Upgrade to Premium
Polaris: EDGE 2002-2005, all models in the Edge chassis
Reply
  #1
Old 01-22-2018, 06:14 PM
nowready05 nowready05 is offline
Currently: Looking for a Union Bay 1150 sled...
Basic Member
nowready05 is an unknown quantity at this point
Default Need Some Front End Help on 2004 Pro-X
I have a 2004 Polaris Pro-x sled. Installed is VanAmberg tunnel, custom Edge rear suspension with Ride-EFX shocks, 162x15x2.5 track SLP Powder Pro skis, etc. My problem is that the front end or skis seem to be hunting and not tracking very well. Seems like the skis are not digging into the snow very well. So the question is how can I get more weight transferred to the front skis? Set the front shocks to the lightest setting and ?
Thanks for your replies.
Rate this post: Yes | No
  #2
Old 01-23-2018, 08:58 AM
thefullmonte's Avatar
thefullmonte thefullmonte is offline
Currently: Pura Vida
thefullmonte has a reputation beyond reputethefullmonte has a reputation beyond reputethefullmonte has a reputation beyond reputethefullmonte has a reputation beyond reputethefullmonte has a reputation beyond reputethefullmonte has a reputation beyond reputethefullmonte has a reputation beyond reputethefullmonte has a reputation beyond reputethefullmonte has a reputation beyond reputethefullmonte has a reputation beyond reputethefullmonte has a reputation beyond repute
Default
Sounds like a pretty cool sled. You should post up some pics.
Is this happening mostly on the trail? The ski width of the Edge chassis was pretty common and not unusual for it to follow other tracks.
That being said I would check the usual suspects, ski alignment, toe out and camber. As for more ski pressure you might actually try pre-loading the front ski springs more. Keep in mind that this is all a balancing act. Adding more pressure can make it harder to roll over as well. If you have removed your sway bar this may be a non-issue anyway.
I'm not sure what your rear suspension is like. You might want to check where your limiter straps are positioned. The higher up they are positioned the more ski pressure you will have.
I'm sure you're going to have a some trial and error with that setup, but I hope I gave you a few ideas anyway.
__________________
[SIGPIC][/SIGPIC]
  #3
Old 01-24-2018, 02:20 PM
whoisthatguy's Avatar
whoisthatguy whoisthatguy is offline
Currently: Not set.
whoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond reputewhoisthatguy has a reputation beyond repute
Default
Tighten up the front limiter straps to put more pressure on the skis, and reduce powder performance.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2004 Rev front end width Thread Starter — yz400ex Forum — Ski-Doo: REV Sleds Replies — 2 Last Post — 08-31-2014 02:26 PM
Thread — Will '13 Assault front end bolt up to Pro front end? Thread Starter — snowracer21 Forum — Polaris: Pro-Ride Replies — 9 Last Post — 10-16-2013 12:36 PM
Thread — 2004 Pro-x 600 low end bog Thread Starter — motocrazy2006 Forum — Polaris: EDGE Replies — 2 Last Post — 02-22-2013 12:20 PM
Thread — Want to trade 2011 M8 HCR Front Suspension for Sno Pro Front End Thread Starter — snowmobilesnowman Forum — Suspension/Shocks (Swapmeet) Replies — 0 Last Post — 12-15-2011 07:28 PM
Thread — 2004 rev front end parts complete Thread Starter — ALTITUDE SICKNESS Forum — Suspension/Shocks (Swapmeet) Replies — 2 Last Post — 01-27-2009 09:56 PM
no new posts
