Upgrade to Premium
Polaris: IQ 2005-Current, all models in the IQ and IQ Raw chassis
Reply
  #1
Old 01-15-2018, 05:32 PM
RTBS RTBS is offline
Currently: Not set.
RTBS is an unknown quantity at this point
Default Fuel injector good or bad???
Putting a motor in a chassis on a RMK dragon CFI that I bought. The chassis came with the fuel rails and injectors. I was looking at the fuel injectors and noticed one of them had a dent in the shaft that inserts into the motor. Here is a pic. I have never taken one apart or cut them not sure if its a hollow tube inside. Any thoughts if you think it needs to be replaced.
Click image for larger version
Rate this post: Yes | No
  #2
Old 01-15-2018, 06:13 PM
XCaSSAULT's Avatar
XCaSSAULT XCaSSAULT is online now
Currently: Go MN Wild!
XCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond reputeXCaSSAULT has a reputation beyond repute
Default
Good find. Yeah I’d say replace it. Why chance it. They are expensive. You could have it flow tested but how do you find out what the flow is suppose to be? Make sure your replace it with correct color (red,blue or yellow) that the others are.
  #3
Old 01-15-2018, 09:37 PM
volcano buster volcano buster is online now
Currently: Not set.
volcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond reputevolcano buster has a reputation beyond repute
Default
Your ECM should have a color designation on it too. Mine are yellow and it states that in print on the label.
  #4
Old 01-15-2018, 10:05 PM
Currently: Not set.
Default
Thanks I haven't checked the color but will. I had a buddy say there is a plastic piece inside and was thinking that maybe just the outer metal cover is dented he thought it would be okay but wanted to see what others thought.
Sent from my SM-G930V using Tapatalk
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2011 M8 bad injector? Thread Starter — Rock Hound Forum — Arctic Cat: M Series Replies — 1 Last Post — 01-22-2015 11:23 AM
Thread — Bad injector? Thread Starter — Snowhood Forum — Polaris: 900 Replies — 3 Last Post — 02-13-2013 10:44 PM
Thread — 09 m8, bad injector? Thread Starter — Octanee Forum — Arctic Cat: M Series Replies — 6 Last Post — 12-26-2012 10:52 AM
Thread — Bad injector? Thread Starter — genoM8 Forum — Arctic Cat: M Series Replies — 8 Last Post — 04-04-2011 08:31 AM
Thread — M-1000 Bad Injector? Thread Starter — longtracksedge Forum — Arctic Cat: M Series Replies — 3 Last Post — 02-03-2011 12:48 PM
no new posts
