Upgrade to Premium
Reply
  #1
Old 01-29-2018, 11:24 PM
coryf89 coryf89 is online now
Currently: 13 ktm 450sxf. 17 yeti 129
Basic Member
coryf89 has a reputation beyond reputecoryf89 has a reputation beyond reputecoryf89 has a reputation beyond reputecoryf89 has a reputation beyond reputecoryf89 has a reputation beyond reputecoryf89 has a reputation beyond reputecoryf89 has a reputation beyond reputecoryf89 has a reputation beyond reputecoryf89 has a reputation beyond reputecoryf89 has a reputation beyond reputecoryf89 has a reputation beyond repute
Default what are you guys using for batteries?
bike almost started at -29. same thing at -15. but just wont. so close. it sucks having electric start only.
2013 ktm 450sxf with 520 big bore. Rotella t6 synthetic 0w-40. antigravity LI-ION battery. is the LI-ION my problem?
should I be running a different battery type? a lb or 2 wont bother me... I just want my damn bike to start!!!!
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #2
Old 01-29-2018, 11:45 PM
Motogeek33's Avatar
Motogeek33 Motogeek33 is offline
Currently: "The only good thing about that kit is the track." :-P~~!!!
Motogeek33 has a reputation beyond reputeMotogeek33 has a reputation beyond reputeMotogeek33 has a reputation beyond reputeMotogeek33 has a reputation beyond reputeMotogeek33 has a reputation beyond reputeMotogeek33 has a reputation beyond reputeMotogeek33 has a reputation beyond reputeMotogeek33 has a reputation beyond reputeMotogeek33 has a reputation beyond reputeMotogeek33 has a reputation beyond reputeMotogeek33 has a reputation beyond repute
Default
An AGM battery will usually work best in the cold. I run a Yuasa YTZ7S in my 500 EXC and it's been working great, although we haven't had any really cold days this year.
The Following User Says Thank You to Motogeek33 For This Useful Post:
coryf89 (01-30-2018)
  #3
Old 01-30-2018, 06:52 AM
Ben 500RR-S Ben 500RR-S is online now
Currently: 18 Camso DTS 129
Basic Member
Ben 500RR-S has a reputation beyond reputeBen 500RR-S has a reputation beyond reputeBen 500RR-S has a reputation beyond reputeBen 500RR-S has a reputation beyond reputeBen 500RR-S has a reputation beyond reputeBen 500RR-S has a reputation beyond reputeBen 500RR-S has a reputation beyond reputeBen 500RR-S has a reputation beyond reputeBen 500RR-S has a reputation beyond reputeBen 500RR-S has a reputation beyond reputeBen 500RR-S has a reputation beyond repute
Default
My OEM lead acid Yuasa has been doing the job, so far. I'm surprised you don't keep a small Li-Ion jump pack to help the main battery on those extra-cold mornings/starts.
I had a -15 F morning start and the jump pack helped a lot in getting the bike started as the cold had the battery struggling to start the motor. I'm also glad I have the kickstarter as a backup but if I had no backup kickstarter I'd for sure keep a jump pack at the ready.
My next battery will be Li-Ion.
  #4
Old 01-30-2018, 07:22 AM
wwillf01's Avatar
wwillf01 wwillf01 is offline
Currently: Praying for snow
wwillf01 has a reputation beyond reputewwillf01 has a reputation beyond reputewwillf01 has a reputation beyond reputewwillf01 has a reputation beyond reputewwillf01 has a reputation beyond reputewwillf01 has a reputation beyond reputewwillf01 has a reputation beyond reputewwillf01 has a reputation beyond reputewwillf01 has a reputation beyond reputewwillf01 has a reputation beyond reputewwillf01 has a reputation beyond repute
Default
I have to use a jump starter with the lithium when it is that cold...I just wired the plugs to hang under the seat for easy access ..
Sent from my Pixel 2 XL using Tapatalk
  #5
Old 01-30-2018, 10:08 AM
Snowbikenewbie Snowbikenewbie is offline
Currently: Not set.
