Upgrade to Premium
Polaris: IQ 2005-Current, all models in the IQ and IQ Raw chassis
Reply
  #1
Old 01-28-2018, 09:03 AM
sledmanhof's Avatar
sledmanhof sledmanhof is offline
Currently: Not set.
sledmanhof has a reputation beyond reputesledmanhof has a reputation beyond reputesledmanhof has a reputation beyond reputesledmanhof has a reputation beyond reputesledmanhof has a reputation beyond reputesledmanhof has a reputation beyond reputesledmanhof has a reputation beyond reputesledmanhof has a reputation beyond reputesledmanhof has a reputation beyond reputesledmanhof has a reputation beyond reputesledmanhof has a reputation beyond repute
Garage
Default Dragon det and low idle issues
I have an 09 dragon 800 and just took the first trip out this season and I had noticed when I went to start it on the mountain it wouldnt hold an idle. Well got it warmed up and took off and had the check engine light come on once Iíd hit roughly 6500 rpm and would kick it to limp mode with the det code. Checked the plugs and they were way to lean.
I talked to the nearest dealer and they told me to change the fuel filter which I did. Tried it the next day and it still had that issue. I did have trouble starting it before the trip but drained the gas and put new in and it fixed that problem. It idles fine at 1500 ft back home.
On the last trip last year I had replaced the voltage reg and capacitor but rode a full day running great after.
I also did notice a couple hornet nests that had formed over the summer behind my dash but looked in my air box and didnít see anything. Iím at a loss at what could be causing this as it ran perfect last season
Rate this post: Yes | No
  #2
Old 01-28-2018, 04:30 PM
XCaSSAULT XCaSSAULT is online now
Currently: Go Wild!
Basic Member
XCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond repute
Default
As far as I know the only thing that could effect the way the motor runs at different elevations would be the air box/barometric senor.
Iím sure some good googling could turn up a way to test this sensor. And triple checking all wires for rub throughs and corrosion would be a good start.
Otherwise completely going over the exhaust valves is always good practice. Checking for cracked bellows, smoke from solenoid tube, spring condition, carbon build-up and clogged cylinder holes.
Might as well look in there with a good flashlight and check pistons/ cylinder walls.
Compression check too
The Following User Says Thank You to XCaSSAULT For This Useful Post:
sledmanhof (01-28-2018)
  #3
Old 01-28-2018, 08:47 PM
sledmanhof's Avatar
Currently: Not set.
Garage
Default
Thanks for the reply. Iím gonna tear into it this week hopefully. Iíve been reading to make it that lean itís not getting enough fuel compared to the air itís pulling in. Iíve never had the issue with the 2000 miles ive put on it. It got a new top end 400 miles ago. What else could also be related to the fuel? Aside from changing fuel filter which I did, is there an easy way to check the injectors without taking it to a dealer? I know the fuel mapping with the ecu was an issue a while ago but Iím assuming since Iíve never had an issue before it wouldnít suddenly start now. I donít believe the fuel had ethanol mixed in but if there was trace amounts could that have an affect on it too?
  #4
Old 01-28-2018, 10:36 PM
Currently: Go Wild!
Basic Member
Default
I have very little experience dealing with injectors but I do know they are expensive. Really damn expensive! Like $210/piece and there is 4 of them! So i would dive into all other aspects that can cause lack of fuel. And there is many.
Such as weak fuel pump, faulty sensor or possible air leak from cracked intake boots or crank seal.
The problem at elevation really feels like barometric sensor but in all Iíve read on these sleds I havenít come across the symptoms that that senor being faulty would show. Probably because itís a bosh sensor and they seem to know how to make good products. But that doesnít rule it out.
The throttle position sensor seems to be a common randomly failing part on these things and will effect fuel delivery especially at idle, so thatís should be on the list.
Iíve heard there are places that can flow test the injectors. Iíd look into that before replacing them but only after ruling everything else out.
  #5
Old 02-11-2018, 03:32 PM
sledmanhof's Avatar
Currently: Not set.
