Upgrade to Premium
Reply
  #1
Old 01-11-2018, 07:34 PM
MTN_VIPER's Avatar
MTN_VIPER MTN_VIPER is offline
Currently: Making roll-over valve kits since 2008
MTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond reputeMTN_VIPER has a reputation beyond repute
Default New King Cat roll over valve kits.
I have been receiving quite a few requests to build a ROV kit for the King Cat/Sidewinder. With that in mind, we have designed a ROV kit for the King Cat and Sidewinder that replaces the normally closed OEM check valve with a normally open system similar to our M7000/Viper ROV kits.
Just like our M7000 ROV kit, the King Cat ROV kit is a premium unit that features a Roll Over Valve Control Module (ROVCM) and the quick prime oil pump re-prime system!
I have more information at http://fourstrokesolutionsllc.webs.c...g-cat-rov-kits
and for installation photos here at http://fourstrokesolutionsllc.webs.c...bumid=16102135
Click image for larger version
__________________
Four Stroke Solutions LLC
Patented Roll-Over Valve Systems
ROV kits for M/XF7000/Viper, Sidewinder and King Cat with Quick-prime!
For Arctic Cat and Yamaha Sleds
Patents 8,225,766 8,528,516 9,303,537
http://fourstrokesolutionsllc.webs.com/
e-mail fourstrokesolutionsllc@hotmail.com
Rate this post: Yes | No
The Following User Says Thank You to MTN_VIPER For This Useful Post:
Woody67 (01-11-2018)
  #2
Old 01-12-2018, 08:01 AM
2013 M1100 Turbo 2013 M1100 Turbo is offline
Currently: Not set.
Basic Member
2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute2013 M1100 Turbo has a reputation beyond repute
Default
Is there a known issue with the ROV that come on these sleds? I have rolled mine a couple times and never had an issue?
I have heard of some of the stock ROV's freezing under extreme conditions.
  #3
Old 01-12-2018, 06:04 PM
MTN_VIPER's Avatar
Default
The stock normally closed valve does work. However some guys were having trouble with the stock OEM unit freezing closed. Usually it happens when the sled sits outside overnight in below freezing weather. If it freezes closed and you start the engine, it can over pressurize the oil tank causing it to leak at oil tank halve seal. To repair the leak requires disassembling the oil tank and re-sealing it.
Not all sleds have the frozen closed valve concern and I suspect a large factor is environmental. Moisture condensation occurs naturally in the breather lines during normal operation. How much is there and whether it freezes or not depends on several factors including riding time cycles, mileage on the sled, ambient moisture content and ambient temperatures.
As a different option, our ROV kit uses a normally open valve which is in the venting position anytime that it's not being comanded closed. (ie. tether pulled, with the key on)
Because the valve is already open while sled is off and it doesn't have to change positions during a cold start, the breather system can start venting right away. This allows the warm air to flow from the oil tank un-restricted as soon as possible. Which in turn, thaws out any accumulated moisture in the breather line that may have frozen.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — King Cat Roll Over Valve Thread Starter — Saddle sore Forum — Arctic Cat: 1100 ProClimb Replies — 1 Last Post — 09-25-2017 08:00 AM
Thread — Roll-Over Valve kits for Proclimb M1100 from Four Stroke Solutions LLC Thread Starter — MTN_VIPER Forum — Arctic Cat: 1100 ProClimb Replies — 84 Last Post — 11-15-2016 07:42 AM
Thread — Roll-Over Valve kits for Viper/XF7000! Thread Starter — MTN_VIPER Forum — Vipers! Replies — 22 Last Post — 01-01-2015 03:31 PM
Thread — Roll-Over Valve kits are now Patented! Thread Starter — MTN_VIPER Forum — Yamaha: 4-Stroke Replies — 12 Last Post — 09-05-2012 10:15 PM
Thread — Power Valve Delete on King Cat Thread Starter — ProKlim Forum — Arctic Cat: 1M Replies — 4 Last Post — 01-01-2009 02:43 PM
no new posts
