Upgrade to Premium
Arctic Cat: TURBO Turbo discussion for Arctic Cat aftermarket turbo sleds
Reply
  #1
Old 01-12-2018, 09:10 AM
mtn-doo's Avatar
mtn-doo mtn-doo is offline
Currently: busy building !!!
mtn-doo has a reputation beyond reputemtn-doo has a reputation beyond reputemtn-doo has a reputation beyond reputemtn-doo has a reputation beyond reputemtn-doo has a reputation beyond reputemtn-doo has a reputation beyond reputemtn-doo has a reputation beyond reputemtn-doo has a reputation beyond reputemtn-doo has a reputation beyond reputemtn-doo has a reputation beyond reputemtn-doo has a reputation beyond repute
Default Boondocker Sidekick Auto, new Ascender model.
https://www.instagram.com/p/Bd2bR6dnDVz/
It's here and it's awesome!!! Boom !!!
Pump gas, Electronic Boost controll, just ride !!!
__________________
Randy
406-249-1132
Boondocker Northern US Rep
1 out of 1 members found this post helpful. Rate this post: Yes | No
The Following 4 Users Say Thank You to mtn-doo For This Useful Post:
32longtrack (01-12-2018), bradburck (01-12-2018), mtn_rider08 (01-12-2018), Qreiff (01-12-2018)
  #2
Old 01-14-2018, 04:42 AM
Sunvang Sunvang is offline
Currently: Not set.
Sunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond reputeSunvang has a reputation beyond repute
Default
When will they release a adjustable kit?
__________________
2019 Arctic Cat Hardcore Alpha 154" Silber Turbo
  #3
Old 01-14-2018, 09:03 AM
mtn-doo's Avatar
Default
That is the ST kit. It is in development. What are you planning? Just curious.
__________________
Randy
406-249-1132
  #4
Old 01-14-2018, 01:14 PM
Currently: Not set.
Default
Quote:
I think that 5psi is to little boost to justify the price, and I like to tune turbo sleds myself.
Would a Sidekick kit be possible to upgrade to an adjustable fuel controller and extra injectors later, when the new fuel controllers comes out?
__________________
  #5
Old 01-14-2018, 01:34 PM
mtn-doo's Avatar
Default
Yes. That would be the ST kit.
Let me explain the Sidekick Auto a little further. The Sidekick Auto is not so much a "Pound boost" setting, but rather a HP setting. It is fully automated by Electronic Boost Control. You start out at 5 psi which gives you approximately 200 hp. As you climb in elevation and your air density gradually falls, the EBC proportionately increases boost maintaining 200 hp.
At elevation you will be boosting much higher, just like our modern automobile systems do. Then as you descend in elevation, EBC proportionately reduces the boost as to not over boost down low. Your boost is always changing with your density altitude. Your HP is remaining constant. Super nice technology now. You can look at a few vids on Boondockers FB page of the new Cat in action. They are on the back bumper half the time because they are boosting much higher psi at elevation. You don't need a "fixed boost number " anymore with EBC. Also with the boost controlled, you don't need higher octane fuels for over boost situations. You would not be disappointed.
__________________
Randy
406-249-1132
2 out of 2 members found this post helpful. Rate this post: Yes | No
  #6
Old 01-14-2018, 01:38 PM
mtn-doo's Avatar
Default
Also consistent HP means consistent clutching. You never have to make small clutch adjustment with elevation anymore. Very very nice.
__________________
Randy
406-249-1132
The Following User Says Thank You to mtn-doo For This Useful Post:
Shwinecat (01-27-2018)
  #7
Old 01-14-2018, 01:46 PM
Currently: Not set.
Default
Thanks for the information, I have had several Boondocker turbo sleds before, and all were fully adjustable so I know how they work.
Here in Norway where i ride I don't really have big elevation variations, and im riding from 1500ft to 3800ft at the highest. At the most i could see 1psi in difference from the lowest elevation to the highest.
And i still think 6psi is to little boost for me, and at 200hp im still around 20hp less then im used to.
No problem running pump gas and 8-9psi at our elevation if it is tuned well. Need to mention that our pump gas has a sligthly higher octane then yours, and contains no ethanol mixed in it.
Don't get me wrong, the Sidekick is a awesome product, but some just want more
__________________
  #8
Old 01-14-2018, 01:50 PM
mtn-doo's Avatar
Default
Yes, You will have the ST kit available in the future. You will have the ability to make it a MONSTER ! Straight VP - C12 fuel and big boost!
That was my last sled and yes, it is a drug !!! Haaha
__________________
Randy
406-249-1132
  #9
Old 01-14-2018, 01:56 PM
Currently: Not set.
Default
Sounds good.