Garage
Default
So I finally got to tear it apart and the only thing I have come across is one of my exhaust valve springs was disinigrated. What could that have had to do with this problem if at all?
  #6
Old 02-13-2018, 10:08 PM
KJ800 KJ800 is offline
Currently: Not set.
Basic Member
KJ800 is an unknown quantity at this point
Default
I've been having a similar problem on my 2010 800 Dragon. Bought it used with ~1500 miles and before I did any riding put the durability kit in it. Ever since the rebuild it has had a hesitation (or dead spot) right around mid throttle or 6500rpm roughly. If I go slowly through the throttle generally the check engine light will come on. If I let off it will go off and not come back on right away. If I don't let off it will flash and retard the motor.
What I have done with no change in performance:
-New fuel filter
-Fresh gas, have ran several fresh tanks through
-New crank position sensor
-New water temp sensor
I've been reading a lot on throttle position sensors, and tonight I tested mine using a rough homemade tester. Found that at about half throttle (but not where I was noticing while riding) it would get a 0 reading then come back to a normal voltage. I'll be buying a new TPS tomorrow and dialing that in. Starting to run out of options, but it makes sense that this is the problem. I'm hoping there is a dead spot in the TPS causing it to lean out and hesitate/throw crank position sensor code.
I'll update with my findings.
The Following 2 Users Say Thank You to KJ800 For This Useful Post:
sledmanhof (02-14-2018), XCaSSAULT (02-14-2018)
  #7
Old 02-14-2018, 08:28 PM
sledmanhof's Avatar
Currently: Not set.
Garage
Default
Thatís exactly the same symptoms I have. Hopefully that can be the culprit and is an easy fix.
  #8
Old 02-18-2018, 09:13 PM
Currently: Not set.
Basic Member
Default
So yesterday I put in the new TPS and went through the setup process. I was optimistic, but I tested the TPS again after calibration and there was the same "dead spot" in the throttle where the multimeter goes to zero. So... I may have not had a bad TPS after all, $169 well spent.
Anyway, took it down the length of the field probably 15-20 times. It still has the hesitation, although maybe half as much as the last time I rode. And, no check engine lights. I went through the throttle slow, fast, in-between, let off and went right back on it. Seems to run a little smoother. Maybe it just needed the throttle body adjusted along with the TPS. Supposed to be going to the UP on Thursday to ride for the long weekend. So we'll see how it runs.
  #9
Old 02-21-2018, 10:23 PM
peaceofwork peaceofwork is offline
Currently: Internet Rmkpro 800apprentiship
Basic Member
peaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond reputepeaceofwork has a reputation beyond repute
Default
Be sure and report back, I watch this with great interest
  #10
Old 02-22-2018, 04:27 PM
sledmanhof's Avatar
Currently: Not set.
Garage
  #11
Old 02-23-2018, 08:59 AM
Currently: Go Wild!
Basic Member
Click Here to Register
  #12
Old 02-24-2018, 12:49 PM
sledmanhof's Avatar
Currently: Not set.
Garage
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 800CFI (Dragon) issues - Stall/Kill at idle Thread Starter — t_jones98 Forum — Polaris Replies — 3 Last Post — 03-21-2016 09:14 AM
Thread — Starting issues idle issues running issues? Help Thread Starter — WINJE Forum — Arctic Cat: TURBO Replies — 2 Last Post — 12-22-2013 02:19 AM
Thread — High idle then low idle, and no reverse Thread Starter — Whiz-bang Forum — Polaris: Pro-Ride Replies — 11 Last Post — 01-23-2012 10:51 PM
Thread — low idles, bad idle, no idle Thread Starter — 9 Iron Forum — Ski-Doo: XP Sleds Replies — 0 Last Post — 01-28-2010 02:09 AM
Thread — 2008 dragon 800 low elevation stumble and suspension issues Thread Starter — Mike89 Forum — Polaris Replies — 38 Last Post — 12-23-2008 08:32 AM
no new posts
