Upgrade to Premium
Ski-Doo: TURBO Turbo discussion for Ski-Doo aftermarket turbo sleds
Reply
  #1
Old 01-14-2018, 04:49 PM
Marcusx200 Marcusx200 is offline
Currently: Not set.
Basic Member
Marcusx200 is an unknown quantity at this point
Default turbo clutch weights overrev
t3 etec 7lbs silber kit. click 1 on primary
my doo overrevs 8500rpm. dont know grams but i took the "heaviest" possible included in kit ( 1 big tungsten 2 hex screwes) in each wing , wouldnt fit 2 tungsten? what to do?
Rate this post: Yes | No
  #2
Old 01-14-2018, 04:56 PM
fredw fredw is offline
Currently: 850 blown up before Breakin over
Basic Member
fredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond repute
Default
gotta give us some more info, gearing, helix, springs.. If your fully weighted up on arms, more gearing, more helix, oversize rollers, ligher primary spring, steeper ramps, will all pull on motor harder and drop revving..
Check DJ site out for how and where you want to be with clutching, lots of good reeds.. They make also heavier arms that work well with turbo sleds
  #3
Old 01-14-2018, 11:29 PM
Currently: Not set.
Basic Member
Default
i use what comes with the kit. so gearing Will keep rpm down ? which gearing is std 16 summit 163?
  #4
Old 01-14-2018, 11:44 PM
Basic Member
Default
No clue what your silber kit contained, but the 850 kits of there's don't have gearing changes and a guy just blew his reeds out and feels it also needs more gear added..
Best procedure when your up in correct elevation where you ride is to mark your primary clutch haves with a marker, do a pull and take a look how high your belt runs from the top
If it is less than a inch from the top, you should add more gear, if not your heading into a over rev postion
More gearing with push the motor harder and keep belt farther down in primary giving you some grace for over rev
  #5
Old 01-15-2018, 12:10 AM
Backcountrypro's Avatar
Backcountrypro Backcountrypro is online now
Currently: Preparing to get a education in boost!
Backcountrypro has a reputation beyond reputeBackcountrypro has a reputation beyond reputeBackcountrypro has a reputation beyond reputeBackcountrypro has a reputation beyond reputeBackcountrypro has a reputation beyond reputeBackcountrypro has a reputation beyond reputeBackcountrypro has a reputation beyond reputeBackcountrypro has a reputation beyond reputeBackcountrypro has a reputation beyond reputeBackcountrypro has a reputation beyond reputeBackcountrypro has a reputation beyond repute
Default
I fought with this on my Turbo Etec at first. I was able to get it dialed in by switching to a clutch set from Toms with his 3d arms. I also geared up from the stock 19:51 to 22:51. Tom knows his stuff and can get you dialed in pretty close.
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #6
Old 01-15-2018, 09:05 AM
JJ_0909 JJ_0909 is offline
Currently: Not set.
JJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond repute
Default
A lot of the problem is belt slip.
Try ZRP weights. Load the heel a lot. I'm seeing 8000 with 5psi @8000 feet all day. Zero over-rev.
  #7
Old 01-15-2018, 11:58 AM
winter brew's Avatar
winter brew winter brew is offline
Currently: Not set.
winter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond reputewinter brew has a reputation beyond repute
Default
What primary spring did you install?
  #8
Old 01-15-2018, 02:21 PM
Dani3lsn Dani3lsn is offline
Currently: Not set.
Basic Member
Dani3lsn is an unknown quantity at this point
Default
what setup do you have in the secondary clutch ?
  #9
Old 01-16-2018, 07:11 AM
Turbo11T Turbo11T is offline
Currently: EVOLVING
Turbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond reputeTurbo11T has a reputation beyond repute
Default
The spring that comes with the kit for a silber 800 was a yellow/red 200/290 team primary spring.
I believe that a spring and weights are the only thing with the kit.
I must say from my experience it was very hard to get it clutched to stay out of overrev with just the spring and the weights. You had to have so much weight (25 grams) to keep it from overrevving. This made the off boost pretty poor.
I have been pretty happy with my DJ turbo clutch kit for my 800 silber. It rips quickly through the lower rpms. The backshift is good and it holds the rpms. To me it was worth the money spent. You can look on his website what he recommends. ibackshift.com
2 out of 2 members found this post helpful. Rate this post: Yes | No
  #10
Old 01-16-2018, 08:48 AM
Currently: EVOLVING
  #11
Old 01-16-2018, 01:17 PM
Currently: Not set.
Click Here to Register
  #12
Old 01-31-2018, 08:27 AM
Currently: Not set.
Basic Member
  #13
Old 01-31-2018, 08:39 AM
Basic Member
  #14
Old 01-31-2018, 12:46 PM
Currently: Not set.
Basic Member
  #15
Old 01-31-2018, 11:28 PM
Basic Member
  #16
Old 02-01-2018, 02:52 AM
Currently: Not set.
Basic Member
  #17
Old 02-01-2018, 01:02 PM
Currently: Not set.
  #18
Old 08-26-2018, 08:10 AM
Currently: Not set.
Basic Member
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — MDS P1-Turbo Adjustable clutch weights Thread Starter — jrk Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 4 Last Post — 10-14-2014 04:56 PM
Thread — Turbo pro clutch weights Thread Starter — bk720 Forum — Polaris: TURBO Replies — 7 Last Post — 05-18-2014 06:22 PM
Thread — Polaris MDS P1-Turbo Adjustable clutch weights Thread Starter — jrk Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 1 Last Post — 03-23-2014 09:57 PM
Thread — MDS 1100 Turbo Clutch Weights/Spring Thread Starter — Turbo11T Forum — Clutch/Drive Train/Belt (Swapmeet) Replies — 0 Last Post — 11-12-2013 07:34 AM
Thread — 09 assault 800 w/ BD RG turbo clutch weights Thread Starter — St0rm77 Forum — Polaris: TURBO Replies — 8 Last Post — 04-03-2013 11:53 PM
