Upgrade to Premium
Ski-Doo: TURBO Turbo discussion for Ski-Doo aftermarket turbo sleds
Reply
  #1
Old 01-27-2018, 09:34 PM
TWARD700's Avatar
TWARD700 TWARD700 is online now
Currently: Sled is almost ready just need snow!!
TWARD700 has a reputation beyond reputeTWARD700 has a reputation beyond reputeTWARD700 has a reputation beyond reputeTWARD700 has a reputation beyond reputeTWARD700 has a reputation beyond reputeTWARD700 has a reputation beyond reputeTWARD700 has a reputation beyond reputeTWARD700 has a reputation beyond reputeTWARD700 has a reputation beyond reputeTWARD700 has a reputation beyond reputeTWARD700 has a reputation beyond repute
Default Silber 850 knock sensor
Full throttle pull for 20 seconds 4' of powder stated to fall on its face and blinked a knock sensor on the gauge. Anyone have this happen??
__________________
2008 SKID00 REV XP TURBO PERFORMANCE GARRETT KIT 10 LBS ON AVGAS 174 2.5 ICE AGE RAILS FOX EVOL X's EVOLUTION AIR SUSPENSION BRTECH HEADLIGHT DELETE POLISHED TUNNEL LOTS OF POWDERCOATING CAMO GRAPHICS http://s611.photobucket.com/albums/tt197/Tward700
Rate this post: Yes | No
  #2
Old 01-27-2018, 10:30 PM
mountainhorse's Avatar
mountainhorse mountainhorse is offline
Currently: CONTEMPLATING: "Laughter is gods hand on a troubled world.".
mountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond repute
Default
What elevation, and boost?
What fuel?
__________________
Signature:
  #3
Old 01-28-2018, 02:03 AM
TWARD700's Avatar
Default
5000' 50av-50pump 5 psi
__________________
  #4
Old 01-28-2018, 06:11 PM
fredw fredw is offline
Currently: 850 blown up before Breakin over
Basic Member
fredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond repute
Default
Gear up two teeth on top sprocket, hitting rev limiter..
Sibler should of added more gearing to there kits, especially for guys running under 7000’
  #5
Old 01-28-2018, 07:12 PM
TheRedrooster TheRedrooster is online now
Currently: Not set.
TheRedrooster has a reputation beyond reputeTheRedrooster has a reputation beyond reputeTheRedrooster has a reputation beyond reputeTheRedrooster has a reputation beyond reputeTheRedrooster has a reputation beyond reputeTheRedrooster has a reputation beyond reputeTheRedrooster has a reputation beyond reputeTheRedrooster has a reputation beyond reputeTheRedrooster has a reputation beyond reputeTheRedrooster has a reputation beyond reputeTheRedrooster has a reputation beyond repute
Default Sled turbo sputtering
No that’s not the problem it’s a lack of fuel not gearing your afr are to high if you keep running it like that you’ll fix it for sure it will go boom
  #6
Old 01-28-2018, 07:51 PM
Basic Member
Default
Just got off the phone with the guy that hit the over rev/ knock sensor, he uses 120 octane fuel and since gearing up problem solved..
  #7
Old 01-28-2018, 08:05 PM
TWARD700's Avatar
Default
I have the 26 tooth to gear from TKI
To go to 2.4 gearing running 2.52 now
Running SHR weights 6 gram screw 2 gram on bolt clicker 3
Pulls 8000 ever time I look down but the recall says 8440
__________________
  #8
Old 01-28-2018, 08:15 PM
Basic Member
Default
Ya this pdrive is defiantly I think leaving something on the table, my stock 850 is also showing 8400 max rpm, but only shows 8-8100 on a big pull when looking
I looked at my stock primary after the last few days of hard 100 second pulls and the belt is up less than 1/2 inch from top of primary... thee is no way in hell that it can’t over rev with a turbo added making another 50 hp..
Why Sibler needs to add some gearing, my other two turbo xm sleds run 2.03 and 2.10 gearing and belt goes one inch from top of primary on a good pull at 7000’
  #9
Old 01-28-2018, 09:23 PM
Basic Member
Default
Talking with a tech tonight, he says after 8300rpm ecm starts pulling fuel, this would also lean out and hit knock much easier, possible det plug damage you seen
Gearing up was on the top of his list of things to remedy problem
  #10
Old 01-29-2018, 07:27 AM
winter brew's Avatar
winter brew winter brew is offline
Currently: Not set.
winter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond repute
  #11
Old 01-29-2018, 09:08 AM
Basic Member
Click Here to Register
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — knock sensor Thread Starter — summit800 Forum — Ski-Doo: XP Sleds Replies — 3 Last Post — 12-23-2017 11:02 PM
Thread — Any one have a tps or knock sensor go out on a silber kit?? Thread Starter — cr187 Forum — Polaris: TURBO Replies — 1 Last Post — 01-05-2012 02:33 PM
Thread — Knock Sensor Thread Starter — Dock Forum — Ski-Doo: XP Sleds Replies — 9 Last Post — 12-19-2010 01:10 AM
Thread — Why is my knock sensor on? Thread Starter — hivoltagesledhead Forum — Ski-Doo: TURBO Replies — 11 Last Post — 12-07-2010 07:28 PM
Thread — Knock sensor Thread Starter — donttelmywife Forum — Polaris: 900 Replies — 5 Last Post — 01-09-2010 12:09 AM
no new posts