Basic Member
Snowbikenewbie has a reputation beyond reputeSnowbikenewbie has a reputation beyond reputeSnowbikenewbie has a reputation beyond reputeSnowbikenewbie has a reputation beyond reputeSnowbikenewbie has a reputation beyond reputeSnowbikenewbie has a reputation beyond reputeSnowbikenewbie has a reputation beyond reputeSnowbikenewbie has a reputation beyond reputeSnowbikenewbie has a reputation beyond reputeSnowbikenewbie has a reputation beyond reputeSnowbikenewbie has a reputation beyond repute
Default
I hear the earth x lithium batteries are working best. I have the stock lead battery and it’s been great at starting once warm. Another rider I know has a lithium in an adventure bike. He said when it’s really cold he turns on the headlight for a few minutes to wake/warm up the battery and then it fires. You might try that.
  #6
Old 01-30-2018, 12:20 PM
ChrisNeibauer ChrisNeibauer is online now
Currently: Not set.
ChrisNeibauer has a reputation beyond reputeChrisNeibauer has a reputation beyond reputeChrisNeibauer has a reputation beyond reputeChrisNeibauer has a reputation beyond reputeChrisNeibauer has a reputation beyond reputeChrisNeibauer has a reputation beyond reputeChrisNeibauer has a reputation beyond reputeChrisNeibauer has a reputation beyond reputeChrisNeibauer has a reputation beyond reputeChrisNeibauer has a reputation beyond reputeChrisNeibauer has a reputation beyond repute
Default
WPS Featherweight Lithium Battery HJT9B-FP-IL off amazon. running in 4 FE501's and a 450SXF, so far not a problem after a year
  #7
Old 01-30-2018, 12:55 PM
Basic Member
Default
learned the hard way. first ride out... first thing in the morning, needed a boost off the truck. half way through the day I think I got snow on the battery due to broken airbox shroud, and I had no e start. needed to be pull started. what a disaster that was.
ordered up an antigravity XP 10 that I carry in my backpack. WAY overkill, but hopefully it doesnt let me down.
https://www.rockymountainatvmc.com/p...icro-Start-PPS
also, regarding easy boosting, id like to mount one of these under my rear fender for quick and easy access... no more removing my seat if I need a boost. just clamp on from the booster in my backpack and go (I wish it worked when cold, or else I could keep it in the cargo case on the skid... is my backpack really that warm?)
http://www.vte-europe.com/content/el..._connector.php
  #8
Old 01-30-2018, 01:03 PM
Basic Member
Default
Oh man, I can't imagine having no kickstarter and then no backup charger.
I'm going to take the Weego charger that I do have and make sure that it is still topped up even though it has been less than a month from when I last charged it, just to make sure it is full, just in case as even with a kickstarter, sometimes, well, one never knows.
I'm so glad that Beta created a pushbutton seat release, no tools needed to get under the seat=bonus.
  #9
Old 01-30-2018, 01:16 PM
Excalibur's Avatar
Excalibur Excalibur is offline
Currently: Need snow!!!!
Excalibur has a reputation beyond reputeExcalibur has a reputation beyond reputeExcalibur has a reputation beyond reputeExcalibur has a reputation beyond reputeExcalibur has a reputation beyond reputeExcalibur has a reputation beyond reputeExcalibur has a reputation beyond reputeExcalibur has a reputation beyond reputeExcalibur has a reputation beyond reputeExcalibur has a reputation beyond reputeExcalibur has a reputation beyond repute
Default
This is what I use. you can find the harness at EarthX or other places. Hook leads to battery and carry the other half with jump battery. Nice weather seal plug for the center section of the harness. The small jump batteries all use the same plug.
Click image for larger version
  #10
Old 01-30-2018, 02:25 PM
Misha Subo Misha Subo is offline
Currently: 2 x('18Camso/'08KTM300 XCW)
Basic Member
Misha Subo has a reputation beyond reputeMisha Subo has a reputation beyond reputeMisha Subo has a reputation beyond reputeMisha Subo has a reputation beyond reputeMisha Subo has a reputation beyond reputeMisha Subo has a reputation beyond reputeMisha Subo has a reputation beyond reputeMisha Subo has a reputation beyond reputeMisha Subo has a reputation beyond reputeMisha Subo has a reputation beyond reputeMisha Subo has a reputation beyond repute
  #11
Old 01-30-2018, 06:17 PM
Basic Member
Click Here to Register
  #12
Old 01-30-2018, 06:44 PM
wwillf01's Avatar
  #13
Old 01-30-2018, 06:57 PM
Basic Member
  #14
Old 01-30-2018, 08:26 PM
chumbilly1 chumbilly1 is offline
Currently: livin' the dream!, but needin' to ride!
