Upgrade to Premium
Ski-Doo: TURBO Turbo discussion for Ski-Doo aftermarket turbo sleds
Reply
  #1
Old 01-08-2018, 11:45 AM
mtn-doo's Avatar
mtn-doo mtn-doo is online now
Currently: busy building !!!
mtn-doo has a reputation beyond reputemtn-doo has a reputation beyond reputemtn-doo has a reputation beyond reputemtn-doo has a reputation beyond reputemtn-doo has a reputation beyond reputemtn-doo has a reputation beyond reputemtn-doo has a reputation beyond reputemtn-doo has a reputation beyond reputemtn-doo has a reputation beyond reputemtn-doo has a reputation beyond reputemtn-doo has a reputation beyond repute
Default Boondocker "Sidekick Auto"
Hi everyone!
I want to give a review and comprehensive over view of the new Boondocker Sidekick Auto for the Ski Doo 850.
I have spent the last few days pounding this sled and turbo package and want to share the experience.
First off, I feel I should give a thorough breakdown of the Sidekick and it's operating components and functions.
#1 - The Boondocker Sidekick is the "next gen" technology in Turbo application for our sleds. We finally have up to date, 21st century technology available!
ECU - , The OEM , ECU's are the result of thousands of hours of perfection by the manufacturer to accomplish the amazing, "perfect" operation we see today in these new sleds. Boondocker has realized this fact and therefore does not touch the OEM's ECU. The ECU is not sent in and "re-programmed" or altered. It controls and performs all of the functions intended by the manufacturer, including SHOT. Having that gives the 850 the amazing grunt and throttle response famous to this engine. The Sidekick Auto simply lays in fuel over top of the stock ECU as needed for boost. You then have the stock, excellent ECU functioning as normal "plus" boost and additional fuel. The result is amazing. If you have receive an ECU update from the manufacturer, you simply take it to your dealer, update as per normal, then continue riding! No down time. Then down the road when you want to sell your sled and upgrade, you simply unplug the Sidekick Auto electronics, remove the turbo and reassemble to stock and sell your sled. No need for an expensive new ECU replacement. Very nice.
#2 - Electronic Boost Control, "EBC". This technology is amazing. No more manual boost control or the need to "turn it up a little" when at altitude. EBC is more of a "horsepower setting" than a boost setting. With the old technology we had, we used to manually set a "target boost value". With Boondockers EBC, we are essentially setting a target "Horsepower value". The Sidekick Auto begins at approximately 5 pounds of boost. That equates to about 210HP on the 850. The EBC then monitors the atmospheric values and proportionately adjusts boost accordingly, maintaining the 210HP.
At high elevations, the Sidekick Auto will be pumping out 7,8,9, pounds of boost required to maintain that constant 210HP. Then as you head back down the mountain, the EBC is protecting you from over-boosting by reducing boost until it is back at that beginning value of approx 5PSI. You can start to see this is not a "boost setting" but a HP setting. EBC is controlling boost throughout the day. All of this is done electronically and automatically! Then to top it off, there is also TPS, "throttle position sensing" incorporated into the application of boost. The result is a seamless, smooth and progressive power application. You can carefully hold a sketchy sidehill, smoothly and continuously. If you want to stand it on the rear bumper, just push your thumb a little farther. Very "ride-able" and smooth.
The EBC and TPS functions remind me of my new Ford Eco-Boost truck. Like all of our modern turboed cars and trucks. There is EBC and TPS working to give us consistent HP in all temperatures and elevations. What that does for our sleds is give us HP consistency which eliminates the need for any clutch tuning! Once the Boondocker clutching is installed, there is no need for adjustments because the HP to the track is always consistent! Super cool.
#3 - The turbo itself is a Garrett 2860. Excellent all around choice. The Cold air intake is accomplished through the OEM's upper box and a cold air plenum feeding the turbo. The charge tube and air box, "charge box" are aluminum for quick heat transfer and flow efficiency. The fuel is provided through the OEM primary and secondary injectors.
