Upgrade to Premium
Polaris: EDGE 2002-2005, all models in the Edge chassis
Reply
  #1
Old 01-28-2018, 05:48 PM
GrapeIsland GrapeIsland is offline
Currently: Not set.
Basic Member
GrapeIsland is an unknown quantity at this point
Default 2006 Edge Touring 550 jetting advice needed
In Winter we use our sleds mainly for transportation back and forth to mainland - which is less than 1km each way. Usually 2 up, often towing small sleigh. I have a 2006 Edge touring 550. We have always run fan cooled sleds as liquids either take too long to warm up, or overheat on bare ice.
I rebuilt my 550 with spi pistons and extra clearance. It has 280pto/270mag jetting. Needles clipped in middle.
It always seems to run too rich, especially in warmer weather. too the point of bogging where I have to coax it to get on the pipe.
I have read old posts where some people have used 220 mains. That seems like a HUGE drop from stock, but maybe it;s the way I should go? We do not use it for long trial rides - although sometimes kids go for a 25 minutes rip around island.
Can I safely go down to much smaller jetting to get better warm weather running? I know these engines have burn down issues.
Thanks and sorry for long email
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to GrapeIsland For This Useful Post:
GrapeIsland (01-30-2018)
  #2
Old 01-29-2018, 01:23 PM
retiredpop retiredpop is online now
Currently: Not set
retiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond repute
Default
I wouldn't go to 220 mains for your elevation. I found a jetting chart for your sled and it looks like 270/260 or 260/250 would be a better setup.
See attachment for jetting.
__________________
The older I get the better I was. In fact now that I think about it I'm a legend!
Haven't outgrown my 600 yet!
The Following User Says Thank You to retiredpop For This Useful Post:
  #3
Old 01-29-2018, 11:07 PM
whoisthatguy's Avatar
whoisthatguy whoisthatguy is online now
Currently: Not set.
whoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond repute
Default
Experiment with the needle clips in the #2 position from the top. Mains are for high RPM performance. Needle clips are for idling and low RPM performance.
  #4
Old 01-30-2018, 05:52 AM
Currently: Not set.
Basic Member
Default
Thank you !! I will drop to 250/260 and see how that works
  #5
Old 01-30-2018, 09:53 PM
Bushwacker1 Bushwacker1 is online now
Currently: Not set.
Bushwacker1 has a reputation beyond reputeBushwacker1 has a reputation beyond reputeBushwacker1 has a reputation beyond reputeBushwacker1 has a reputation beyond reputeBushwacker1 has a reputation beyond reputeBushwacker1 has a reputation beyond reputeBushwacker1 has a reputation beyond reputeBushwacker1 has a reputation beyond reputeBushwacker1 has a reputation beyond reputeBushwacker1 has a reputation beyond reputeBushwacker1 has a reputation beyond repute
Default
Install a holzmann tempaflow on the sled. This device will adjust your jetting as the temps rise. I have installed them on over 10 different sleds between my own or friends sleds. You jet from the MFG jetting chart for -20 Deg F and it applies a vacuum to your float bowls as the outside air temp rises to keep the jetting where it should be. This device is truly a product that does everything it is advertised to do. There is also a way to make fine tuning adjustments if your elevation changes.
  #6
Old 01-31-2018, 12:50 AM
Currently: Not set.
Default
You would want to check on how much oil you are burning per gallon of gas, and try to keep it in the 40 parts gas to 1 part oil range. As sleds get older, the oil pump mixture will vary to the point of burning up crankshaft bearings. Polaris always goes conservative on all of their jetting and needle recommendations, so that the engine don't burn down under warranty.
The Following User Says Thank You to whoisthatguy For This Useful Post:
GrapeIsland (01-31-2018)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2007 polaris trail Touring 550 Thread Starter — righty9938 Forum — Polaris Replies — 0 Last Post — 01-11-2011 09:13 PM
Thread — 2006 Edge touring Thread Starter — dmach8 Forum — Polaris Replies — 2 Last Post — 02-19-2009 06:24 AM
Thread — 2000 polaris 550 touring Thread Starter — brincx Forum — Polaris Replies — 0 Last Post — 01-21-2009 09:42 AM
Thread — Advice needed for putting a 155 track under my 04 edge chassis Thread Starter — Reaper Forum — Polaris Replies — 15 Last Post — 09-11-2008 01:39 AM
Thread — 2003 Polaris Trail Touring 550 Thread Starter — 700_Edge_X Forum — Polaris (Swapmeet) Replies — 0 Last Post — 03-17-2008 02:40 PM
no new posts
