Upgrade to Premium
Reply
  #1
Old 01-15-2018, 12:03 AM
RedKitty RedKitty is offline
Currently: Not set.
Basic Member
RedKitty has a reputation beyond reputeRedKitty has a reputation beyond reputeRedKitty has a reputation beyond reputeRedKitty has a reputation beyond reputeRedKitty has a reputation beyond reputeRedKitty has a reputation beyond reputeRedKitty has a reputation beyond reputeRedKitty has a reputation beyond reputeRedKitty has a reputation beyond reputeRedKitty has a reputation beyond reputeRedKitty has a reputation beyond repute
Default Starting and Reverse Issues on a 2016 t3 174
I have a 2016 that has always started first pull even after sitting for months. I've never had any issues with her but last Saturday I was coming up a hill and let off the throttle very abruptly and it made a strange breathy sound and died. Had to pull it over a dozen times to start it, and it sounded slightly off. We were still quite a ways from the home so I rode it about 16 miles or so out, at high end it seemed perfectly fine but just seemed a bit weak on low and midrange, and had to give it a little throttle to get it to start(this has NEVER been the case before). Got it back to the garage and after sitting overnight it seems to start easier, but idle seems low around 1100-1200 rpms. and if I try to put it in reverse it dies. Anyone have any thoughts about what might cause this?
Rate this post: Yes | No
  #2
Old 01-17-2018, 05:04 PM
cubby's Avatar
cubby cubby is offline
Currently: Riding Atv's till the snow comes back
cubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond reputecubby has a reputation beyond repute
Default
How many miles do you have on her? Most of the time if a sled won't go in reverse it's low compression.
__________________
2016 T3 154"
2007 XRS 800 151" engine built by SHR
2013 Polaris 850xp
2015 Polaris 1000xp
2016 Polaris 170 RZR
Hold it pinned till you feel bad
The Following User Says Thank You to cubby For This Useful Post:
RedKitty (01-20-2018)
  #3
Old 01-17-2018, 10:22 PM
Skidooguy Skidooguy is offline
Currently: Not set.
Skidooguy is an unknown quantity at this point
Default
Fuel pump gasket?
__________________
19 850 Summit X 165
15 Summit X T-3 163 800 E-tec
11 Skidoo 800 E-tec SummitXP 154
The Following User Says Thank You to Skidooguy For This Useful Post:
  #4
Old 01-18-2018, 11:59 AM
Diamond8's Avatar
Diamond8 Diamond8 is offline
Currently: Ready For Snow!
Diamond8 has a reputation beyond reputeDiamond8 has a reputation beyond reputeDiamond8 has a reputation beyond reputeDiamond8 has a reputation beyond reputeDiamond8 has a reputation beyond reputeDiamond8 has a reputation beyond reputeDiamond8 has a reputation beyond reputeDiamond8 has a reputation beyond reputeDiamond8 has a reputation beyond reputeDiamond8 has a reputation beyond reputeDiamond8 has a reputation beyond repute
Default
What Skidooguy said..........check the fuel pump......it's gasket.....and it's operation. Have had two sleds in our group do the same thing and it was traced back to issues with the fuel pump. Leaking....not building proper fuel pressure then causing starting / running issues.
Dave
__________________
We're here for a good time not a long time!! ......2015 Summit-X T-3 163 with goodies is current ride
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following User Says Thank You to Diamond8 For This Useful Post:
  #5
Old 01-20-2018, 05:39 PM
Currently: Not set.
Basic Member
Default Thanks everyone for the help
Turns out it was a compression issue, the mag side cylinder only had 95psi. Turns out the pin that holds the ring in had come out and caused all kinds of mayhem. Thanks again to all that responded.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Starting issues idle issues running issues? Help Thread Starter — WINJE Forum — Arctic Cat: TURBO Replies — 2 Last Post — 12-22-2013 02:19 AM
Thread — 1100t Starting in reverse Thread Starter — Hilborn Forum — Arctic Cat: 1100 ProClimb Replies — 16 Last Post — 02-27-2012 05:38 PM
Thread — 07 Phazer starting issues Thread Starter — phazed and confused Forum — Phazers! Replies — 4 Last Post — 01-25-2010 01:58 PM
Thread — Sled keeps starting in reverse? Thread Starter — AaronBND Forum — Arctic Cat: M Series Replies — 9 Last Post — 12-24-2009 11:22 AM
Thread — MMax starting issues Thread Starter — Lt Rascal Forum — Yamaha Replies — 8 Last Post — 01-28-2008 07:20 PM
no new posts