__________________
  #10
Old 01-14-2018, 02:05 PM
mtn-doo's Avatar
The Following 7 Users Say Thank You to mtn-doo For This Useful Post:
600ho (01-14-2018), ArcticChat (01-18-2018), cpa (02-12-2018), High Country (02-11-2018), jonmatz88 (11-13-2018), Prairie Dog (01-14-2018), bdcat162 (03-03-2018)
  #11
Old 01-14-2018, 02:21 PM
Currently: Not set.
Click Here to Register
  #12
Old 01-14-2018, 02:24 PM
mtn-doo's Avatar
  #13
Old 01-14-2018, 02:28 PM
mtn-doo's Avatar
  #14
Old 01-14-2018, 03:33 PM
Chewy22's Avatar
Chewy22 Chewy22 is online now
Currently: Not set.
Chewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond reputeChewy22 has a reputation beyond repute
  #15
Old 01-14-2018, 03:51 PM
M Turbo M Turbo is offline
Currently: Not set.
Basic Member
M Turbo has a reputation beyond reputeM Turbo has a reputation beyond reputeM Turbo has a reputation beyond reputeM Turbo has a reputation beyond reputeM Turbo has a reputation beyond reputeM Turbo has a reputation beyond reputeM Turbo has a reputation beyond reputeM Turbo has a reputation beyond reputeM Turbo has a reputation beyond reputeM Turbo has a reputation beyond reputeM Turbo has a reputation beyond repute
  #16
Old 01-14-2018, 03:56 PM
Cat800 Cat800 is online now
Currently: Not set.
Basic Member
Cat800 has a reputation beyond reputeCat800 has a reputation beyond reputeCat800 has a reputation beyond reputeCat800 has a reputation beyond reputeCat800 has a reputation beyond reputeCat800 has a reputation beyond reputeCat800 has a reputation beyond reputeCat800 has a reputation beyond reputeCat800 has a reputation beyond reputeCat800 has a reputation beyond reputeCat800 has a reputation beyond repute
  #17
Old 01-14-2018, 03:58 PM
Currently: Not set.
Basic Member
  #18
Old 01-14-2018, 07:45 PM
mtn-doo's Avatar
  #19
Old 01-14-2018, 07:49 PM
mtn-doo's Avatar
  #20
Old 01-14-2018, 07:54 PM
mtn-doo's Avatar
  #21
Old 01-14-2018, 07:59 PM
mtn-doo's Avatar
  #22
Old 01-14-2018, 10:35 PM
Polaris Pilot Polaris Pilot is offline
Currently: Riding a Cat!
Basic Member
Polaris Pilot has a reputation beyond reputePolaris Pilot has a reputation beyond reputePolaris Pilot has a reputation beyond reputePolaris Pilot has a reputation beyond reputePolaris Pilot has a reputation beyond reputePolaris Pilot has a reputation beyond reputePolaris Pilot has a reputation beyond reputePolaris Pilot has a reputation beyond reputePolaris Pilot has a reputation beyond reputePolaris Pilot has a reputation beyond reputePolaris Pilot has a reputation beyond repute
  #23
Old 01-14-2018, 11:32 PM
Currently: Not set.
  #24
Old 01-15-2018, 08:23 AM
mtn-doo's Avatar
Sunvang (01-15-2018)
  #25
Old 01-16-2018, 05:40 PM
Tstams Tstams is offline
Currently: Not set.
Basic Member
Tstams has a reputation beyond reputeTstams has a reputation beyond reputeTstams has a reputation beyond reputeTstams has a reputation beyond reputeTstams has a reputation beyond reputeTstams has a reputation beyond reputeTstams has a reputation beyond reputeTstams has a reputation beyond reputeTstams has a reputation beyond reputeTstams has a reputation beyond reputeTstams has a reputation beyond repute
The Following User Says Thank You to Tstams For This Useful Post:
f7firecatkid (01-27-2018)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Boondocker "Sidekick Auto" Thread Starter — mtn-doo Forum — Ski-Doo: TURBO Replies — 65 Last Post — 02-03-2018 07:50 AM
Thread — boondocker sidekick X Thread Starter — cls11 Forum — Turbos/Superchargers (Swapmeet) Replies — 4 Last Post — 03-18-2017 09:51 AM
Thread — BoonDocker Sidekick: Intercooler Yes or No? Thread Starter — BrandonH Forum — Polaris: TURBO Replies — 14 Last Post — 09-27-2016 04:09 PM
Thread — Boondocker Sidekick, snowcheck Thread Starter — L. Perry Forum — Polaris: TURBO Replies — 26 Last Post — 04-11-2016 08:22 PM
Thread — Boondocker Sidekick Turbo for PC Thread Starter — Phizzer Forum — Arctic Cat: Proclimb M Replies — 8 Last Post — 01-27-2016 10:04 AM
no new posts
