Upgrade to Premium
Arctic Cat: M Series 2005-Current, all models in the M-series chassis
Reply
  #1
Old 01-12-2018, 08:18 AM
Ddub's Avatar
Ddub Ddub is offline
Currently: Not set.
Ddub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond reputeDdub has a reputation beyond repute
Default 07 m1000 build
I picked up this sled for cheap running and working like it should and the next thing I know it's down to almost a bare chassis. Funny how that happens! Ots actually a crossfire but has a 2016 141 skid in it with a 144 2 inch challenger track. The motor was ported by rk tek, cylinders and cases. Got rid of the factory bar setup and went with cfr bars and risers. Powder coated, bm fabrication boards and carbon fiber tunnel wrap. Should be a fun sled. Looking forward to running it against my h/c with a bikeman 940 to see how they compare!
Click image for larger version
ID:	291325   Click image for larger version
ID:	291326   Click image for larger version
ID:	291328   Click image for larger version
Rate this post: Yes | No
  #2
Old 01-12-2018, 08:25 AM
Ddub's Avatar
Currently: Not set.
Default
Damn sideways pics!
  #3
Old 01-12-2018, 11:03 AM
Ddub's Avatar
Currently: Not set.
Default
Couple more.
ID:	291338   Click image for larger version
  #4
Old 01-17-2018, 05:32 PM
CATSLEDMAN1 CATSLEDMAN1 is online now
Currently: one ski and a KTM
CATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond reputeCATSLEDMAN1 has a reputation beyond repute
Default 1000's of blues
if its stock drive train, keep in mind its really high geared, very lazy no matter what mods you make, gear it like your 800, you will be really surprised at how it can run
keep an eye on plug or piston wash, again, all stock, they were tooo lean to really run very well stock or with mods until you add some gas
  #5
Old 01-17-2018, 06:06 PM
smokindave's Avatar
smokindave smokindave is online now
Currently: I need a new sled....like bad!
Canada Moderator
smokindave has a reputation beyond reputesmokindave has a reputation beyond reputesmokindave has a reputation beyond reputesmokindave has a reputation beyond reputesmokindave has a reputation beyond reputesmokindave has a reputation beyond reputesmokindave has a reputation beyond reputesmokindave has a reputation beyond reputesmokindave has a reputation beyond reputesmokindave has a reputation beyond reputesmokindave has a reputation beyond repute
Default
I’ve got a brand new Twisted Turbo kit for sale that would wake that sled up...did I say that it’s for sale for cheap.
$2000 Canadian!
1 out of 1 members found this post helpful. Rate this post: Yes | No
  #6
Old 01-17-2018, 06:07 PM
kiliki kiliki is online now
Currently: Not set.
kiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond reputekiliki has a reputation beyond repute
Garage
Default
only the 07 unflased ecu was lean. 08 up got a bit more fuel added.
  #7
Old 01-18-2018, 10:07 AM
ultrasks700 ultrasks700 is offline
Currently: twisting wrenches
ultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond reputeultrasks700 has a reputation beyond repute
Default
Sweet looking machine! I wish I kept my M-series around, I had a lot of fun with it.
__________________
2018 Mountain Cat ES
Mechanical Engineer
Maine Rider
  #8
Old 01-18-2018, 10:57 PM
Ddub's Avatar
Currently: Not set.
Default
It has the 09 updated ecu and I'll be using a pcv. Rk tek ported the cases and cylinders. Rk tek head, stm valves, speedwerx pipe and y-pipe. Crank has been trued and welded with new bearings. It should be a runner!!
  #9
Old 01-19-2018, 11:04 AM
jim jim is online now
Currently: Keyboard highmarking at its best.
jim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond reputejim has a reputation beyond repute
Default
Nice. That sled is gonna be a ripper. I had an 07 with just RKT head, after market y-pipe, geared down (one gear lower than stock M8), SLP intake mod and can with more fuel and clutching. Ran awesome.
I assume you'll run some race gas mix? I ran 92 in mine and it was on the edge of detonation at 6-8k feet. Also, I highly recommend the SLP intake mod to reduce or eliminate powder bogging. The SLP intake has axillary intake screens so that when your intakes on the hood are plugged, and they will be in powder, you can still feed it air. Without that mod, I had constant powder bogging issues...that simple intake mod fixed that.
  #10
Old 01-19-2018, 09:19 PM
Ddub's Avatar
Currently: Not set.
  #11
Old 02-28-2018, 08:51 AM
Ddub's Avatar
Currently: Not set.
Click Here to Register
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Proclimb M1000 build tread Thread Starter — Daltech Forum — Arctic Cat: Proclimb M Replies — 55 Last Post — 01-07-2019 01:25 AM
Thread — Cat m1000 build help Thread Starter — Rabiesbabies Forum — Arctic Cat: M Series Replies — 3 Last Post — 07-03-2015 10:04 AM
Thread — M1000 build thread! Thread Starter — Kyle91rs Forum — Member Sled Builds Replies — 3 Last Post — 12-23-2013 10:22 PM
Thread — custom build M1000 for sale Thread Starter — crazyforsnow Forum — Arctic Cat (Swapmeet) Replies — 0 Last Post — 12-05-2013 08:12 AM
Thread — My M1000 build Thread Starter — smokindave Forum — Member Sled Builds Replies — 22 Last Post — 11-22-2010 09:11 AM
no new posts
