Upgrade to Premium
Polaris: TURBO Turbo discussion for Polaris aftermarket turbo sleds
Reply
  #1
Old 01-24-2018, 06:58 PM
sumtinwong sumtinwong is offline
Currently: Not set.
Basic Member
sumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond repute
Default TPI 911 Response Clutch Cover
just wondered if any one has used one and what their thoughts were on them? seems like a good deal minus the weight, I just worry about how long I got before a rebuild on the primary is a must and I like that it can adjust the sheave clearance as the belt wears or if I choose to get a different belt without opening the clutch up. and well 250% more bushing wouldn't hurt ether! 911 Response Clutch Cover
$249.95
Rate this post: Yes | No
  #2
Old 01-24-2018, 10:35 PM
mtncat1's Avatar
mtncat1 mtncat1 is offline
Currently: waiting for snow
mtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond reputemtncat1 has a reputation beyond repute
Default
imo they are a waste of money ,they came out as a solution to cats crappy clutches ,polaris clutching works so no need for this product
__________________
2013 163 X3 silber turbo,
  #3
Old 01-25-2018, 10:37 AM
BILTIT's Avatar
BILTIT BILTIT is online now
Currently: Never enough snow!!!
BILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond reputeBILTIT has a reputation beyond repute
Default
They are well worth the money, just for adjustable belt-sheave clearance alone!
__________________
Derek B.
2000 440 xc sp 136 (EDGE)
2003 800 RMK 162
2004 910 PRO-XR 121x1.75", Wheelie Machine!!!
2011 LRod 13.6 800 ProRMK 3"PC KMOD/Raptors kmod 37" arms Ti can
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #4
Old 01-25-2018, 01:53 PM
Currently: Not set.
Basic Member
Default
  #5
Old 01-25-2018, 03:13 PM
Snowmow's Avatar
Snowmow Snowmow is online now
Currently: Not set.
Snowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond reputeSnowmow has a reputation beyond repute
Default
http://www.boondockers.com/index.php...e-clutch-cover
  #6
Old 01-25-2018, 03:16 PM
Snowmow's Avatar
Currently: Not set.
Default
http://patrickcustomcarbon.com/index...oduct_id=29778
  #7
Old 01-25-2018, 03:50 PM
LoudHandle LoudHandle is offline
Currently: I'd rather snowshoe than be caught on a SKIDOO! I'm not feminine / gay enough to ride SkiDoo either.
LoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond reputeLoudHandle has a reputation beyond repute
Default External adjustment; a fix to a non-exsistant problem with proper clutching
The issue with externally adjusting belt to sheeve clearance is; it messes with all the other variables in the clutch.
Utilizing an external adjustment will change the Spring Force as well as where the weight contacts the roller. So while you may get the belt to sheeve correct, IMO it changes everything else in a counterproductive way. If you're not picky about your clutching / performance then it may be a good fit for you. It will cause most to chase their tail and is not worth the hassle. If you got a machine that eats belts bad enough to really use the external adjustment you got far bigger issues to rein in and get under control than "Deflection".
In my opinion the best Value is the; ZRP cover
Ibexx also makes one that is similar and slightly lighter but the quality of the machining is a little rough IMO and probably is 6061-T6 which is a fair margin weaker (than the 7075-T6 of the ZRP cover) and due to the Ibexx tri-lobe design will flex far more than it should, which will result in binding and premature wear.
__________________
ALASKA
The Following 2 Users Say Thank You to LoudHandle For This Useful Post:
Snowmow (01-25-2018), sumtinwong (01-25-2018)
  #8
Old 01-25-2018, 06:17 PM
Currently: Not set.
Basic Member
Default
the only other clutch cover that addressed what I was originally looking for was indy dans as he was the only other one that increased the cap bushing size! all of the covers help to make the towers hold together in a more ridged fashion but don't address the other problems of these clutches. all do a good job by adding strength to them witch we need but I was trying to increase the over all life be for a rebuild is needed also!