chumbilly1 has a reputation beyond reputechumbilly1 has a reputation beyond reputechumbilly1 has a reputation beyond reputechumbilly1 has a reputation beyond reputechumbilly1 has a reputation beyond reputechumbilly1 has a reputation beyond reputechumbilly1 has a reputation beyond reputechumbilly1 has a reputation beyond reputechumbilly1 has a reputation beyond reputechumbilly1 has a reputation beyond reputechumbilly1 has a reputation beyond repute
  #15
Old 01-30-2018, 10:34 PM
Basic Member
  #16
Old 01-31-2018, 01:25 AM
  #17
Old 01-31-2018, 09:41 AM
M5- M5- is offline
Currently: Riding the Beartooth Pass
Basic Member
M5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond reputeM5- has a reputation beyond repute
The Following User Says Thank You to M5- For This Useful Post:
coryf89 (01-31-2018)
  #18
Old 01-31-2018, 01:28 PM
hollywood506 hollywood506 is offline
Currently: Not set.
Basic Member
hollywood506 has a reputation beyond reputehollywood506 has a reputation beyond reputehollywood506 has a reputation beyond reputehollywood506 has a reputation beyond reputehollywood506 has a reputation beyond reputehollywood506 has a reputation beyond reputehollywood506 has a reputation beyond reputehollywood506 has a reputation beyond reputehollywood506 has a reputation beyond reputehollywood506 has a reputation beyond reputehollywood506 has a reputation beyond repute
  #19
Old 01-31-2018, 02:16 PM
Basic Member
  #20
Old 01-31-2018, 04:39 PM
CATSLEDMAN1 CATSLEDMAN1 is offline
Currently: one ski and a KTM
CATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond repute
  #21
Old 01-31-2018, 07:15 PM
Sheetmetalfab's Avatar
Sheetmetalfab Sheetmetalfab is online now
Currently: Getting the R6 snowbike ready......
Sheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond reputeSheetmetalfab has a reputation beyond repute
  #22
Old 01-31-2018, 11:41 PM
kell8071 kell8071 is offline
Currently: Not set.
kell8071 has a reputation beyond reputekell8071 has a reputation beyond reputekell8071 has a reputation beyond reputekell8071 has a reputation beyond reputekell8071 has a reputation beyond reputekell8071 has a reputation beyond reputekell8071 has a reputation beyond reputekell8071 has a reputation beyond reputekell8071 has a reputation beyond reputekell8071 has a reputation beyond reputekell8071 has a reputation beyond repute
The Following User Says Thank You to kell8071 For This Useful Post:
coryf89 (02-01-2018)
  #23
Old 02-01-2018, 08:04 AM
dooman92 dooman92 is online now
Currently: Not set.
dooman92 has a reputation beyond reputedooman92 has a reputation beyond reputedooman92 has a reputation beyond reputedooman92 has a reputation beyond reputedooman92 has a reputation beyond reputedooman92 has a reputation beyond reputedooman92 has a reputation beyond reputedooman92 has a reputation beyond reputedooman92 has a reputation beyond reputedooman92 has a reputation beyond reputedooman92 has a reputation beyond repute
  #24
Old 02-07-2018, 04:26 PM
Pjjansson Pjjansson is offline
Currently: Not set.
Basic Member
Pjjansson is an unknown quantity at this point
  #25
Old 08-26-2018, 05:40 AM
Basic Member
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Connecting two Batteries. Thread Starter — COP-OUT Forum — Trucks and Trailers Replies — 6 Last Post — 11-23-2013 11:27 AM
Thread — earthX batteries Thread Starter — tpollon2 Forum — General Snowmobiling Replies — 0 Last Post — 11-04-2013 11:43 PM
Thread — liteweight batteries Thread Starter — beturbo Forum — Arctic Cat: 1100 ProClimb Replies — 1 Last Post — 12-18-2011 11:13 AM
Thread — Batteries Thread Starter — bendelow Forum — GPS enabled devices Replies — 13 Last Post — 12-14-2010 12:54 PM
Thread — Gel Batteries Thread Starter — goofy Forum — Ski-Doo Replies — 0 Last Post — 12-01-2008 07:33 PM
