Upgrade to Premium
Polaris: TURBO Turbo discussion for Polaris aftermarket turbo sleds
Reply
  #1
Old 01-15-2018, 10:50 AM
niner's Avatar
niner niner is offline
Currently: loving my MTNTK turbo
niner has a reputation beyond reputeniner has a reputation beyond reputeniner has a reputation beyond reputeniner has a reputation beyond reputeniner has a reputation beyond reputeniner has a reputation beyond reputeniner has a reputation beyond reputeniner has a reputation beyond reputeniner has a reputation beyond reputeniner has a reputation beyond reputeniner has a reputation beyond repute
Default 174 MTNTK turbo pro (10 lbs) VS 174 sidewinder
https://youtu.be/4wQd-4ReQAU
A little comparison. Pretty happy. Those sidewinders are fast.
Rate this post: Yes | No
  #2
Old 01-25-2018, 11:24 PM
sumtinwong sumtinwong is offline
Currently: Not set.
Basic Member
sumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond reputesumtinwong has a reputation beyond repute
Default
what elevation was that at? and did he have work dun on the sidewinder? tune/clutches/pipe.exc.
I ask because im riding with a buddy that has a 2018 sidewinder btx 153 2.25 and we are running 0-4000ft I have a 2016 assault silber at 5 pounds indy dans clutch kit and I am wiping his a$$! we haven't got to the big end of things yet but we keep thinking that's where he will make up grounds
  #3
Old 01-26-2018, 11:16 AM
Octanee Octanee is offline
Currently: Not set.
Octanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond reputeOctanee has a reputation beyond repute
Default
I also wonder that as well for mods, the lighter weight pro and at 10# should out pull the stock sidewinder. But if the sidewinder had... The mcx tune then I could see it performing like that.
  #4
Old 01-26-2018, 02:00 PM
Currently: Not set.
Basic Member
Default
yea I hear with a re-flash those SideWinders can get turned up over 400 HP THATS NUTS! we have found the clutching to be horrible it is absolutely the worst bottom end we have ever hade the pleasure of trying to fix! another buddy has a NA 4strok (2015 don't remember witch one} but it is rated at 130-135 HP and that sidewinder doesn't leave that sled in a race until they are doing about 30 its just silly all those ponies and they cant get them thru the drivetrain...we are working on the clutching on the SideWinder but it is proving to be a b!t(h at best...they are a lot more finicky than I thought they would be takes a wile for the turbo to spool up....I wonder if that's why they hade a rolling start on the clime it didn't sound like they got on it from the start.
  #5
Old 01-26-2018, 04:32 PM
AKFULLTHROTTLE's Avatar
AKFULLTHROTTLE AKFULLTHROTTLE is offline
Currently: Waiting for my Polaris 850!
AKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond reputeAKFULLTHROTTLE has a reputation beyond repute
Default
With out knowing what HP level that Yam is running.. The Pro on 10 is like a Axys on 5.
__________________
Full Throttle Customs
Alaska Silber Turbos Dealer
http://www.silberturbos.com/
  #6
Old 01-26-2018, 06:56 PM
Currently: Not set.
Basic Member
Default
wow that's a drastic change! 10 pounds to get 200+ hp nutty
  #7
Old 01-26-2018, 09:21 PM
live2beel live2beel is offline
Currently: Not set.
live2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond reputelive2beel has a reputation beyond repute
Default
Rolling start definitely helps the Yamaha. Stick them both in fresh with no tracks and try again.
  #8
Old 01-29-2018, 11:07 AM
niner's Avatar
Default
Elevation is around 7500’
Sidewinder is running stock tune, stock clutching and a Cr straight pipe ( claimed 15 hp gain)
I’m running 76 gram lightning weights in the pro.
My sled kills a Axys running on 5 lbs.
We did a rolling start to minimize variables.
The sidewinder has track speeds in the 55 mph range and mine in the low 50’s mph track speeds.
Both sleds have 174 X3 tracks. Both have Baker skids.
Sidewinders up here are running very fast on the hills. I was pretty happy to see how close they are. Snow was in the 12”-18” of fresh. When it gets deeper mine should get closer.