I understand what you are saying about how it can effect things but I don't think the few MM that we might need to adjust on sheave clearance will have much if any adverse effect. we all set belt deflection constantly or at least those of us who are picky about our clutching but just deal with the sheave clearance getting worse and worse until we blow the belt or just toss it. most of us set the sheave to our kits or factory specks to start because it can make a big difference. the sheave clearance is just the other half of belt deflection IMO. and would be nice to adjust it with the deflection. I can understand how if it was off from the start and we just used the adjuster to make it right it might move everything enough to start having adverse effects but it should be set correct from the start and work a few MM in from their to avoid it getting wonky... again just my thoughts but every one I have talked to said they love them and just keep taking them off their last sled and putting them on the new one but then again I only talked to 2 people that have used them but nether has mentioned this problem?
  #9
Old 01-26-2018, 04:20 PM
AKFULLTHROTTLE's Avatar
AKFULLTHROTTLE AKFULLTHROTTLE is offline
Currently: Waiting for my Polaris 850!
AKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond repute
Default
Dans cover is slightly heavier than a stock. The added strength keeps it from flexing under load. Also the quick change bushing is super nice but I have had zero issues with the different bushing as well. Holding up very well.
As said, the ZRP can flex causing bind as well..
__________________
Full Throttle Customs
Alaska Silber Turbos Dealer
http://www.silberturbos.com/
0 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to AKFULLTHROTTLE For This Useful Post:
sumtinwong (01-26-2018)
  #10
Old 01-26-2018, 07:59 PM
icr icr is offline
Currently: on another forum
Basic Member
icr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond reputeicr has a reputation beyond repute
The Following User Says Thank You to icr For This Useful Post:
budha (04-21-2018)
  #11
Old 01-29-2018, 09:57 AM
Click Here to Register
  #12
Old 01-29-2018, 01:02 PM
icr icr is offline
Basic Member
  #13
Old 01-29-2018, 02:41 PM
Currently: Not set.
Basic Member
The Following 2 Users Say Thank You to sumtinwong For This Useful Post:
AKFULLTHROTTLE (01-29-2018), Snowmow (01-29-2018)
  #14
Old 01-29-2018, 03:10 PM
icr icr is offline
Basic Member
  #15
Old 01-29-2018, 04:26 PM
BILTIT's Avatar
  #16
Old 01-29-2018, 06:24 PM
Currently: Not set.
Basic Member
The Following User Says Thank You to sumtinwong For This Useful Post:
  #17
Old 01-29-2018, 06:28 PM
  #18
Old 01-29-2018, 08:23 PM
icr icr is offline
Basic Member
  #19
Old 01-29-2018, 08:36 PM
The Following 3 Users Say Thank You to LoudHandle For This Useful Post:
guidoxpress (05-25-2018), Reeb (02-21-2018), Snowmow (01-29-2018)
  #20
Old 01-29-2018, 08:42 PM
Currently: Not set.
Basic Member
  #21
Old 01-29-2018, 08:58 PM
Snowmow's Avatar
Currently: Not set.
  #22
Old 01-29-2018, 08:59 PM
Currently: Not set.
Basic Member
alt (02-02-2018), Snowmow (01-29-2018)
  #23
Old 01-29-2018, 09:03 PM
Snowmow's Avatar
Currently: Not set.
  #24
Old 01-29-2018, 09:14 PM
icr icr is offline
Basic Member
  #25
Old 01-29-2018, 09:49 PM
Currently: Not set.
Basic Member
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — has any one used TPI 911 Response Clutch Cover Thread Starter — sumtinwong Forum — Polaris: AXYS Replies — 24 Last Post — 02-28-2018 01:49 PM
Thread — Team Secondary,MDS weights,TPI 911 cover for a 800 Pro Climb---SOLD Thread Starter — 1100Cat Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 1 Last Post — 09-26-2012 12:09 PM
Thread — Hi-tech 911 Response Cover P-85 Thread Starter — Angermangement890 Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 1 Last Post — 09-16-2011 06:54 PM
Thread — 911 Response Clutch Cover Thread Starter — cook_beef Forum — Arctic Cat: M Series Replies — 1 Last Post — 11-28-2010 08:31 PM
Thread — 911 clutch cover Thread Starter — KDD Forum — Polaris: IQR Replies — 4 Last Post — 10-21-2010 03:45 PM
no new posts