#4 - I have to put this one out there for specific attention. The muffler. Haaha, yep! It deserves attention. It is a very precisely designed and built piece. Stainless steel and designed specifically for this kit. Beautiful to look at, amazingly engineered and built and a custom , stainless "Boondocker Logo" tagged on. The sound is the big bonus. It is not that empty "tuna can", mod sled noise we all loved in the past. It has a deeper rumble and crack. Not much louder that stock, but definitely the sound that advertises to everyone around there's something special under the hood. Most excellent !
#5 - Clutching. The clutch upgrades were very simple. 2017's get a new spring. 2018's keep their spring. There is a new set of arms, "ramps" with weights pre-installed. You simply install and go. The secondary spring and helix remain. The first pull I made was a clutch test. It rocketed to 8K and never budged. Done... very nice. On the road going in, I tested the shift rate and RPM. It will literally rip you off the back of the seat if you aren't ready. I love an aggressive up-shift. There was no "fade" or flattening out in the upper rev's. It pulled super aggressive all the way to the end and remained at 8K rpm. Crystal clean and smooth holding a sustained WOT pull in deep snow. It feels like you could hold it there for ever. Perfectly clean and smooth. Everything seemed very "happy" if you tuners know what I mean....
Summery and seat of the pants.
From start up, the sled purr's like stock. The "stock ECU" is controlling everything. The throttle response is wicked as normal. Boost builds from near idle, smoothly until your arms are stretched and the ski's are airborne. I would hold WOT on a deep powder climb, chop the throttle, and mash it again as a test. The ski's would dip, then lift high and the climb continued as though I hadn't done anything! Instant response and smooth. We have all seen the likes of Chris Burant, Keith Curtis, Dan Adams and others on their incredible Boondocker powered Polaris sleds. Now we have that entire package for the Ski Doo 850"s !!! Very stoked !!! #"Boondocker /Ski Doo"!!!
Well everyone, I tried to be as informative as possible to the Side Kick Auto's technical pieces and their function. I hope this was helpful and if you have any questions, you are always welcome to give me a shout.
I will post some pic's shortly and follow up with some Go Pro footage etc.
__________________
Randy
406-249-1132
Boondocker Northern US Rep
2 out of 2 members found this post helpful. Rate this post: Yes | No
The Following 8 Users Say Thank You to mtn-doo For This Useful Post:
cableguy (01-15-2018), fredw (01-08-2018), jokerman (01-08-2018), mountainhorse (01-08-2018), mtncat (01-09-2018), nuttyn01 (01-09-2018), skidawg (01-11-2018), winter brew (01-09-2018)
  #2
Old 01-08-2018, 12:24 PM
JJ_0909 JJ_0909 is online now
Currently: Not set.
JJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond reputeJJ_0909 has a reputation beyond repute
Default
Quote:
Originally Posted by mtn-doo View Post
Hi everyone!
No doubt they make a good product. Everyone here knows I however work for Silber.
I'm not going to bash the BD system, but being you/they are taking shots here that aren't completely factual, I feel the need to update this post...
The whole idea that you are using the factory ECU and "adding to it" is sort of BS. Its a new map based off a piggyback controller. Period. The motor doesn't know where the fuel and air is coming from, it doesn't care. The piggyback is reacting to certain variables to add/subtract fuel. Yes, the stock map remains the same, but you are still taking one map, adding another map, and getting something entirely new.
Granted, BD has been doing the pigggyback thing a long time, but remember, no modern automobile with a turbocharger uses a piggyback to control air/fuel. To suggest that using the stock electronics is somehow "less than" is the part I'm trying to show isn't really fair.
Silber is also working on a remote reflash procedure. There are already various locations around the country this can be done. This will get rolled out in quantity over the coming months/season.
Finally, as far as removing the kit for sale, well, there are ethics here I will not go into. However, any dealer can flash the ECU back to stock if one is so inclined.
Anyway, we aren't going to pretend BD makes a terrible kit the same way a Chevy engineer isn't going to laugh at a Ford engineer. We respect each other. But we do believe in our technologies and do wish the masses would perpetuate more accurate information as to the inner workings of each product.
Cheers!
