Upgrade to Premium
Yamaha: Boosted Sleds (Turbo or Supercharged) Turbo discussion for Yamaha aftermarket Turbo or Super Charged sleds.
Reply
  #1
Old 01-16-2018, 11:24 PM
quadtrac quadtrac is offline
Currently: Burning AV-GAS!
quadtrac quadtrac quadtrac quadtrac quadtrac quadtrac quadtrac quadtrac quadtrac quadtrac quadtrac
Default MPI Nytro PsychoSled Questions
First off is PsychoSled still in business? I have a 2011 MPI turbo nytro running his power commander/wideband setup on it. Have a couple questions for anybody that might know... Wanted to take a look at some of the gauges and just confirm everything is correct. At warm idle I'm seeing these values: 18% throttle, 14.64 afr, 6% duty, -47.1 engine temp, 33 fuel Adj, and 14.65 pressure. Im wondering why its saying 18% throttle at idle and also -47.1 engine temp? Also when it fully warms up it seems to want to idle kinda slow... Around 1000-1200 rpm. Any thoughts on this much appreciated!
Rate this post: Yes | No
  #2
Old 01-18-2018, 12:13 AM
Default
Few pics ...
Click image for larger version
ID:	291610   Click image for larger version
  #3
Old 01-18-2018, 01:19 AM
cbouton cbouton is offline
Currently: Waiting for more snow
cbouton has a reputation beyond reputecbouton has a reputation beyond reputecbouton has a reputation beyond reputecbouton has a reputation beyond reputecbouton has a reputation beyond reputecbouton has a reputation beyond reputecbouton has a reputation beyond reputecbouton has a reputation beyond reputecbouton has a reputation beyond reputecbouton has a reputation beyond reputecbouton has a reputation beyond repute
Default
Can't remember all the values but I know 14.6 afr at idle is fine. If you haven't calibrated the throttle body sensor in the PC software yet it's a good time to do that.
Are you curious of the numbers because the machine is running bad/ low idle?
As for low idle check for any boost leaks/vacuum line leaks (on throttle bodies) and fresh gas and new set of plugs and see if that helps your idle. I'm betting vacuum line leak or fouled plugs. Mine idles low when I start too foul a plug
  #4
Old 01-18-2018, 07:03 PM
julio julio is offline
Currently: thinking fishing while waiting for snow
Basic Member
julio has a reputation beyond reputejulio has a reputation beyond reputejulio has a reputation beyond reputejulio has a reputation beyond reputejulio has a reputation beyond reputejulio has a reputation beyond reputejulio has a reputation beyond reputejulio has a reputation beyond reputejulio has a reputation beyond reputejulio has a reputation beyond reputejulio has a reputation beyond repute
Default low idle
cant say for the rest but check your belt deflection as well if its a bit tight it will idle low when warm. the warm up cycle can overcome this with the extra gas it gives.. julio
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Extended warranty questions on MPI 190 hp Viper MTX Thread Starter — RMKing1 Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 2 Last Post — 05-01-2016 08:21 AM
Thread — PsychoSled Low/Mid Boost Fuel Bridge For Nytro Thread Starter — MotoPsycho Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 134 Last Post — 04-25-2014 09:16 AM
Thread — Just saw this from Psychosled Industries. Thread Starter — sledheadd Forum — Nytros! Replies — 30 Last Post — 03-23-2014 02:21 PM
Thread — Review and Installation: PsychoSled "Super Secret Squirrel" Nytro Clutch Thread Starter — christopher Forum — Yamaha: Product Reviews and Installs Replies — 80 Last Post — 03-11-2014 06:04 PM
Thread — MPI Nytro install questions Thread Starter — painterdrew Forum — Yamaha: Boosted Sleds (Turbo or Supercharged) Replies — 3 Last Post — 11-15-2009 10:58 PM
no new posts
