Upgrade to Premium
Polaris: EDGE 2002-2005, all models in the Edge chassis
Reply
  #1
Old 01-08-2018, 09:36 AM
moorespeed450 moorespeed450 is offline
Currently: Not set.
Basic Member
moorespeed450 is an unknown quantity at this point
Default 700 SKS retard mode
Working on 700sks that will go into retard mode and shut one cylinder down when machine heats up, no lights come on dash. We have replaced or traded with known good parts and still does same thing. Replaced water pump impellar, belt, new aftermarket stator, sensor in head, checked TPS, traded out airbox with coils, been through carbs and reeds, traded out fuel pump and kill switch. Bleeding cooling system several times and ways. Still machine will go to a certain point then go into the retard mode and shut a cylinder down. Any suggestions would be great.
Rate this post: Yes | No
  #2
Old 01-09-2018, 08:54 AM
retiredpop retiredpop is offline
Currently: Not set
retiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond reputeretiredpop has a reputation beyond repute
Default
Do you know if the coolant is circulating through the coolers sufficiently? Run it at speed and stop to check temperature between right and left running boards. If coolant is not circulating the right one will be hot and left one considerably cooler. Is the temp light bulb good?
__________________
The older I get the better I was. In fact now that I think about it I'm a legend!
Haven't outgrown my 600 yet!
  #3
Old 01-09-2018, 09:08 AM
05rmksteve's Avatar
05rmksteve 05rmksteve is offline
Currently: Buying parts
05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute05rmksteve has a reputation beyond repute
Default
Did you try a different ecm?
  #4
Old 01-09-2018, 01:11 PM
Currently: Not set.
Basic Member
Default
ya ecm was tried when we installed different airbox, replaced light blub already, will check running boards thanks.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread — Is there a failsafe mode(limp mode) on Nytro if overheat going down the trail? Thread Starter — snowmanx Forum — Yamaha: 4-Stroke Replies — 9 Last Post — 01-04-2012 08:20 PM
Thread — 03 sks 700 Thread Starter — JFro50 Forum — Polaris: EDGE Replies — 3 Last Post — 12-08-2011 09:16 PM
Thread — HELP 03 sks 700 Thread Starter — yamarider48 Forum — Polaris: EDGE Replies — 4 Last Post — 02-07-2010 01:18 AM
Thread — 03 sks 700 Thread Starter — JFro50 Forum — Polaris: EDGE Replies — 9 Last Post — 10-12-2009 08:39 AM
Thread — 99 sks 700 must go!! Thread Starter — bobbyt1717 Forum — Polaris (Swapmeet) Replies — 5 Last Post — 09-08-2008 08:57 PM