3 out of 3 members found this post helpful. Rate this post: Yes | No
The Following 8 Users Say Thank You to JJ_0909 For This Useful Post:
Cpt.Ron (01-10-2018), fredw (01-08-2018), grizzly7 (01-09-2018), jokerman (01-08-2018), live2beel (01-08-2018), mountainhorse (01-08-2018), skidawg (01-11-2018), Wheel House Motorsports (01-08-2018)
  #3
Old 01-08-2018, 01:34 PM
mtn-doo's Avatar
Default
Thanks for your thoughts. I must clarify however that this is a Boondocker Sidekick Auto review. Not a comparison or any other brand discussion. I am sure someone will have a multi brand discussion and review at some point. I believe there are other turbo threads available for other brands. This is a stand alone thread for everyone to read, discuss and ask questions in respect to this system. Not a comparison to anything or anyone? Respectfully, no other brands are mentioned. We've all seen threads over the years go sideways and become a mess for everyone. Thanks again.
Back to this thread and product overview.
To clarify, the Ski Doo , OEM ECU is not touched or even ever removed from the sled at any time. The OEM ECU performs all of the manufacturer's functions as designed by the manufacturer.
The Auto Sidekick electronics are not a "tuner", "programmer" like the products we have all used somewhere in the past on bikes or sleds. The Side Kick Auto is built by an electronics team from scratch in house to provide fuel, EBC and TPS. It does incorporate Electronic Boost Control, like our modern vehicle applications, and incorporates TPS like out modern vehicle applications. That is the technology point being made. The end result is a seamless, smooth, and consistent HP to the track, again like the modern turbo electronics we see today in other applications.
Thank you.
__________________
Randy
406-249-1132
The Following User Says Thank You to mtn-doo For This Useful Post:
mtncat (01-09-2018)
  #4
Old 01-08-2018, 01:47 PM
Currently: Not set.
Default
Thank you.
I get that. But you made it a comparison in the way you wrote your review. In that comparison you made some errors with how you articulated certain things.
Yes, it is a "programmer box". It is not a stand alone ECU. The program may very well be good, but that does not change the fact it is a piggyback controller. EG, it is a slave unit to the master ECU. You can have a piggyback controller do amazing things, but it is nothing like the modern automobile in how they work from a functional perspective. If you understand modern fuel injection, you'd see that having maps on maps (two maps, not able to influence one and other) is different than one homogeneous map that controls everything.
Sorry to get lost in definitions, but again, my point here is not to crap on the product but just to keep the facts straight.
  #5
Old 01-08-2018, 02:08 PM
mtn-doo's Avatar
Default
I am sorry you don't understand The Sidekick Auto for The 850. The Boondocker electronics are "NOT" connected to the OEM ECU. No "Y" connection, no "T" connection. Not connected at all on the 850. You are only assuming. You need to get one first and become familiar with it in order to discuss it accurately.
The "modern" technology I referenced is the application of Electronic Boost Control and the ability to very boost in a wide variety of conditions in order to maintain a consistent power delivery. Also the Throttle Position function blending boost in reference to throttle position is super state of the art, like our other "modern turbo applications". EBC and TPS working together is the magic I am referring to. Not "where" the info is coming from. The secondary box, the "Auto Box" is providing that technology.
Thanks.
__________________
Randy
406-249-1132
  #6
Old 01-08-2018, 02:27 PM
Chadly's Avatar
Chadly Chadly is offline
Currently: Not set.
Chadly has disabled reputation
Default
Sure seems like BD wrote that post for you 😆 Hopefully they got it figured out because my 2 XMs that had BD kits put me in a boat where I don't think I'll ever own one again.
  #7
Old 01-08-2018, 04:02 PM
mtn-doo's Avatar
Default
Yes. They definitely have an awesome product with this new Sidekick Auto. Pull the rope and ride. Awesome! I get your point however. LoL I remember back a few years when Polaris had the infamous 900. Haaha . Things sure seem to evolve and we get the benefit ! Imagine where we will be in another 10 years. Anti gravity sleds?
__________________
Randy
406-249-1132
  #8
Old 01-08-2018, 04:17 PM
mtn-doo's Avatar
Default
Hey guys. Here are a few pic's. I will cover more pic's as needed and follow up with some Video. The new Sidekicks were released last week and there are several local guys out playing. I will try to get some Vid and answer any questions going forward.
