Upgrade to Premium
Reply
  #1
Old 01-24-2018, 12:56 PM
Marcusx200 Marcusx200 is offline
Currently: Not set.
Basic Member
Marcusx200 is an unknown quantity at this point
Default Primary clutch marks
Ive forget to do own marks does anyone know how the standard marks works?
Ive got these marks . My concern is the inner shave mark is has one one the back and one on the top (a square/diamond) stanced . Which to use? Ive tested the one "behind" and i saw lot of vibrations
Rate this post: Yes | No
  #2
Old 01-24-2018, 10:56 PM
Goinboardin's Avatar
Goinboardin Goinboardin is online now
Currently: ..current
Goinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond reputeGoinboardin has a reputation beyond repute
Default
Your post is a little unclear, but I think you're asking about the alignment marks on the primary clutch parts. There are several. The small circle on the movable sheave is aligned to the arrow on the spring cup & the governor cup. With those three parts assembled together, align their mark with the small notch on the backside of the fixed sheave. Then for clutch install, the crank itself has a line on it's end; the larger circle on the movable sheave aligns with that.
Hope that helps. If you're seeing different marks on the clutch, please clarify the year & model of your sled.
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #3
Old 01-28-2018, 12:22 AM
Default
I had my clutch off today, thought these pictures might help. The first two show the external markings that are used to align the clutch parts to one another. Not pictured is the arrow on the spring cup (out of sight under the governor cup in the pictures). The second two show how the clutch gets clocked to the crank, and what the mark on the crank looks like on my 13' Etec (reman crank actually, but original was the same).
Click image for larger version
ID:	292228   Click image for larger version
ID:	292229   Click image for larger version
__________________
2013 XM 800 153
The Following User Says Thank You to Goinboardin For This Useful Post:
Covelli44 (04-17-2018)
  #4
Old 01-30-2018, 09:17 PM
BigAir's Avatar
BigAir BigAir is offline
Currently: Still missin' the old SnoWest
BigAir has a reputation beyond reputeBigAir has a reputation beyond reputeBigAir has a reputation beyond reputeBigAir has a reputation beyond reputeBigAir has a reputation beyond reputeBigAir has a reputation beyond reputeBigAir has a reputation beyond reputeBigAir has a reputation beyond reputeBigAir has a reputation beyond reputeBigAir has a reputation beyond reputeBigAir has a reputation beyond repute
Default
So you don't line up the arrow with the mark on the crank? You line up the large circle with the mark on the crank? I might need to pull mine and reclock it.
__________________
You must always push the limits, because if you never fail then you will never succeed.
'16 T3
'08 M1000
The Following User Says Thank You to BigAir For This Useful Post:
scummit8 (10-23-2018)
  #5
Old 01-31-2018, 08:38 AM
Currently: Not set.
Basic Member
Default
Thanks for reply. The one Thing that is weird is this spring cup holder mark . Look at this discription it tells u to not use the small ring to cup arrow.. right picture "notch"
The Following User Says Thank You to Marcusx200 For This Useful Post:
  #6
Old 01-31-2018, 11:12 AM
Default
Quote:
Good catch! I stand corrected. I re-read the manual myself and see that now. I don't suspect that (the spring cup index) matters as much as proper clutch/crank indexing, but good to know.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Primary clutch alignment marks Thread Starter — Mayz07 Forum — Arctic Cat: M Series Replies — 4 Last Post — 01-28-2017 01:04 PM
Thread — Marks on primary clutch Thread Starter — ENDO1 Forum — Polaris: Pro-Ride Replies — 10 Last Post — 02-19-2013 10:33 PM
Thread — Black marks on Primary clutch Thread Starter — avossler Forum — Arctic Cat: M Series Replies — 2 Last Post — 01-29-2011 06:31 PM
Thread — marks in primary clutch ok? Thread Starter — wowgogs Forum — Ski-Doo: XP Sleds Replies — 4 Last Post — 03-01-2010 11:26 AM
Thread — black marks on primary clutch?? Thread Starter — garciava Forum — Arctic Cat Replies — 15 Last Post — 12-30-2008 05:55 PM
no new posts
