Upgrade to Premium
Polaris: IQ 2005-Current, all models in the IQ and IQ Raw chassis
Reply
  #1
Old 01-20-2018, 06:19 PM
Rodger Rodger is offline
Currently: Not set.
Basic Member
Rodger is an unknown quantity at this point
Default Need help with 2008 RMK 700 rough idle and bogging
I have a 2008 RMK 700 that halfway through aride started running rough and bogging at low end. Still ran strong if you could get to WOT. Then it progressively got worse and would bod when you hit the throttle from an idle. If you turn it off and start it back up it will idle for about a minute then start increasing rpm, start running rough and die. I have replaced the fuel filter, the air intake boot that was separated so I thought that was the smoking gun, and inspected the Reed valves. Put it all back together and no change. Anyone else experience this? Just for kicks I did a compression test and both cylinders we're above 120.
Rate this post: Yes | No
  #2
Old 01-24-2018, 07:15 PM
Currently: Not set.
Basic Member
Default 2008 RMK 700
Well if anyone ever has the same issue it was a bad fuel pump. Started at 40 psi and rapidly started dropping off until just under 30 it stalled from lack of fuel.
The Following 2 Users Say Thank You to Rodger For This Useful Post:
retiredpop (01-24-2018), snoboy (03-13-2018)
  #3
Old 03-13-2018, 02:57 PM
snoboy snoboy is offline
Currently: getting it together
snoboy has a reputation beyond reputesnoboy has a reputation beyond reputesnoboy has a reputation beyond reputesnoboy has a reputation beyond reputesnoboy has a reputation beyond reputesnoboy has a reputation beyond reputesnoboy has a reputation beyond reputesnoboy has a reputation beyond reputesnoboy has a reputation beyond reputesnoboy has a reputation beyond reputesnoboy has a reputation beyond repute
Default
Thanks for the info.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Need help with 2008 RMK 700 rough idle and bogging Thread Starter — Rodger Forum — New Member Introductions Replies — 0 Last Post — 01-20-2018 06:05 PM
Thread — 2008 Polaris 700 RMK bogging out Thread Starter — jman94 Forum — Polaris: IQ Replies — 6 Last Post — 03-10-2015 01:52 PM
Thread — 01 ZX rough idle Thread Starter — sledheadkev Forum — Ski-Doo: ZX Sleds Replies — 12 Last Post — 02-22-2012 01:12 PM
Thread — rough idle and coughing Thread Starter — bustamove Forum — Ski-Doo: REV Sleds Replies — 0 Last Post — 01-02-2011 07:41 PM
Thread — running rough 04' 700 rmk Thread Starter — tweber Forum — Polaris Replies — 1 Last Post — 01-10-2008 12:12 AM