Click image for larger version
ID:	291105   Click image for larger version
ID:	291106   Click image for larger version
__________________
Randy
406-249-1132
  #9
Old 01-08-2018, 04:47 PM
fredw fredw is offline
Currently: 850 blown up before Breakin over
Basic Member
fredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond reputefredw has a reputation beyond repute
Default
Are you running no oil pump on that kit Randy like they are doing on the Sibler? Dead heading turbo and feed from raves?
Stock reeds? Additional weight added to sled once turbo is installed? Retail cost!!
  #10
Old 01-08-2018, 05:07 PM
mtn-doo's Avatar
  #11
Old 01-08-2018, 05:22 PM
inspector01 inspector01 is offline
Currently: Not set.
inspector01 has a reputation beyond reputeinspector01 has a reputation beyond reputeinspector01 has a reputation beyond reputeinspector01 has a reputation beyond reputeinspector01 has a reputation beyond reputeinspector01 has a reputation beyond reputeinspector01 has a reputation beyond reputeinspector01 has a reputation beyond reputeinspector01 has a reputation beyond reputeinspector01 has a reputation beyond reputeinspector01 has a reputation beyond repute
Click Here to Register
  #12
Old 01-08-2018, 05:47 PM
mtn-doo's Avatar
  #13
Old 01-08-2018, 06:14 PM
Currently: Not set.
  #14
Old 01-08-2018, 07:42 PM
mtn-doo's Avatar
  #15
Old 01-08-2018, 08:26 PM
madmax's Avatar
madmax madmax is offline
Currently: Not set.
madmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond reputemadmax has a reputation beyond repute
The Following 5 Users Say Thank You to madmax For This Useful Post:
live2beel (01-08-2018), mtn-doo (01-08-2018), mtncat (01-09-2018), Polaris Pilot (01-09-2018), Ryan-41 (02-01-2018)
  #16
Old 01-08-2018, 08:45 PM
Chadly's Avatar
Currently: Not set.
  #17
Old 01-08-2018, 10:03 PM
mtn-doo's Avatar
  #18
Old 01-08-2018, 10:09 PM
mtn-doo's Avatar
  #19
Old 01-08-2018, 10:40 PM
Basic Member
  #20
Old 01-08-2018, 11:04 PM
Skidoo bachelor Skidoo bachelor is offline
Currently: Not set.
Basic Member
Skidoo bachelor is an unknown quantity at this point
  #21
Old 01-09-2018, 09:22 AM
Currently: Not set.
  #22
Old 01-09-2018, 11:00 AM
mtn-doo's Avatar
  #23
Old 01-09-2018, 11:15 AM
Currently: Not set.
  #24
Old 01-09-2018, 12:10 PM
nuttyn01 nuttyn01 is offline
Currently: Not set.
nuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond reputenuttyn01 has a reputation beyond repute
  #25
Old 01-09-2018, 12:34 PM
Currently: Not set.
Reply
Bookmarks
Tags
boondocker, ski doo, ski doo 850, turbo ski doo
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2016 Snowcheck Axys Sidekick 163" Thread Starter — M8Chris Forum — Polaris (Swapmeet) Replies — 0 Last Post — 03-18-2017 09:59 AM
Thread — Sidekick on axys 155" 2.6 Thread Starter — FCR112 Forum — Polaris: TURBO Replies — 10 Last Post — 10-10-2016 10:45 PM
Thread — IOs auto reroute. "Mobfree.click" WTF! Thread Starter — xc6rider Forum — Suggestions and User Feedback Replies — 1 Last Post — 01-01-2016 06:53 AM
Thread — IOs auto reroute. "Mobfree.click" WTF! Thread Starter — xc6rider Forum — Suggestions and User Feedback Replies — 0 Last Post — 01-01-2016 06:46 AM
Thread — battery life and "auto" feature on 509 goggle fan Thread Starter — Bocephus Forum — General Snowmobiling Replies — 13 Last Post — 12-11-2012 11:43 AM
