Upgrade to Premium
Yamaha: 4-Stroke Includes all Yamaha 4-strokes, Nytro, Apex, Phazer, etc
Reply
  #1
Old 01-11-2018, 04:01 AM
piotrek piotrek is offline
Currently: Not set.
Basic Member
piotrek is an unknown quantity at this point
Default Yamaha RX-1 shaft absorber replacement.
Hi! My name is Piotr. I`m from Poland. In snowmobile rx1 2004 must replacement absorber 8FP-16155-00-00 in shaft 8FA-11406-00-00. I removed the engine. I removed oil pan, oil pump, water pump and this shaft. I do not know how to dismount the sleeve and the bearing. Was someone from you replacing the absorber? The service manual does not show this procedure. How to do it?
Best regards
Piotr
Rate this post: Yes | No
  #2
Old 01-11-2018, 12:18 PM
Givemeaboost's Avatar
Givemeaboost Givemeaboost is offline
Currently: Not set.
Givemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond reputeGivemeaboost has a reputation beyond repute
Default
By looking at the Yamaha part fisch it looks like you might need to use a split puller that will go behind the bearing and press it off the shaft.
Ken............
__________________
03 rx1 mtn with homebuilt turbo , 159 finger track , Rev tank and seat. 01 Mountain Max
  #3
Old 02-02-2018, 02:55 AM
Currently: Not set.
Basic Member
Default
I did it, I needed a split puller and high temperature.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — M1000 reed replacement;TPS adj; drive shaft bearing replacement; tank replacement Thread Starter — Sledbrain2 Forum — Arctic Cat: M Series Replies — 0 Last Post — 01-16-2016 09:38 PM
Thread — Help Needed, I Need A Fabcraft Replacement Shaft Thread Starter — 800 Escape Forum — Suspension/Shocks (Swapmeet) Replies — 5 Last Post — 12-17-2012 12:17 AM
Thread — Drive shaft replacement Thread Starter — justadude Forum — Ski-Doo Replies — 7 Last Post — 10-27-2008 03:17 PM
Thread — Fabcraft replacement shaft(new) Thread Starter — mngoat Forum — Suspension/Shocks (Swapmeet) Replies — 0 Last Post — 09-15-2008 02:56 PM
Thread — shock shaft replacement? Thread Starter — specialk6r Forum — Arctic Cat Replies — 7 Last Post — 02-06-2008 04:15 PM
no new posts
