Upgrade to Premium
Polaris: 900 05-06 Polaris RMK 900
Reply
  #1
Old 01-14-2018, 01:29 PM
egefell egefell is offline
Currently: Not set.
Basic Member
egefell is an unknown quantity at this point
Default Weight hanging up on broken roller - can i remove and get back to trail head?
I have an 06 rmk 900 159". It is currently deep in the backcountry and I could not tow out due to deep snow and big pass to get over.
I have a broken roller that my weight is being hung up on, keeping the primary engaged. The sled did start back up and idol (seemed to be fine, track even moved when we lifted it off the ground. BUT it was giving me an awful noise and did not want to move.
My original thought is it change out the entire clutch in the field. The more I researched this, it sounds like its possible but a huge pain in the ***.
My questions is; can I removed the weight that is hanging up and get the sled back to the trail head? Will this cause damage to other parts of the mechanism or to the engine itself?
Would really like to do able to do the work that needs to be done in a garage...
Thanks for you help!
Rate this post: Yes | No
  #2
Old 01-14-2018, 02:59 PM
94fordguy's Avatar
94fordguy 94fordguy is offline
Currently: Waiting for snow!
94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute94fordguy has a reputation beyond repute
Default
If it were my sled in the field with that issue, I would find or borrow another primary and change clutches out to get it back to the truck. I wouldn't want to run the machine with a clutch that far out of balance if you're talking about pulling one of the weights, that'll put a lot of stress on the crank stub. Pulling the primary is actually pretty easy as long as you have the puller, some teflon tape, and some water to pour in the hole. Or pull the clutch and have it serviced, then bring it back and reinstall if you don't have a spare primary available.
__________________
ARRA MEMBER - Americans for Responsible Recreational Access
WSSA MEMBER - Washington State Snowmobile Association
Yakima Ski Benders MEMBER - Washington's first snowmobile club
Support Public Access to Public Land
13 PRO RMK 800 162 VEI Custom
12 Ford F-350 Lariat C/C S/B 4x4 6.7L Powerstroke...130K
08 Polaris Scrambler 500 4x4
06 Kawasaki ZZR 600
05 RMK 900 166 Anniversary Edition #850 6,693 Miles
02 Interstate 19' Enclosed
The Following User Says Thank You to 94fordguy For This Useful Post:
05900 (01-14-2018)
  #3
Old 01-14-2018, 05:00 PM
05900's Avatar
05900 05900 is offline
Currently: Hele i kahi mokupuni
05900 has a reputation beyond repute05900 has a reputation beyond repute05900 has a reputation beyond repute05900 has a reputation beyond repute05900 has a reputation beyond repute05900 has a reputation beyond repute05900 has a reputation beyond repute05900 has a reputation beyond repute05900 has a reputation beyond repute05900 has a reputation beyond repute05900 has a reputation beyond repute
Garage
Default
Or buy a rebuild kit,bag some tools and replace the roller where it sits. No doubt it will be a PITA but you wont have to pull it....
__________________
You might not see him in person, But he'll see you just the same..
  #4
Old 01-16-2018, 08:26 AM
SixtySevenGT's Avatar
SixtySevenGT SixtySevenGT is offline
Currently: Building Sleds
SixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond reputeSixtySevenGT has a reputation beyond repute
Default Do Both
Is the roller flat or is the weight against the side.
Might be the bushing in the weight simple fix there
Take a puller and Teflon, and the rebuild kit since you need it anyway. Some 900 clutches come off hard. Take a new bolt also, after a clutch swap that might ruin your day later.
Been there -- Done that
__________________
"Always Drink Upstream from the Herd"
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — AARGH, broken roller in my secondary. Thread Starter — jacmmaxwell Forum — Ski-Doo: XP Sleds Replies — 6 Last Post — 03-17-2012 08:23 AM
Thread — Best way to remove the plate on the back of the clutch? Thread Starter — likkerpig Forum — Arctic Cat: M Series Replies — 9 Last Post — 11-16-2011 06:55 AM
Thread — 05 Summit X 1000 Weight reduction-Know what to remove just not how Help! Thread Starter — Skummit X Forum — Ski-Doo: REV Sleds Replies — 5 Last Post — 11-11-2009 02:01 PM
Thread — best way to remove broken clutch tool from crank??? Thread Starter — 89sandman Forum — Arctic Cat Replies — 12 Last Post — 01-28-2009 01:01 PM
Thread — Broken Sway Bar, remove? Thread Starter — PowderMiner Forum — Polaris Replies — 5 Last Post — 12-09-2008 07:19 PM
no new posts
