Upgrade to Premium
Polaris: 900 05-06 Polaris RMK 900
Reply
  #1
Old 01-17-2018, 01:40 PM
topstitch1 topstitch1 is offline
Currently: Not set.
Basic Member
topstitch1 is an unknown quantity at this point
Default 06 700 rmk bog and stutter. Had tps checked
So! Im stuck. No engine lights on, idles great, goes into reverse. Will run good for a minute or so sometimes longer. Then anything above 4500rpm gets a major bog. It will actually kill the motor if you stay on the throttle. Shut it off and it restarts perfect. Comp is 135 on both. New tps in it. Did find some melted wires for air intake, repaired them no change. Plugs have decent fuel on them, so i dont think its s fuel issue. It has all the symptoms of tps. But that has been replaced and triple checked, also checked harness for it. Any ideas? I need a real guru on this one. It has two different dealerships stumped.
Rate this post: Yes | No
  #2
Old 01-17-2018, 01:49 PM
Currently: Not set.
Basic Member
Default
Power valves cleaned and checked. Seems to be heat and electrical related.
  #3
Old 02-01-2018, 04:24 AM
Ole Andre Ole Andre is offline
Currently: Not set.
Ole Andre has a reputation beyond reputeOle Andre has a reputation beyond reputeOle Andre has a reputation beyond reputeOle Andre has a reputation beyond reputeOle Andre has a reputation beyond reputeOle Andre has a reputation beyond reputeOle Andre has a reputation beyond reputeOle Andre has a reputation beyond reputeOle Andre has a reputation beyond reputeOle Andre has a reputation beyond reputeOle Andre has a reputation beyond repute
Default
could it be injector related?
you have two injectors for each sylinder. somewhere arround 5000 the "main" injector takes over.
Replaced fuel filter allready I guess?
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Exhaust bog or tps? Thread Starter — springcreek338 Forum — Polaris: Pro-Ride Replies — 5 Last Post — 02-06-2014 07:28 PM
Thread — Irregular WOT Bog, TPS?? Thread Starter — stem Forum — Polaris: Pro-Ride Replies — 28 Last Post — 01-17-2014 12:33 PM
Thread — 700 fusion tps question/low speed bog Thread Starter — TriumphoverU Forum — Polaris: 900 Replies — 18 Last Post — 02-12-2012 11:20 PM
Thread — TPS on 900's checked at closed throttle position. Thread Starter — ttreewalkerr Forum — Polaris: 900 Replies — 1 Last Post — 09-14-2011 01:36 PM
Thread — 09 m1000 stutter or bog low rpms Thread Starter — snapperm7 Forum — Arctic Cat: M Series Replies — 10 Last Post — 01-11-2010 09:55 PM
no new posts