The Following User Says Thank You to niner For This Useful Post:
sumtinwong (01-29-2018)
  #9
Old 01-29-2018, 03:45 PM
Currently: Not set.
Basic Member
Default
it must be the elevation like I said I ride with a 2018 sidewinder btx 153 I have a 2016 axys assault 155 800 silber turbo 5 pounds, indy dans low elevation clutching and I am putting him to shame! so bad he just dropped close to a grand on clutching to spruce it up! we have ben riding at 1500-2500 ft so far this year but I know that the sidewinder will produce a constant HP at all elevations and has a intercooler to accommodate the bigger boost temps... is yours intercooled? at 10 pounds im sure the intercooler is needed for your charge temps. like I said above we have not got in to any big/long pulls just short ones like the vid you posted and we have not tried a rolling start ether! but it has ben no competition yet but we are going to fix that! one way or the other. the SW, is a fun sled ether way the best 4 stroke I have ever ridden. all I can guess is its the pipe...elevation.... or like AK stated the axys is just responding to boost a lot better than the pros? I feel like its the elevation or the rolling start as we don't ride that far up so I cant attest to how much HP loss that gives you and the SW feels a lot stronger after 20-25 mph than it does off the line so I can see how the rolling start could make a big difference . I am going to try the rolling start the next time we go out to see if we get the same results you did! {even though I feel its padding the test to what the 4stroke needs!} much like when they redesigned the dirt bike tracks when the 4strokes first hit them to accommodate them...and no I am not bashing 4strokes own many of them in my summer toys...all my fave summer toys are 4strokes! but I can feel the difference in the two as a 2smoker has a volatile power and the 4stroker has a very linier power.
  #10
Old 01-29-2018, 04:08 PM
niner's Avatar
  #11
Old 01-29-2018, 04:32 PM
Currently: Not set.
Basic Member
Click Here to Register
  #12
Old 01-29-2018, 08:01 PM
niner's Avatar
  #13
Old 01-29-2018, 08:23 PM
Currently: Not set.
Basic Member
  #14
Old 01-29-2018, 09:09 PM
niner's Avatar
  #15
Old 01-29-2018, 10:04 PM
Currently: Not set.
Basic Member
  #16
Old 01-29-2018, 10:47 PM
niner's Avatar
  #17
Old 01-30-2018, 12:11 AM
Currently: Not set.
Basic Member
  #18
Old 01-31-2018, 01:26 AM
xpturbo600 xpturbo600 is offline
Currently: Not set.
Basic Member
xpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond reputexpturbo600 has a reputation beyond repute
The Following User Says Thank You to xpturbo600 For This Useful Post:
niner (01-31-2018)
  #19
Old 01-31-2018, 03:39 PM
Currently: Not set.
Basic Member
  #20
Old 01-31-2018, 04:26 PM
niner's Avatar
  #21
Old 02-01-2018, 06:12 PM
Currently: Not set.
Basic Member
  #22
Old 02-03-2018, 11:39 PM
Currently: Not set.
Basic Member
  #23
Old 02-06-2018, 09:26 PM
Currently: Not set.
Basic Member
  #24
Old 02-06-2018, 11:55 PM
niner's Avatar
sumtinwong (02-07-2018)
  #25
Old 02-12-2018, 09:36 PM
Currently: Not set.
Basic Member
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 174 Sidewinder build and season ride report. Thread Starter — Turblue Forum — Sidewinder Replies — 66 Last Post — 01-03-2019 11:33 AM
Thread — 2013 MTNTK TURBO 174 PRO BUILD Thread Starter — niner Forum — Polaris: TURBO Replies — 32 Last Post — 09-25-2018 06:51 PM
Thread — 17 174 Axys is 442 lbs... Thread Starter — Ace Freely Forum — Ski-Doo: REV Gen 4 Replies — 163 Last Post — 05-03-2016 05:40 PM
Thread — 174 MTNTK turbo ripping up Allen Creek Feb 2016 Thread Starter — niner Forum — Your Awesome Videos Replies — 0 Last Post — 02-12-2016 11:29 PM
Thread — pro with a 174???or 10t dragon 174??? Thread Starter — lightening800 Forum — Polaris: Pro-Ride Replies — 7 Last Post — 11-03-2010 09:48 AM
no new posts
