#1
In light of this recent thread I have a question.
https://www.snowest.com/forum/showthread.php?t=439857 I just removed my primary clutch for other unrelated work. In reading this recent thread, post #2 mentions that the OP's crankshaft line marking must align with a circle marking on the movable clutch sheave. My question is.... if my clutch was removed and then reinstalled (with no clutch dis-assembly), does it require being indexed to the crankshaft in some fashion? . Last edited by Rick E; 01-26-2018 at 10:08 AM. |
#2
Yes, it does. There are two circles on the movable sheave. One is small in diameter, one is larger in diameter. The larger of the two is for indexing with the crankshaft. Look close on at the crank stub; there should be a line on it, align that crank mark with the bigger circle on the movable sheave.
#3
Thank you for that info.
As it turns out, I had noticed the larger circle as well as the PTO crank stub index line. I lined them up the best that I could. She is all back together now. Rick E. |
Bookmarks |
Previous Thread
Next Thread
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Thread — 08 800r primary clutch | Thread Starter — glhperformance | Forum — Clutch/Drive Train/Belt (Swapmeet) | Replies — 0 | Last Post — 09-09-2014 01:54 PM |
Thread — 07 800r primary clutch | Thread Starter — Twisted Tunnel | Forum — Clutch/Drive Train/Belt (Swapmeet) | Replies — 1 | Last Post — 03-07-2014 11:52 AM |
Thread — 800r xp primary clutch | Thread Starter — glhperformance | Forum — Clutch/Drive Train/Belt (Swapmeet) | Replies — 0 | Last Post — 12-06-2013 06:28 PM |
Thread — First Timers Primary Clutch Update & Report (800r '07) | Thread Starter — brahm | Forum — Ski-Doo: REV Sleds | Replies — 9 | Last Post — 11-18-2009 02:04 AM |
Thread — 08 800R primary weight add/removal question...?? | Thread Starter — JLeosnow | Forum — Ski-Doo | Replies — 2 | Last Post — 03-26-2008 08:47 PM |
