Upgrade to Premium
Ski-Doo: TURBO Turbo discussion for Ski-Doo aftermarket turbo sleds
Reply
  #1
Old 01-22-2018, 08:13 AM
Marcusx200 Marcusx200 is offline
Currently: Not set.
Basic Member
Marcusx200 is an unknown quantity at this point
Default Reeds t3 800
Hi , just checked my reeds because it dies when u hit reverse when its cold and it feels slower and afr are weird.
On both side one flap is Open 1mm (you can see light thru them) could this be the cause? No other damages
Rate this post: Yes | No
  #2
Old 01-22-2018, 08:39 AM
fredw fredw is offline
Currently: 850 blown up before Breakin over
Basic Member
fredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond repute
Default
I have had the same thing happen with mine in past, but it seams to still run fine up top and idles fine, do you have any sunlight between the two haves? Pedals?
Engine burp, cough and the worst a engine over rev can send hot charge temps back quick and warp pedals, and reeds
Sometimes just swapping reeds around will close gap and get another season threw them
  #3
Old 01-22-2018, 09:57 AM
Currently: Not set.
Basic Member
Default
Yes i see sunlight in the reeds . Yes it have been overevving
  #4
Old 01-22-2018, 10:38 AM
Basic Member
Default
Well than you need to swap around or replace them, but you better also fix initial problem of over rev.. make sure you have enough gear, so you have a little grace if rpm spikes
Toms arms from Toms snowmobile allow you to control weight distribution with in the arm, he says another advantage is this allows less chance of a over rev, so far worked fine for myself, up to ten lbs.. but I did cook a set when blowing a new doo belt last year.. cages got so hot they were warped, I was lucky to get sled off hill with out air support
  #5
Old 01-23-2018, 04:15 AM
Currently: Not set.
Basic Member
Default
Ive Think i found the issue for overev when i changed spring in secondary ,i didnt know that that belt adjuster was an adjuster so i just turned all the way in resulting in belt very "high" , resulting in less belt on primary resulting in not to move all the way up on primary , i think?
  #6
Old 01-24-2018, 09:58 PM
skank skank is online now
Currently: Not set.
skank has a reputation beyond reputeskank has a reputation beyond reputeskank has a reputation beyond reputeskank has a reputation beyond reputeskank has a reputation beyond reputeskank has a reputation beyond reputeskank has a reputation beyond reputeskank has a reputation beyond reputeskank has a reputation beyond reputeskank has a reputation beyond reputeskank has a reputation beyond repute
Default
If your belt is too tight and sitting too high in the secondary it will die everytime you try to put it in reverse.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 700 RMK reeds vs. 800 XCR reeds Thread Starter — redneckracer280 Forum — Polaris: GEN 2 Replies — 2 Last Post — 11-17-2012 10:35 PM
Thread — 800 HO Reeds Thread Starter — silverbacks Forum — Carb/Airbox/Reeds (Swapmeet) Replies — 0 Last Post — 09-08-2012 03:05 PM
Thread — Reeds on the PC 800? Thread Starter — ekingland Forum — Arctic Cat: Proclimb M Replies — 4 Last Post — 12-01-2011 02:54 PM
Thread — 800 HO reeds Thread Starter — toesout Forum — Carb/Airbox/Reeds (Swapmeet) Replies — 1 Last Post — 01-24-2008 06:50 PM
Thread — 800 H.O. Reeds on a Non H.O. Motor? Thread Starter — cjfarm11 Forum — Ski-Doo Replies — 0 Last Post — 12-11-2007 02:11 PM
no new posts
