as long as it stays running. I am also watching the fuel pressure gauge and can tell when I'm loosing power because I'm loosing pressure.
I've been messing with this thing all day, wiggling harnesses and whatnot trying to locate the spot but no success. Anyone out there have suggestions???
I had a problem in the past with the thumb warmer shorting out but it only seemed to effect the lighting circuit and not run ability.
Rate this post: Yes | No
  #2
Old 02-01-2018, 06:45 AM
Old & slow Old & slow is offline
Currently: Not set.
Old & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond reputeOld & slow has a reputation beyond repute
Default
Quote:
Sled-2010 M-8
I have spark
First off check the fuses if you haven't already, second the M series wires did rub through sometimes. Check the area on the left side of the fuel tank,and under the seat. Another area was the main harness from the ccu. Electrical can be hard to find but usually easy to fix. You may have two separate issues i would also repair the thumb warmer issue first and see if that changes anything.
  #3
Old 02-01-2018, 02:02 PM
Skywest Skywest is offline
Currently: Not set.
Basic Member
Skywest has a reputation beyond reputeSkywest has a reputation beyond reputeSkywest has a reputation beyond reputeSkywest has a reputation beyond reputeSkywest has a reputation beyond reputeSkywest has a reputation beyond reputeSkywest has a reputation beyond reputeSkywest has a reputation beyond reputeSkywest has a reputation beyond reputeSkywest has a reputation beyond reputeSkywest has a reputation beyond repute
Default
There is a ground underneath the coolant bottle. It’s buried in there but mine was starting to chaff against the frame. It could be causing your issues.
  #4
Old 02-01-2018, 02:43 PM
Currently: Not set.
Basic Member
Default
I've checked the ground and actually added more ground. Still nothing. Checked the wires under the tank and they appear to be good. Still digging!
  #5
Old 02-27-2018, 03:28 PM
Currently: Not set.
Basic Member
Default
Have you ohmed out your stator?
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — M8 Bd turbo fuel pump power issues! Thread Starter — M1000Mod162 Forum — Arctic Cat: TURBO Replies — 4 Last Post — 01-05-2015 03:45 PM
Thread — Where can I get a fuel pump and could a weak fuel pump be affecting performance alot Thread Starter — cumminshp Forum — Arctic Cat: M Series Replies — 15 Last Post — 11-29-2012 03:01 PM
Thread — 06 900 no power to fuel pump or lights/gauges Thread Starter — Snowhood Forum — Polaris: 900 Replies — 9 Last Post — 12-23-2011 11:30 PM
Thread — no power to fuel pump 2009 m8 Thread Starter — ingin689 Forum — Arctic Cat: M Series Replies — 3 Last Post — 02-27-2011 10:42 PM
Thread — Fuel Pump Relay Clicks - No power - Battery? Thread Starter — 03rmking Forum — Yamaha Replies — 7 Last Post — 12-11-2007 12:37 PM
no new posts
