Upgrade to Premium
Polaris: 900 05-06 Polaris RMK 900
Reply
  #1
Old 01-08-2018, 10:49 AM
Bobbytee Bobbytee is offline
Currently: Not set.
Basic Member
Bobbytee is an unknown quantity at this point
Default 2006 Polaris 700 no spark
Problems all started when heated grips shorted and caused gauges to go out. Headed back to the truck and died on trail. Stator checks good and so does regulator.
Rate this post: Yes | No
  #2
Old 01-08-2018, 05:29 PM
mountainhorse's Avatar
mountainhorse mountainhorse is offline
Currently: CONTEMPLATING: "Laughter is gods hand on a troubled world.".
mountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond reputemountainhorse has a reputation beyond repute
Default
How did you check those parts?
__________________
Signature:
  #3
Old 01-09-2018, 09:56 AM
Currently: Not set.
Basic Member
Default
I got .5 ohms between the 3 yellow wires on stator, and diode check on regulator was good on negative and positive sides.
  #4
Old 01-09-2018, 10:38 AM
Currently: Not set.
Basic Member
Default
I know there's more checks to do, if someone on here could offer some guidance it would be great!
  #5
Old 01-09-2018, 12:13 PM
retiredpop retiredpop is offline
Currently: Not set
retiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond repute
Default
Yellow wires come from the voltage generating portion of the stator which used to be commonly called the lighting circuit. The ignition circuit is different. I am attaching wiring diagram which shows resistances for other coils in the stator.
__________________
The older I get the better I was. In fact now that I think about it I'm a legend!
Haven't outgrown my 600 yet!
The Following User Says Thank You to retiredpop For This Useful Post:
Bobbytee (01-09-2018)
  #6
Old 01-09-2018, 12:55 PM
Currently: Not set.
Basic Member
Default
I'll check the ignition side and crank sensor. You have no idea how much time I've wasted online looking for that wireing diagram. Thankyou!!
  #7
Old 01-09-2018, 01:23 PM
7danie49 7danie49 is offline
Currently: patiently waiting for snow!
Basic Member
7danie49 has a reputation beyond repute7danie49 has a reputation beyond repute7danie49 has a reputation beyond repute7danie49 has a reputation beyond repute7danie49 has a reputation beyond repute7danie49 has a reputation beyond repute7danie49 has a reputation beyond repute7danie49 has a reputation beyond repute7danie49 has a reputation beyond repute7danie49 has a reputation beyond repute7danie49 has a reputation beyond repute
Default check wires that power coils
I had this problem with my 900, same stator I believe. I had correct resistance for everything but Green/Red to Green/Yellow and Green/Red to Brown/White, for which I had no readings. Turns out these power the coils.
For reference, this also shows resistances from the manual: https://ibb.co/f37boG
The Following User Says Thank You to 7danie49 For This Useful Post:
  #8
Old 02-04-2018, 11:13 PM
Currently: Not set.
Basic Member
Default She's alive!!!
After finding no resistance on ignition coils on stator, orderd and installed new stator. Fired first pull!!! You guys are the best!
Final diagnosis: Grips shorted and burnt coils on stator. Time to put some inline fuses in. Still can't believe there's no wire protection on this entire sled!
Reply
Bookmarks
Tags
700, no spark, polaris 700
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — 2006 Polaris sportsman 700 Thread Starter — jdw1 Forum — ATV/Motorcycle (Swapmeet) Replies — 1 Last Post — 02-07-2015 10:30 AM
Thread — 2006 Polaris 700/900 bottom end, 06 700 cylinders/head excellent shape, low miles Thread Starter — guidoxpress Forum — Engine/Engine Parts (Swapmeet) Replies — 1 Last Post — 02-06-2015 12:18 AM
Thread — 2006 Polaris 700 Rmk Thread Starter — ridepolaris800 Forum — Polaris Replies — 0 Last Post — 01-30-2015 01:32 AM
Thread — Video on diagnosing no spark, low spark or intermitten spark condition on 1990's Cats Thread Starter — Blaine Forum — Arctic Cat: Powder Special and older Replies — 0 Last Post — 12-29-2009 09:56 PM
no new posts
