Upgrade to Premium
Reply
  #1
Old 01-25-2018, 06:04 PM
Lander's Avatar
Lander Lander is online now
Currently: Bad day in the Mardes is better than a good day anywhere else.
Lander has a reputation beyond reputeLander has a reputation beyond reputeLander has a reputation beyond reputeLander has a reputation beyond reputeLander has a reputation beyond reputeLander has a reputation beyond reputeLander has a reputation beyond reputeLander has a reputation beyond reputeLander has a reputation beyond reputeLander has a reputation beyond reputeLander has a reputation beyond repute
Default XM RER/Headlight Module Conversion
I broke the entire housing of the RER/headlight module on my 2015 T3, which is about $200 to replace, so I am wondering if I can just replace it with the GEN 4 RER button, which is only $60? I could care less about the headlight dimmer being there so I'd just wire into the bright mode.
Rate this post: Yes | No
  #2
Old 01-25-2018, 06:37 PM
BeachSled's Avatar
BeachSled BeachSled is offline
Currently: Not set.
BeachSled has a reputation beyond reputeBeachSled has a reputation beyond reputeBeachSled has a reputation beyond reputeBeachSled has a reputation beyond reputeBeachSled has a reputation beyond reputeBeachSled has a reputation beyond reputeBeachSled has a reputation beyond reputeBeachSled has a reputation beyond reputeBeachSled has a reputation beyond reputeBeachSled has a reputation beyond reputeBeachSled has a reputation beyond repute
Default
The G4 switch will not work (I have been down this road already)
The G4 switch is 2 wire and the XM switch is 3 wire.
  #3
Old 01-25-2018, 06:40 PM
BeachSled's Avatar
Currently: Not set.
Default
You can look at my posts on these two threads. This is how I went about changing the left hand control.
http://www.dootalk.com/forums/topic/...dlebar-spaces/
http://www.dootalk.com/forums/topic/...switch-wiring/
The Following User Says Thank You to BeachSled For This Useful Post:
Lander (01-25-2018)
  #4
Old 01-25-2018, 09:04 PM
Lander's Avatar
Default
Will the RSI rocker switch work for the headlight relocate or can you send me an Amazon link for both switches I would need for relocating to the console. Why Ski Doo waited so long to do this on MTN sleds is beyond me.
  #5
Old 02-07-2018, 10:20 PM
Lander's Avatar
Default
My solution was to re-use the RER switch since it was still good. I removed the black trim pieces and cut-out (accidentally upside down) the RER switch with a utility knife, and used drill for the new headlight switch (it's actually an RSI grip heater switch but it allows you to turn the headlight completely off). There are already perfectly placed cut-outs in the plastics underneath, so apparently Ski Doo had pre-planned for people breaking off a $200 switch pod? The process was simple and just had to use a few butt splices for the rerouting.
Click image for larger version
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following 2 Users Say Thank You to Lander For This Useful Post:
Blk88GT (02-08-2018), slinky (02-09-2018)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — xm rer and headlight switch on xp Thread Starter — t-rev8 Forum — Ski-Doo: XP Sleds Replies — 1 Last Post — 11-29-2013 11:27 AM
Thread — yamaha hid headlight conversion Thread Starter — sxr1000 Forum — Yamaha: 4-Stroke Replies — 1 Last Post — 10-08-2011 06:44 PM
Thread — WTB Calibration Module for 2004 REV 800 H.O. w/DPM & RER Thread Starter — snomoguy Forum — WTB (Swapmeet) Replies — 0 Last Post — 04-27-2010 07:11 AM
Thread — Want to relocate your warmers/light/RER module? Thread Starter — enis750 Forum — Ski-Doo: REV Sleds Replies — 13 Last Post — 10-27-2009 10:50 AM
Thread — 2001 Summit 800 RER conversion question Thread Starter — Heavysledz Forum — Ski-Doo Replies — 4 Last Post — 05-30-2008 01:29 PM
no new posts
